    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.1k
    • chimaeraghundefined
      chimaeragh @rilot
      @edwardp Can you have a look at this macro and see if it works for your implementation?
      Duet 2 Wifi, Ooznest Workbee CNC 1510
      edwardpundefined 1 Reply Last reply Reply Quote 0
      • edwardpundefined
        edwardp @chimaeragh
        @chimaeragh thanks for posting those. I am just working through the simplest Z-only probe initially (@Kane on the other thread has a version of the macro that is now working for me). Once we have the Z probe working reliably (and I understand the subtleties of why my original macro was incorrect) I will use these to explore the tool diameter measurements.
        Cheers
        E
        • Hagridundefined
          Hagrid @rilot
          @rilot Thank you 🙂
            chimaeragh
            Hi. I just saw that this project has been updated to DWC 3.3 rc1. Glad to know it hasn't been abandoned. I'll be getting a Neje laser module to attach to my CNC soon and will be coming back to RRF3
            Sindariusundefined 1 Reply Last reply Reply Quote 2
            • Sindariusundefined
              Sindarius @chimaeragh
              @chimaeragh I promise it is not abandoned 🙂 I have a few other tasks which has taken up a bit of time. I plan on getting an XYZ probe plugin put in place when I am able to put some time into it. I have an OpenBuilds CNC with an XYZ touch probe that I want to get up and running as well.
              cjmundefined bitminterundefined 2 Replies Last reply Reply Quote 2
              • cjmundefined
                cjm @Sindarius
                @sindarius Not sure what I've done wrong, but I've just updated to 3.3.0-rc1 and the DRO and Jog plug ins appear to have disappeared?
                Sindariusundefined 1 Reply Last reply Reply Quote 0
                  Sindarius @cjm
                  @cjm I didn't include the plugins in this build. I need to post the DRO plugin and I'll update the Jog plugin which is normally available here https://github.com/Sindarius/DWC_Touch_Jog_Control
                  cjmundefined 1 Reply Last reply Reply Quote 2
                  • cjmundefined
                    cjm @Sindarius
                    @sindarius Many thanks for the quick answer!
                    Sindariusundefined 1 Reply Last reply Reply Quote 1
                      Sindarius @cjm
                      @cjm I found an issue where plugins were not starting properly with the previous version. There is a new release which resolves this issue.
                      https://github.com/Duet3D/DWC-CNC/releases/tag/CNC03-3.3.0-RC1%2B1
                      The updated plugins are available here
                      DRO
                      https://github.com/Sindarius/DWC_DRO_Plugin/releases/tag/0.2.0
                      Touch Jog Control
                      https://github.com/Sindarius/DWC_Touch_Jog_Control/releases/tag/0.2.0
                      chimaeraghundefined cjmundefined 2 Replies Last reply Reply Quote 1
                        chimaeragh @Sindarius
                        @sindarius second link is not working
                          @chimaeragh give it a shot now, I had to change the visibility of the repo.
                          chimaeraghundefined 1 Reply Last reply Reply Quote 0
                            @sindarius Thanks. Working now
                            • cjmundefined
                              cjm @Sindarius
                              @sindarius Thanks very much - all seems to be working now.
                              The updated jog plug-in looks good too!
                              weed2allundefined 1 Reply Last reply Reply Quote 1
                              • weed2allundefined
                                weed2all @cjm
                                @Sindarius I uploaded the touch jog and dro but it seems to get some sort of error when try to start them...I didn't had to much time into it but tomorrow I'll give it a new shot to see what's going on...I might need to do a fresh install of rrf and dwc as well...i will came back with news tomorrow...
                                https://www.thingiverse.com/weed2all/designs
                                  Sindarius @weed2all
                                  @weed2all let me know. I have tested them with latest DWC-CNC and latest firmware 3.3-RC2
                                  weed2allundefined 2 Replies Last reply Reply Quote 1
                                  • weed2allundefined
                                    weed2all @Sindarius
                                    @sindarius yes...it might shown the error because what I think is I'm still on the 3.2 firmware...not 100% sure...I'm at work now...in few hours when I get home I'll have time for testing again!
                                    • weed2allundefined
                                      weed2all @Sindarius
                                      @sindarius ok...now I have all working...just did an update from 3.2 to 3.3 rc2 and the dro plugin and touch plugin are starting now..
                                        Sindarius @weed2all
                                        @weed2all glad to hear it is working 👍
                                        • shanteundefined
                                          shante
                                          Hello, im trying to install the gamepad plugin, but im getting "Prerequisites
                                          Invalid plugin manifest " error. Can someone help me ? Thank you
                                          Im on
                                          Duet Web Control 3.3.0-rc1
                                          Board: Duet 3 MB6HC (MB6HC)
                                          DSF Version: 3.3-rc2
                                          Firmware: RepRapFirmware for Duet 3 MB6HC 3.3RC2 (2021-05-11)
                                            jay_s_uk
                                            @shante have you enabled the third party plugin service?
                                            https://forum.duet3d.com/topic/22054/firmware-bundle-3-3beta2-released/2
