    Preview version of CNC optimized DWC.
    CNC
    40
    191
    21.8k
    • Sindariusundefined
      Sindarius @chimaeragh
      @chimaeragh No problem, I don't want anyone breaking bits on my watch 🙂 Blown up a couple carbide bits in my day!
      chimaeraghundefined 1 Reply Last reply Reply Quote 1
      • paulg4hundefined
        paulg4h @Sindarius
        @sindarius said in Preview version of CNC optimized DWC.:
        @paulg4h let me take a look but I imagine that should not be a problem.
        Many thanks again!
        With the latest Version 3.3.0-CNC07 the Temperature and Flow are now shown in DWC!
        • chimaeraghundefined
          chimaeragh @Sindarius
          @sindarius Tested today and everything works great 👍. Thanks a lot
          I had to modify my workzero.g file, I found my Z axis moving up and crashing whenever I used to Go to Zero.
          The offending line was
          G1 H1 Z1500 F2400
          before the X and Y axis movement.
          I replaced that line with
          M98 Phomez.g
          and it's working OK now.
          Duet 2 Wifi, Ooznest Workbee CNC 1510
          Sindariusundefined 2 Replies Last reply Reply Quote 1
            @chimaeragh I need to double check but you may want to try G0 H4 when you go to move to the top of the z axis. Worth a shot at the very least.
            https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
            chimaeraghundefined 1 Reply Last reply Reply Quote 0
              @sindarius I have tried that, but I seem to lose my current Z zero position so I've commented it out and gone back to calling homez.g which works fine
                chimaeragh @chimaeragh
                @Sindarius I have just noticed that tool position coordinates do not update in real time, but only after starting a new segment of gcode. Is this intentional or a bug?
                Sindariusundefined 1 Reply Last reply Reply Quote 0
                  @chimaeragh The position is how it is reported through the object model. What I normally see is tool position updates when the move starts and machine position updates after a move has completed. It's not a DWC-CNC specific behavior.
                    @sindarius OK. I think it worked differently on RRF2. Curious why it was changed but it's not too much of a problem.
                    Jogging updates in real time though
                      Phaedrux Moderator @chimaeragh
                      @chimaeragh I'm not sure it was any different in RRF2 though.
                      In RRF 3.3 you could try decreasing the segment size to make for smaller move lengths. That might let it update more frequently, but I'm not certain. See M669 S and T
                      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_Parameters_for_Cartesian_CoreXY_CoreXZ_CoreXYU_CoreXYUV_MarkForged_kinematics_RRF_2_03_and_later_only
                        @chimaeragh
                        G91
                        G1 H3 Z90 F500
                        G90
                        G1 X0 Y0 F6000
                        G1 Z0
                        I set this up on my test CNC machine and it worked fine for a go to zero macro. you can set the Z value greater than you z travel and it should stop when the limit is hit.
                          @sindarius Thanks
                            chimaeragh
                            @Sindarius @dc42 @raymondstone Has anybody been able to get power loss resume working with the latest release? Maybe a macro if not implemented in the UI itself? I'm able to run some very long jobs and I'm very nervous as utility power supply is not quite stable at the moment.
                              @chimaeragh Found it. Simply sending M916 via console was the solution. Thanks everyone. Should always search the wiki before asking dumb questions 😅
                              • bitminterundefined
                                bitminter @Sindarius
                                @sindarius any updates on the probe integration? That would be very helpful to say the least 🙂 thanks again for all your hard work!
                                  chimaeragh
                                  @bitminter There's a probe plugin available now here...
                                  CNC Probe Plugin
                                  bitminterundefined 1 Reply Last reply Reply Quote 0
                                    bitminter @chimaeragh
                                    @chimaeragh that is AWESOME!! Trying it out now! Thanks again!
                                    • Shanian79undefined
                                      Shanian79
                                      1 year with the Duet3 running the CNC.undefined
                                      JoergS5undefined 1 Reply Last reply Reply Quote 1
                                      • JoergS5undefined
                                        JoergS5 @Shanian79
                                        This post is deleted!
