    Z-Probe vs Toolboard question...
    • Chrissundefined
      Chriss
      Hi *,
      Happy new year to all of you!
      I use the mini5+ on my current build (ratrig v-cast IDEX), so it is clear that I miss 2 drivers. My idea is to connect a two toolbards (1LC), one board per tool. I think that this is the idea behind the toolboard. 🙂
      I have learned in the past that the endstop switch must be connected to the same board as the motors driving this axle. Is that still the case (FW 3.2)? I do not know how I can connect a bl-touch if it needs to be on the same board than? I think that it is clear that the driver on the toolboard will drive the extruder not the z steppers.
      I had in my mind that the limitation will be removed but I'm not sure any more about the version. I tried to find something at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md but without success.
      Cheers, Chriss
      • whopping pochardundefined
        whopping pochard
        Check out the roadmap post here for some related info: https://forum.duet3d.com/topic/20602/reprapfirmware-road-map-q1-2021
          The limitation is that an endstop switch on the main board cannot stop a motor on an expansion board. You can connect your BLTouch to a tool board, and it will be able to stop Z motors connected to the main board. The limitations are described here https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations.
          Are you aware that there will shortly be a 2-driver expansion daughter board for the Mini 5+? We expect to have them later this month.
          Chrissundefined 1 Reply Last reply Reply Quote 0
          • Chrissundefined
            Chriss @dc42
            @dc42 Thanks David, so my memories fooled me. 😉
            Yes, I saw that 2driver thing expansion, I'm not sure that this will be a better approach for me.
            I like the idea of "one board per tool". That simplifies the wiring a lot. On the other hand is the expansion board on the y rail I nice idea too.
            Anyway, the tool boards are hard to source her in Germany at the moment. So I will have so more time to decide anyway.
            Cheers, Chriss
              dc42 administrators @Chriss
              Yes, tool boards are excellent for direct-drive tools.
              @Chriss said in Z-Probe vs Toolboard question...:
              I just checked our three distributors in Germany and found https://www.dold-mechatronik.de/Duet-3-Toolboard-1LC_1.
              • Chrissundefined
                Chriss @dc42
                Thanks again. I was on there website yesterday and there webserver was not working. Good to see that they are back online. 🙂 I Ordered a pair of them plus two filament sensors, whatever.... sometimes it is better to stay at the original plan. 😉
