    Configuring S42B Close Loop Stepper Controller
    Third-party add-ons
    8
    28
    3.4k
    • Adamfilipundefined
      Adamfilip
      I am going to add two of the BigtreeTech S42B Closed Loop Stepper motor addons to my Custom CoreXY 3D printer.
      https://github.com/bigtreetech/BIGTREETECH-S42B-V1.0
      https://www.biqu.equipment/products/bigtreetech-s42a-42-stepper-motor-closed-loop-driver-board-with-oled-display
      I have a DuetWifi with an Duet Expansion Breakout Board
      My current Config setup for the motors is the following.
      M569 P0 S0                                      ; physical drive 0 goes backwards
      M569 P1 S0                                    ; physical drive 1 goes backwarsa
      M569 P2 S0                                       ; Z physical drive 2 goes backwards
      M569 P3 S1                                       ; Extruder physical drive 3 goes Forwards
      M584 X0 Y1 Z2 E3                                 ; set drive mapping
      M350 X32 Y32 Z32 I0                              ; configure microstepping without interpolation
      M350 E16 I1                                      ; configure microstepping with interpolation
      M92 X400 Y400 Z1593 E409             ; set steps per mm
      M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min) JERK
      M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1500 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M572 D0 S0.0125 ; Pressure Advance                                        ; Set idle timeout
      Lookin for assistance on what to change 🙂
        Adamfilip
        Looking for some assistance. I have a Duet Wifi with External Driver BOB controller and a S42B Closed Loop controller on my stepper.. I want to connect them together
        I suck at wiring lol.. hoping someone kind can help me determine how to connect the two boards...S42B-duet-wiring.jpg
          Adamfilip
          S42b - duet bob
          Dir -> dir +
          Step -> step +
          En -> En +
          Gnd -> gnd
          5v -> 5v +
          24 -> 24v + on power supply
          Is this correct?
          • fcwiltundefined
            fcwilt @Adamfilip
            @Adamfilip said in Configuring S42B Close Loop Stepper Controller:
            Just out of curiosity why are you going to do that?
            Everything I have read says there is no reason to do so.
            Thanks.
            arhiundefined 1 Reply Last reply Reply Quote 0
              Adamfilip
              I run into issue with occasional layer shifts that I havent been able to resolve.
              so im trying this.
              • arhiundefined
                arhi @fcwilt
                @fcwilt said in Configuring S42B Close Loop Stepper Controller:
                I found bunch of "tests" showing they are not precise (moire patterns worse then bad motors on microstepping) but I found also ppl saying they are awesome and that all their artifacts are now gone... so I ordered 4 drivers (only drivers no motors), attached to my own motors and now am thinking about good test jig to test how accurate they are ... will see if I'll attach some super high precision encoders or go another way about them.. but in any way more ppl testing them the better, the hal sensor precision is not bad and the software is not that hard to write for that so in theory they should be very good... (so far I just turned them on and I don't like the sound I hear but let's see if I manage to make some test during NY holidays)
                  Adamfilip
                  Had someone with Electronics experience help me figure out how to connect them.
                  hope this is right lol
                    You will damage the expansion breakout board with the driver connected like that. Disconnect the driver 5V common pin from all 3 pins on the breakout board. Connect it to 5V+ on one of the servo connectors on the breakout board instead.
                      Adamfilip
                      Servo connectors? Do you mean the 5v+ on the Two Heater6&7 areas?
                        dc42 administrators @Adamfilip
                        Yes.
                          Adamfilip
                          Here is a revised diagram
                            Still not right:
                            • Leave the breakout board Step+, Dir+ and Enable+ not connected to anything (and not connected to each other)
                            • Connect +5V from the breakout board to COM on your driver
                              Adamfilip
                              Ok so your suggesting like this
                              • arhiundefined
                                arhi
                                Is this working for you ?!
                                I'm doing the simplest thing possible
                                DIR -> GND
                                EN -> GND
                                GND -> GND
                                VM -> 12V
                                5V -> 5V
                                STEP -> 0-5V gpio
                                and darn thing won't move ?!?! loosing my hair for 2 days already
                                • alankilianundefined
                                  alankilian
                                  @arhi said in Configuring S42B Close Loop Stepper Controller:
                                  EN -> GND
                                  I don't mean to be Captain Obvious, but do you have the system configured for enable=low?
                                  It looks like it can be set to either.
                                  Also, do you have both power supply grounds connected together and to GND on the servo?
                                    Adamfilip
                                    I have just wired up my S42B and Motors
                                    After i changed settings, I do calibrated and it started working
                                    This is my current settings for it,
                                    M569 P5 R0 S0 T3.33:3.33:5:0                                      ; physical drive 0 goes backwards previously P0, p5 is on expansion board
                                    M569 P8 R0 S0 T3.33:3.33:5:0                                  ; physical drive 1 goes backwarsa previously P1, p8 is on expansion board
                                    M584 X5 Y8 Z2 E3                                 ; set drive mapping , old X0 Y1
                                    M350 X16 Y16 Z32 I0                              ; configure microstepping without interpolation, previously 32
                                    M92 X100 Y100 Z1593 E409             ; set steps per mm
                                      Adamfilip
                                      Woohoo Got it working. check out demo
                                      https://youtu.be/Qz6EoinibEc
                                      Phaedruxundefined fcwiltundefined CNCModellerundefined 3 Replies Last reply Reply Quote 1
                                        Phaedrux Moderator @Adamfilip
                                        @Adamfilip Very cool. Thanks for sharing. Let us know how it works out in practice.
                                        • arhiundefined
                                          arhi @alankilian
                                          @alankilian said in Configuring S42B Close Loop Stepper Controller:
                                          tried both !Enable and Enable configuration for the good measure, no help
                                          yes
                                          Also tried 1234 dip's as 1111 (default, first two are what I understand microstepping, third is open/closed control and fourth is write enable for calibration), 1100, 1101, 0000, 0011, 0001 ... no change
                                          at one point I got it to "turn" but was going into "error" after few steps but most of the time it just won't turn at all ... wasted too much time with it I'll try a second driver and a second motor to be sure but I'm moving with my testing to other systems 😞 I think this one was just not meant to be
                                          Massoundefined 1 Reply Last reply Reply Quote 0
                                          • fcwiltundefined
                                            fcwilt @Adamfilip
                                            In real world printing what conditions would correspond to displacing the position with your thumb as you did in your video?
                                            Thanks.
                                            Adamfilipundefined 1 Reply Last reply Reply Quote 0
