    Temperature stabilised test
    348
    • appjawsundefined
      appjaws
      Eventually my hotend temperature stabilise so I need to delay the print start until the temperature is, say +-0.5 (is that reasonable?)
      With my limited skills I have tried to have conditions to check the heat.heaters[1].current
      but I end up in a loop or it is ignored and the print never starts.
      Could anybody suggest a suitable test please
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      PCRundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @appjaws
        Easiest solution
        Add a G4 S10 (10seconds wait) before the Print start after the heating. Or how long it needs
        • engikeneerundefined
          engikeneer @appjaws
          @appjaws why not just use the tolerance parameter (S) in M116?
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M116_Wait
          You can just set that to 0.5degC or whatever you need
          i3 clone with a bunch of mods
          DonStaufferundefined 1 Reply Last reply Reply Quote 1
          • A Former User?
            A Former User
            if the heater has large overshoot then maybe trying to re-tune the PID under the same conditions as a normal print might help M116 do its job
            • appjawsundefined
              appjaws
              @PCR Thanks, but I need something that is more automatic, especially during tool change, and keeps the wait time to a minimum.
              @engikeneer Thanks, tried that but as soon as the temperature is reached, the print starts even though the overshoot is 5C.
              Simplify3D 5.1.2
              DonStaufferundefined 1 Reply Last reply Reply Quote 0
              • DonStaufferundefined
                DonStauffer @engikeneer
                @engikeneer I'm looking at this issue right now.
                If I wait for the temperature to be within tolerance, it could see that as the temperature is in the process of overshooting (which is normal). Then I'd be printing at too high a temperature at first. This actually just happened to me yesterday, which is why I did a search on this topic.
                What I probably want is for the temperature to STAY within tolerance for a specific period of time, indicating it is stable (not just "passing through"). Perhaps it would be enough to do something like:
                M116 P0 S1
                G4 S1 ; Allow for Overshoot
                M116 P0 S1 ; Wait for Recovery
                The 1-second delay gives it time to overshoot by more than the tolerance, and then it waits for it to come back down. I've never seen a properly-tuned hot end drop below the target substantially after recovering from overshoot.
                Update: 1 second wasn't NEARLY enough. I'm trying 12 seconds now. There needs to be time for the temp to reach 1 below the target, and continue up to 1 above the target.
                  Phaedrux Moderator @DonStauffer
                  @donstauffer Perhaps best to re-tune or manually adjust the parameters to remove the overshoot entirely?
                  If during initial heating the temperature undershoots the target, reduce the A parameter ((RRF 3.2 and earlier) or increase the R parameter (RRF 3.3 and later). If it overshoots the target, increase the A parameter or reduce the R parameter. Try increasing/reducing it by 5% or 10%.
                  https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                    DonStauffer @appjaws
                    @appjaws I'm watching my 2-color print with those 2 additional temperature stabilization lines in the startup and tool change scripts. OMG, does that matter! Stringing is down, consistent appearance and sheen, even extrusion! Wow!
