    Endstops unstable and EMERGENCY STOP NOT STOPPING EXT.BOARD ???
    593
    • jrocklandundefined
      jrockland
      As the title say, the endstop on expansion board just randomly stop working for no reasons, and the emergency stop (m112 AND m999) does NOT affect the extension board.
        jrockland
        I keep trying to do something with the boards I bought and really I can't find anything to do with those anymore. They should be advertise as unfinished product and sold as so we don't spend our money thinking we buy stable working product.
          Are you still running beta firmware on those boards?
          jrocklandundefined 3 Replies Last reply Reply Quote 0
            jrockland @dc42
            @dc42 im running the latest firmware available and check for update every week.
              jrockland
              Also endstops on extension board are ignored when homing after a print.
              -Yes endstops are connected on the same ext board as the related stepper motors.
                jrockland @dc42
                @dc42 Just realised when I do a M115, it say firmware_version 3.1.1 BUT Firmware_date 2020-05-19.b2. is it right ?
                  Can you post the results of M122 so we can see what boards you're talking about?
                  jrocklandundefined 2 Replies Last reply Reply Quote -1
                    jrockland @Phaedrux
                    @Phaedrux m122
                    RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                    Board ID: 08DJM-956L2-G43S4-6J1F8-3SD6T-9V56D
                    Used output buffers: 1 of 40 (16 max)
                    Static ram: 154604
                    Dynamic ram: 163276 of which 60 recycled
                    Exception stack ram used: 224
                    Never used ram: 75052
                    Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3408) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
                    Owned mutexes:
                    Last reset 00:29:43 ago, cause: software
                    Last software reset at 2020-12-31 18:49, reason: User, spinning module LinuxInterface, available RAM 74620 bytes (slot 2)
                    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                    Error status: 0
                    MCU temperature: min 34.1, current 35.2, max 37.0
                    Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.0, current 12.0, max 12.2, under voltage events: 0
                    Driver 0: standstill, reads 1982, writes 14 timeouts 0, SG min/max 0/0
                    Driver 1: standstill, reads 1982, writes 14 timeouts 0, SG min/max 0/0
                    Driver 2: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
                    Driver 3: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
                    Driver 4: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
                    Driver 5: standstill, reads 1984, writes 14 timeouts 0, SG min/max 0/0
                    Date/time: 2020-12-31 20:31:34
                    Slowest loop: 6.29ms; fastest: 0.14ms
                    === Storage ===
                    Free file entries: 10
                    Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
                    === MainDDARing ===
                    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                    === AuxDDARing ===
                    Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                    Segments left: 0
                    Movement lock held by null
                    HTTP* is ready with "M122" in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon* is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 0.66ms; fastest: 0.01ms
                    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                    HTTP sessions: 0 of 8
                    • Ethernet -
                      State: disabled
                      Error counts: 0 0 0 0 0
                      === CAN ===
                      Messages sent 23204, longest wait 1ms for type 6018
                      === Linux interface ===
                      State: 0, failed transfers: 0
                      Last transfer: 16ms ago
                      RX/TX seq numbers: 45704/29677
                      SPI underruns 0, overruns 0
                      Number of disconnects: 0
                      Buffer RX/TX: 0/0-0
                      === Duet Control Server ===
                      Duet Control Server v3.1.1
                      Code buffer space: 4096
                      Configured SPI speed: 8000000 Hz
                      Full transfers per second: 33.53
                      jrockland @Phaedrux
                      @Phaedrux So I managed to get my expension board to actually update to the last version, and none of my 6hc. half is giving me duet3_sbciap_mb6hc.bin canot be find, other half doest update. (I have 3 machines running 6hc + exp)
                        jrockland @dc42
                        @dc42 your 3.2 cant be installed on any of my board. tried every way possible and it always fail.
                        I did a hard reset with bossa using the last firmware and now I have a dead machine. "DSC isnt started".
                        • oliofundefined
                          oliof
                          Sounds like your raspberry pi is not up and running
                          jrocklandundefined 1 Reply Last reply Reply Quote 0
                            jrockland @oliof
                            @oliof would be hard to do all those update since im working directly on it -_-"
                            I also connected it to my other board and it work so it is from the board 100%.
                            Most useless comment yet.
                              jrockland
                              Ill mark this one as "solved" for now as obviously it didnt update right, and start one about why I cant update ??
                              Multisaftundefined 1 Reply Last reply Reply Quote 0
                              • Multisaftundefined
                                Multisaft @jrockland
                                @jrockland I had the same problem therefor I installed 3.1.1 fw package on both, hc6 and on hc3. After this the update package 3.2 did properly updated both boards.
                                Maybe u need to do this also.
