    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.8k
    • chimaeraghundefined
      chimaeragh @Sindarius
      @sindarius OK. I think it worked differently on RRF2. Curious why it was changed but it's not too much of a problem.
      Jogging updates in real time though
      Duet 2 Wifi, Ooznest Workbee CNC 1510
        Phaedrux Moderator @chimaeragh
        @chimaeragh I'm not sure it was any different in RRF2 though.
        In RRF 3.3 you could try decreasing the segment size to make for smaller move lengths. That might let it update more frequently, but I'm not certain. See M669 S and T
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_Parameters_for_Cartesian_CoreXY_CoreXZ_CoreXYU_CoreXYUV_MarkForged_kinematics_RRF_2_03_and_later_only
        • Sindariusundefined
          Sindarius @chimaeragh
          @chimaeragh
          G91
          G1 H3 Z90 F500
          G90
          G1 X0 Y0 F6000
          G1 Z0
          I set this up on my test CNC machine and it worked fine for a go to zero macro. you can set the Z value greater than you z travel and it should stop when the limit is hit.
          chimaeraghundefined 1 Reply Last reply Reply Quote 1
            @sindarius Thanks
              chimaeragh
              @Sindarius @dc42 @raymondstone Has anybody been able to get power loss resume working with the latest release? Maybe a macro if not implemented in the UI itself? I'm able to run some very long jobs and I'm very nervous as utility power supply is not quite stable at the moment.
              chimaeraghundefined 1 Reply Last reply Reply Quote 0
                chimaeragh @chimaeragh
                @chimaeragh Found it. Simply sending M916 via console was the solution. Thanks everyone. Should always search the wiki before asking dumb questions 😅
                • bitminterundefined
                  bitminter @Sindarius
                  @sindarius any updates on the probe integration? That would be very helpful to say the least 🙂 thanks again for all your hard work!
                    chimaeragh
                    @bitminter There's a probe plugin available now here...
                    CNC Probe Plugin
                    bitminterundefined 1 Reply Last reply Reply Quote 0
                      bitminter @chimaeragh
                      @chimaeragh that is AWESOME!! Trying it out now! Thanks again!
                      • Shanian79undefined
                        Shanian79
                        1 year with the Duet3 running the CNC.undefined
                        JoergS5undefined 1 Reply Last reply Reply Quote 1
                        • JoergS5undefined
                          JoergS5 @Shanian79
                          This post is deleted!
