Square Nozzle Orifice
I've finally had time to sample this nozzle a bit. A few initial considerations:
- other than swapping nozzles, printer hardware and settings remained the same, except the Z offset
- photos were taken under the same lighting conditions and with the same settings
- there are other minor print quality issues that I am aware of (obvious in the pictures), but did not affect the goal of the experiment and were thus ignored
- these tests were certainly not exhaustive and could be improved upon with more time
- 250* (PETG), 60mm/s with no reductions or overrides, 25% infill
- Part size at base is 50mm
First impressions: the square doesn't make much of a difference, but the EDM finish does. Whether or not it would be considered significant is purely subjective, but the change is objectively there. It appears to do the following, to some degree:
- hide ringing and other imperfections
- slightly more matte finish
I will be performing additional testing with a coarser EDM finished round nozzle to confirm the improvements were not orifice shape related. Further, I'd like to quantify the change in surface finish. Can anyone point me in a helpful direction?
Next: because the majority of the nozzle was predrilled, I believe a larger EDM finished surface area may further improve results. After all, the total land for the major orifice ID is only .60mm. It will be a bit, but these results will also be shared. A star shape nozzle is still on the shortlist for the existing nozzle blanks.
Other observation: the square nozzle did allow me to more easily print higher layer heights. The single attached picture was printed at .40mm layer heights. I did not put much effort into it, but the .40mm round nozzle could not complete a print under the same settings/conditions. This may be attributed to the larger surface area of the square vs. circle.
Please see the picture (dropbox link at the bottom) and share your thoughts. The image is quite large (source quality) for better assessment.
Additionally, I would love to share a square nozzle with someone qualified to spend some time experimenting with it, should anyone be interested. In exchange for said testing, the nozzle would not have to be returned.
Please let me know if you have any questions, I'd be happy to elaborate on anything.
Full Comparison Photo
https://www.dropbox.com/s/h90btw6l11z34y0/Finished.jpg?dl=0.40 Layer Height
https://www.dropbox.com/s/kk4213mvsp8ytfe/01.jpg?dl=0EDIT: For clarity and to add certain print settings
I am sorry to say that I can only see a very minor difference in quality (which is exceptional in both prints). Given the cost and effort to produce the result, it doesn't seem worthwhile.
I wonder if the nozzle might be more effective in less perfect printers .... -
No apologies necessary, this is why I shared it. For me it's somewhere more in between, but I may be biased. At this point I'm mostly looking for any change or improvement. And I appreciate the comment on print quality. I would definitely like to try these on some off-the-shelf entry level printers; good idea.
Maybe on shorter layer heights it would make more of a difference. I suspect that the filament will want to return to a rounded state as soon as it's able to.
What does the extrudate look like in free air? Does it retain a square shape or does it return to a round shape?
@Phaedrux Surprisingly it retains a square shape. I'll see if I can find some purge to take a picture of.
@plasticfactory said in Square Nozzle Orifice:
Fascinating.
How does the internal geometry differ on the two nozzles? With the carbide nozzles I've used before there was no throat, the internal faces tapered all the way to the actual opening. We never did real testing to compare to our standard steel nozzles, but there was a noticeable improvement in quality.I will be performing additional testing with a coarser EDM finished round nozzle to confirm the improvements were not orifice shape related. Further, I'd like to quantify the change in surface finish. Can anyone point me in a helpful direction?
Ooo. That might be tough, most surface roughness measurement tools are going to pull out the layers just as much as anything else. But I'm not a metrology engineer...
Can you clarify what you mean by 'easily'?
I'd love to get these nozzles on a load cell, as I assume what you are describing is lower extrusion force. Certainly surface area of the nozzle has a huge impact on extrusion force.
The 0.4mm round nozzle is 0.126mm2, the square is 0.16mm2. The relationship between extrusion force and cross-sectional area of the nozzle isn't simple, but in this kind of range I'd expect it to be reasonably linear. So I would expect the square nozzle to require 25-30% less force for a given volumetric flow rate.It would be interesting if a square or otherwise non-round nozzle would let you extrude significantly narrower paths than the major diameter of the nozzle, but without a loss in quality. That might be the trick for getting down to silly size extrusions. Although it would probably need something other than sinker EDM to make it even close to economical.
What extrusion widths were you using?Please see the picture (dropbox link at the bottom) and share your thoughts. The image is quite large (source quality) for better assessment.
I do find it very interesting that what I would have assumed was ringing from the X/Y stage, clearly must be some sort of ringing in the extruder.
Could be laminar low, could be a masters thesis for the eggheads over at UC Berkeley. -
@theruttmeister said in Square Nozzle Orifice:
Fascinating.
How does the internal geometry differ on the two nozzles? With the carbide nozzles I've used before there was no throat, the internal faces tapered all the way to the actual opening. We never did real testing to compare to our standard steel nozzles, but there was a noticeable improvement in quality.Internal geometry is identical to an E3d V6, but with a square orifice. Within 60 days we should be sampling nozzles without that major ID. Then we will be able to try different internal geometries. In your case, were you using the nominal ID, with a draft (cone shaped end to end)? Just want to make sure I'm understanding correctly.
The 0.4mm round nozzle is 0.126mm2, the square is 0.16mm2. The relationship between extrusion force and cross-sectional area of the nozzle isn't simple, but in this kind of range I'd expect it to be reasonably linear. So I would expect the square nozzle to require 25-30% less force for a given volumetric flow rate.By easily I mean I changed no settings going from .20 to .40 other than the layer height.
I don't currently have the ability to do that kind of testing. Though I'd certainly be happy to toss one of these to someone who could.
What extrusion widths were you using?I was thinking perhaps a trapezoidal shape could help things, almost like a paintbrush effect. Though I'm not sure where to begin on geometry, and because it would only have one "direction" it's not really feasible for me to do anything but make one. Perhaps it's time to start considering another axis, maybe something open source already exists here.
I was printing .50mm width.
Could be laminar low, could be a masters thesis for the eggheads over at UC Berkeley.lol, I hadn't considered it would be ringing from the extruder. Based on my jerk/accel settings I'm still inclined to believe it's from the XY. It's throwing a Hemera around without much regard for anything at the moment.
Yes, the nozzle went from 2mm ID, down to the 0.4mm orifice as a single cone shape progression. I don't recall the angle, but probably 20 degrees. Actually quite reasonably priced!
I have a load cell... and a setup I was intending to use for benchmarking some extruders.
It's not finished right now, but it wouldn't be too hard to finish it.
I don't have any extruders that your nozzle would fit though. All the ones I have on hand are... custom, shall we say.I was thinking perhaps a trapezoidal shape could help things, almost like a paintbrush effect. Though I'm not sure where to begin on geometry, and because it would only have one "direction" it's not really feasible for me to do anything but make one. Perhaps it's time to start considering another axis, maybe something open source already exists here.
Before that, I'd be interested to see the results of printing more organic shapes and general things not aligned with the nozzle orientation. Because:
The major dimension of your square nozzle is ~0.56mm (diagonal). My interest is can you get the quality of a smaller round nozzle, but using a larger surface area and hence lower force, square nozzle.
Can you try some prints at say, 0.45mm width?The paintbrush idea seems sound, but that brings back needing infinite rotation of the nozzle/hotend.
Square is a good place to test ideas for now. A 4 pointed star might also be interesting.lol, I hadn't considered it would be ringing from the extruder. Based on my jerk/accel settings I'm still inclined to believe it's from the XY. It's throwing a Hemera around without much regard for anything at the moment.
Its an axis like any other, and steppers act like a spring-mass. I see no reason why we shouldn't be thinking about the things discussed here:
https://forum.duet3d.com/topic/20373/a-software-solution-to-eliminate-ringing
For the extruder as well.
My hypothesis being that the square nozzle, requiring less force, generates less slip in the motor and so what looks like ringing being eliminated is actually cogging of the extruder motor as it accelerates the filament (less load, less cogging). -
Can you try some prints at say, 0.45mm width?I will print some more traditional parts this weekend. I see what you're saying now. I will try it with the part pointed "forward" and at 45*. I settled on going side to side because of the ideas presented in the original post, but I think you are onto something here.
I could also make another one at .40mm for the major dim, but that seems counterproductive. A squircle would also be possible.
My hypothesis being that the square nozzle, requiring less force, generates less slip in the motor and so what looks like ringing being eliminated is actually cogging of the extruder motor as it accelerates the filament (less load, less cogging).This explanation makes a lot more sense to me now. It's definitely changed the way I'm thinking about this.
This post is deleted!
