    Preview version of CNC optimized DWC.
    CNC
    40
    191
    28.2k
    • weed2allundefined
      weed2all @AverageUser
      @AverageUser you need to update your duet wifi server...it wont work on 1.22
      https://www.thingiverse.com/weed2all/designs
        Phaedrux Moderator @AverageUser
        @AverageUser said in Preview version of CNC optimized DWC.:
        can it be that my firmware is too old?
        @chimaeragh said in Preview version of CNC optimized DWC.:
        I am facing the same issue. Duet2Wifi, Reprap firmware 2.05.1
        Yes. You're going to want to update your firmware and DWC first before trying the CNC stuff.
        If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        That will get your firmware and DWC up to date.
        For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
        https://configtool.reprapfirmware.org/Start
        chimaeraghundefined 1 Reply Last reply Reply Quote 0
        • Sindariusundefined
          Sindarius @jay_s_uk
          As @jay_s_uk stated the machine has to be in CNC mode for the new dashboard to kick in.
          • AverageUserundefined
            AverageUser
            Wow thank you very much for your help. I'll report tomorrow if everything worked. Thx again 👏 👏
            • chimaeraghundefined
              chimaeragh @Phaedrux
              @Phaedrux I am currently using Ooznest's DWC with my Workbee CNC and wanted to try this one out. Since Workbee Control is not compatible with RRF3, I have been reluctant to do the upgrade and have to downgrade again.
              However, it states on the github page for this project
              Compatible versions:
              • DuetSoftwareFramework 3.2.0-RC1
              • RepRapFirmware 2 or newer (1.2x may work but untested)
              I was hoping it would work without having to upgrade firmware.
              PS: I tried upgrading but couldn't get the config right. Homing didn't work and emergency stop was triggered on startup
              Duet 2 Wifi, Ooznest Workbee CNC 1510
              Sindariusundefined Phaedruxundefined chimaeraghundefined 3 Replies Last reply Reply Quote 0
                Sindarius @chimaeragh
                @chimaeragh I’ll double check but I believe that RRF 2.x should work. The main thing is the object model needs to recognize that the printer is in CNC mode and it will change the dashboard over to the new set of controls.
                Edit : I rolled back a Duet 2 WiFi I have on hand and it appears that the State > machineMode is not populated in RRF 2.05.1 so the DWC-CNC dashboard will not show up. RRF 3.x will be necessary to make the dashboard switch over to the new ui.
                  Phaedrux Moderator @chimaeragh
                  Start a thread about updating. I'm sure we can work you through it.
                    AverageUser
                    Guys, thank you very much for your help. Now everything looks just fine! The only question is now: how do I configure my spindle?! Is there like a tutorial somewhere for the DWC-CNC?
                    (I just had to update the RR-Firmware... thats it.. lol)
                      jay_s_uk
                      M453
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_Select_CNC_Device_Mode
                      • kouta10undefined
                        kouta10
                        Hi guys, I am running duetwifi with rrf 3.2. When I switch over to cnc mode with cnc web interface, my paneldue 5i displays random error messages that keep changing. Any one else having this issue? I have tried firmware 1.24 and 3.2.9 on paneldue with the same result.
                          jay_s_uk @kouta10
                          @kouta10 how long is your cable?
                          kouta10undefined 1 Reply Last reply Reply Quote 0
                          • kouta10undefined
                            kouta10 @jay_s_uk
                            @jay_s_uk my cable is 1.7m. I know its longer then recommended but its didn't seem to be an issue for the standard version of the web control.
                              jay_s_uk @kouta10
                              @kouta10 is it shielded with the shielding grounded?
                              I don't think the DWC interface interacts in any way with paneldue as the paneldue is querying the object model.
                              I would be comfortable saying its interference and not DWC that is causing this.
                              • kouta10undefined
                                kouta10 @jay_s_uk
                                @jay_s_uk when I take it out of cnc mode it fine. Even when I was using rrf 2 with workbee web control it was ok. After I have updated my firmware to rrf 3.2 it was still fine even after uploading the cnc web control but as soon as I put it in cnc mode to use the cnc web control I get the problem.
                                  dc42 administrators @kouta10
                                  One for @wilriker to look into.
                                  • wilrikerundefined
                                    wilriker @dc42
                                    @dc42 I'll check it out.
                                    And just as a side-note. With the 4-wire connection cable-length is less of an issue. I use around 2m unshielded, non-twisted 0.34mm² wiring. Works fine even at 115200 baud.
                                    EDIT: I cannot reproduce this. I tried with both a PanelDue 5i as well as PanelDue V3 4.3", with RRF 3.2 as well as 3.3 build from sources. No error messages at all.
                                    @kouta10 Can you please share some of these error messages. If you switch to the Console tab on PanelDue it should list them (at least the last ones) and you could take a photo.
                                    Manuel
                                    My Tool Collection
                                    • kouta10undefined
                                      kouta10 @wilriker
                                      @wilriker the error messages change too fast to make out a complete message. I have watched it for a small time to see if they are looping but couldn't pick up at what point they loop. They chang every .3 of a second. So it's to fast to read them.
                                      dc42undefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                                        @kouta10 said in Preview version of CNC optimized DWC.:
                                        Get someone else to hold down the Reset button of the Duet while you take a photo. Or temporarily comment out the M575 line in config.g that enables PanelDue support, then reset the board.
                                        • wilrikerundefined
                                          wilriker @kouta10
                                          @kouta10 You could also take short video clip.
                                          Manuel
                                          My Tool Collection
                                          • kouta10undefined
                                            kouta10 @dc42
                                            @dc42 sorry problem from my end, I put it back to printer mode and problem continued but strange because yesterday it seemed to fix the problem so I thought I will have a look at the terminal connector and found the problem with one of wires. Thanks for help
