Heater Will not turn off once started.
I am having another heater issue on my new DUET 3 6HC board, when i turn the system on everything seems fine however if i do one of two things,
1, If i turn off thermostatic control on the fan attached to the hotend and the fan comes on with the system power and so does the heater.
2, if i turn thermostatic control on with a temperature of 45 degrees, If i then run M303 H1 S250 to tune the heater everything turns on as it should and i see a temperature rise as expected however at the target temperature the web interface shows the heater should be turned off but ist not it reached 350 degrees with no errors, i then powered down the board waited 10 seconds turned it back on and the heater continued to rise in temperature.
I next turned the board off for 30 mins approx (until hotend was cool) i then turned the board back on and the heater was off and showing 25 degrees in temperature .
My Config.g
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.10 on Mon Dec 07 2020 21:49:17 GMT+0000 (Greenwich Mean Time) ; General preferences G21 ; Work in millimetres G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards (X) M569 P0.1 S1 ; physical drive 0.1 goes forwards (Y) M569 P0.3 S1 ; physical drive 0.3 goes forwards (E0) M569 P0.2 S0 ; physical drive 0.2 goes backwards (Z1 Front Left Motor) M569 P0.4 S0 ; physical drive 0.4 goes backwards (Z2 Back Left Motor) M569 P0.5 S0 ; physical drive 0.5 goes backwards (Z3 Right Motor) M584 X0.0 Y0.1 Z0.2:0.4:0.5 E0.3 ; three Z motors connected to driver outputs 2,4 and 5 M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M671 X205:205:-195 Y-205:205:0 S0.01 ; leadscrews at Front left (X195 Y195), Rear left (X195 Y-195) and right (X0 Y-195) M92 X160.00 Y160.00 Z80.00 E420.00 ; set steps per mm M92 X80 Y80 for 1.8º degree steppers and M92 X160 Y160 for 0.9º M566 X600.00 Y600.00 Z360.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z120.00 E120.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X410 Y410 Z410 S0 ; set axis maxima ; Endstops M574 X1 Y1 S3 ; use stall guard for XY endstops (X min, y max) M574 Z1 S2 ; Set endstops controlled by probe ;M915 X Y R0 F0 H400 ; Stall guard config when not homing ; Z-Probe M558 P5 C"^io3.in" I1 H1 F1000 T6000 A20 S0.005 ; Prusa PindaV2 sensor config. M308 S2 P"temp3" A"Pinda V2" Y"thermistor" T100000 B3950 ; Prusa PindaV2 temperature config. G31 P500 X0 Y30 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:375 Y15:375 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 S0.7 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 S"HOTEND" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
Can you pull your SD card from the board and then power on and see if the heater still starts to heat automatically?
@Phaedrux if I do that I would expect the heater to be off.. the issue seems to be once its on it will not turn off.
@Turricann
pheadrux wants to test if your mosfet is blown. that is a quick way to test it.
What i have done to prove its not hardware is heated the hotend to 200 degrees then powered down and removed the PI I/O cable, when powered back up the heater stayed off.
I then Powered down again and refitted the I/O cable, when powered back up and the temp was @145 degrees fan came on and heater came on although temps were set to 0 and status set to Off.
It seems to be when the hotend fan is on the heater is running ... so if temp goes above 45 degrees fan turns on and heater will not turn off.
If thermostatic control is turned off the fan then the heater comes on when the board is powered ( actual timing is when Pi is booted).
@Turricann I am slightly confused by the thread. is the 6HC running in stand alone mode or with an attached SBC?
In either case what version of firmware are you running? Please try upgrading to 3.2b4.1
I have noticed one off thing with your config:
M106 P1 S1 H T45
H should have a heater number after it or be set to -1 (and i assume it is not intended for it to be off) not sure how you have the fans connected as you only have 1 hotend heater configured but if you want these fans to be based on the heater then this should be H1
@T3P3Tony The setup is a duet 3 6HC running with a Pi , the pi has its own 5a supply. I am upgrading the firmware and the software to the latest as we speak but originally I was running RRF 3.1.1.
As for the fans currently I have 3 fans on out7,8,9 but nomatter which header I use the same issue occurred.
Yes m103 its set to H1 must of captured that while making changes.
Can you also send M98 P"config.g" in the console and report the results?
not any more since updating to RRF 3 beta 4 i am getting DCS failed to connect to duet 3
Dec 11 22:11:20 duet3 DuetControlServer[3872]: [info] Settings loaded
Dec 11 22:11:21 duet3 DuetControlServer[3872]: [info] Environment initialized
Dec 11 22:11:21 duet3 DuetControlServer[3872]: [fatal] Could not connect to Duet (Invalid protocol version 3)
Dec 11 22:11:21 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
Dec 11 22:11:26 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
Dec 11 22:11:26 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 109.
Dec 11 22:11:26 duet3 systemd[1]: Stopped Duet Control Server.
Can you start from a freshly downloaded version of DuetPi and then update from there with sudo apt update sudo apt upgrade?
Still the same DCS is not started. RRF 3.1.1 --> board has 3.2 beta 4
Are you saying you started with a fresh image and updated, then added the unstable branch and updated again?
No the image on the Pi is the one from the link but just checked,
pi@duet3:~ $ sudo apt list duetcontrolserver -a
Listing... Done
duetcontrolserver/stable,now 3.1.1 armhf [installed,automatic]
duetcontrolserver/stable 3.1.0 armhf
duetcontrolserver/stable 1.2.4.0 armhf
duetcontrolserver/stable 1.2.3.0 armhf
duetcontrolserver/stable 1.2.2.1 armhf
duetcontrolserver/stable 1.1.0.5 armhf
duetcontrolserver/stable 1.0.4.1 armhf
duetcontrolserver/stable 1.0.3.1 armhf
Yes, and you can either update the Pi to also be 3.2 b4, or flash the duet back to 3.1.1
If you wish to use the latest unstable DSF components, you can run the following commands instead:
wget -q https://pkg.duet3d.com/duet3d.gpg wget -q https://pkg.duet3d.com/duet3d-unstable.list sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/ sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
Thanks that is what i needed to sort that issue, I upgraded to try and resolve the original issue about the heater recommended by @T3P3Tony ,
I will redo config.g now and see what happens with the heaters.. thanks for your support.
OK config.g redone left every thing else default from a clean install on the Pi
On my duet 3 6hc i have the below,
Running on a 24v supplyOut0 - heatbed. - on/off working OK
Out1 - 24v heater.
Out7 - Hotend fan
Out8 - Partcooling fan
Out9 -Partcooling fan (Disconnected)
TEMP0 - Heatbed thermistor(B9350)
TEMP1 - Hotend Thermistor (B4138)
Temp3- Thermistor from Z probe.
IO_0 = pannal Due - currently disconnected.
IO_3 = Z probe Pinda v2 type
Driver 0 = X
Driver 1 = Y
Driver 2 = Z1
Driver 3 = E0
Driver 4 = Z2
Driver 5 = Z3Thats is everything connected and my config.g is,
; generated by RepRapFirmware Configuration Tool v3.1.10 on Mon Dec 07 2020 21:49:17 GMT+0000 (Greenwich Mean Time); General preferences
M669 K1 ; select CoreXY mode; Drives
M569 P0.5 S0 ; physical drive 0.5 goes backwards (Z3 Right Motor)M584 X0.0 Y0.1 Z0.2:0.4:0.5 E0.3 ; three Z motors connected to driver outputs 2,4 and 5
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolationM671 X205:205:-195 Y-205:205:0 S0.01 ; leadscrews at Front left (X195 Y195), Rear left (X195 Y-195) and right (X0 Y-195)
M566 X600.00 Y600.00 Z360.00 E600.00 ; set maximum instantaneous speed changes (mm/min)M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M208 X410 Y410 Z410 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; Set endstops controlled by probe;M915 X Y R0 F0 H400 ; Stall guard config when not homing
M557 X15:375 Y15:375 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0.7 H1 ; set fan 0 value. Thermostatic control is turned
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
@Turricann So with a fresh config and Pi the heater is still staying on once enabled?
But it's not turning on automatically when power is first applied, right?
yes that is correct as long as the hotend is below 45 Degrees or fan0 has not got thermostatic control disabled .
If thermal control is enabled and the hotend is below 45 degrees the heater will turn on and off normally,
If its above 45 Degrees the hotend will come on with power.This is why i came to the conclusion the heater will not turn when the fan is on.
one more thing is if there are no fans set up i cannot control the heater.
It looks like your config was pasted twice maybe in your last post?
One other thing is when the heater comes on at power up its not instant there is about a 30 second delay like it only happens when the pi powers up.
@Phaedrux yes it was just realized that myself.
Thermistor attached to heater is a ATC Semitec 104GT-2 104NT-4-R025H42G
@Turricann, please state clearly which heater output and which fan output are the ones involved in this issue. I think it's heater 1 on out1, but you appear to have changed the fan configuration between the original config.g you posted and the recent one, and I can't tell whether the fan involved is on out7, out8 or out9.
@dc42 Heater is on output1 and fan is on out7(F0)
