    Glue
    3D Printing General Chat
    • Touchthebitumundefined
      Touchthebitum
      Hello
      I need to glue two flat 3d printed pieces :
      One PLA and another one Petg.
      Which glue may I have to use ?
      Thanks
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
        CA glue usually does the trick.
        Touchthebitumundefined 1 Reply Last reply Reply Quote 0
          Touchthebitum @Phaedrux
          @Phaedrux Thanks 😉
            Sometimes it helps to rough up the areas that will be in contact to give the glue something to extra adhere to.
              @Phaedrux Ok, I'll do that
