    motor phase A may be disconnected help a newby out
    610
    • Fisherundefined
      Fisher
      Im in pthe process of commisioning my new core XY build, I've never used duet electronics before and im having an issue getting the motors running. When homing either the X or Y axis the tool head will move 10mm or so before stopping and the board returns
      G28 Y
      Warning: motor phase A may be disconnected reported by driver(s) 2
      Warning: motor phase B may be disconnected reported by driver(s) 2
      im sure its somthing im doing wrong, the fact that im getting a bit of movement is heartning.
      im using e3d's 'high torque motors' on the x and y.
      • Step Angle: 0.9°
      • Rated Current: 1.68A
      heres the relevent part of my config.g:
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z400.00 E420.00            ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X100.00 Y100.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      System is running on 24v, Anyone know what i might be doing wrong? TIA
      • Fisherundefined
        Fisher
        Forgot to say im using a duet2wifi firmware ver 3.1.1
          jay_s_uk
          have you wired the cables yourself or are you using the cables that came with the motor?
          • Fisherundefined
            Fisher
            cables came with the motors, the small ammount of movement i am getting is in the correct direction when homing.
              Check your motor phases are paired correctly and that the crimps are good.
              https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                Driver 2 is the one marked Z. There are two output connectors for that driver, connected in series. If you have only one Z motor, do you have 2 jumpers in the second Z motor connector? If it's a genuine Duet, it should have been supplied with those jumpers already fitted.
                Nellorundefined 1 Reply Last reply Reply Quote 0
                • Fisherundefined
                  Fisher
                  solved: incorectly wired endstops... i knew it would be somthing silly, thanks all the same.
                  • Nellorundefined
                    Nellor @dc42
                    Im running the current version 3.2-RC2 (2020-12-24) at a Duet 3 6HC
                    When homing the Y-Axis I get a warning:
                    What does the number 2 means? Thought it indicates the corresponding drivers in that case number 1.
                    I only connected Y at the Driver_1 connector and the corresponding endstop.
                    M569 P0.0 S0 ; physical drive 0.0 goes backwards
                    M569 P0.1 S0 ; physical drive 0.1 goes backwards
                    M569 P0.2 S1 ; physical drive 0.2 goes forwards
                    M569 P0.3 S0 ; physical drive 0.3 goes backwards
                    M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                    What wonders me even more is if I try to Home X - of course no motor/endstop is connected to X I get the same warning.
                    • A Former User?
                      A Former User @Nellor
                      @Nellor said in motor phase A may be disconnected help a newby out:
                      probably best to start a new thread rather than continuing someone elses solved thread.
                      drivers are usually
                      0=x
                      1=y
                      2=z
                      3=e0
                      4=e1
                      edit: d'oh .. the duet3, unlike they duet 2, the numbers match the pcb silk screen so just refer to the board and see what you've connected to driver2.
                      • Nellorundefined
                        Nellor @A Former User
                        @bearer
                        I posted that here as maybe something is wrong with the number indication at the warning where DC42 assumed the thread opener is talking about Z - I assume he never talked about z axis...
                        With your explanation it makes even more no sense with the warning.
                        I will delete or shift the post if it is a big problem.
                        • A Former User?
                          A Former User
                          its not a problem as such; its just not easy for others to relate to a solved topic with a new question, and notifications go to everyone else, but not necessarily you etc.
                          • Nellorundefined
                            Nellor
                            Ok, got it... will delete or move it.
                            I found out whats the reason of getting it when I Home Y.
                            • If nothing else is wired besides the Y-Axis you will get all the time this warning. So i assumed it must be Y related even showing Z.
                            • If you don't know that a Y movement results also in a short Z move/lift you end up with not understanding whats going on...
                            • In my case even a Duet Maestro connected before at this build stage without warning.
                            -> Hooked up also a Z Motor and the warning is gone.
                              Phaedrux Moderator @Nellor
                              @Nellor Your homing file probably has a Z lift.
