    System File Colours
    468
    • jmshepundefined
      jmshep
      Not really a problem but when system files are posted on the forum, many are in colour. Mine are all in B&W is there a reason for this?
      Duet 2 WiFi, DWC and firmware 3.2 RC2
      Thanks
        jay_s_uk @jmshep
        @jmshep this was as part of a change to RC2 due to issues with the mobile version.
        It's been raised here https://forum.duet3d.com/topic/20562/dwc-3-2rc2-files-display
        • jmshepundefined
          jmshep
          But I had this problem before I updated to 3.2 RC2. Is there a setting to allow file listing to be in colour after the apparent problem is fixed?
            jay_s_uk @jmshep
            @jmshep no. Its either activated in DWC or its not.
            What version was it not working on before?
            • jmshepundefined
              jmshep
              It has not worked on any previous versions, the one installed before 3.2 was 3.1.1
              jay_s_ukundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @jmshep
                @jmshep it wasn't a feature of 3.1.1
                It's only come in as part of 3.2 and at the moment, it's broken.
                • engikeneerundefined
                  engikeneer @jmshep
                  @jmshep DWC displays you config, homing, macro etc files in a basic text editor in your browser. Here's a screenshot of mine (using 'dark mode' in RRF 3.1.1):
                  When people post their code on the forum, then generally use the 'Code Snippet' tool in their posts. This one:
                  This is is what makes their code coloured/highlighted and pretty (and a lot easier to scroll through!):
                  ; generated by RepRapFirmware Configuration Tool v3.1.10 on Fri Dec 04 2020 18:18:23 GMT+0000 (Greenwich Mean Time)
                  G90                                                    ; send absolute coordinates...
                  M83                                                    ; ...but relative extruder moves
                  M550 P"Thor"                                           ; set printer name
                  M665 R105.6 L200 B85 H320                              ; Set delta radius, diagonal rod length, printable radius and homed height
                  M666 X0 Y0 Z0                                          ; put your endstop adjustments here, or let auto calibration find them
                  M552 S1                                                ; enable network
                  M586 P0 S1                                             ; enable HTTP
                  M586 P1 S0                                             ; disable FTP
                  M586 P2 S0                                             ; disable Telnet
                  M569 P0 S1                                             ; physical drive 0 goes forwards
                  M569 P1 S1                                             ; physical drive 1 goes forwards
                  M569 P2 S1                                             ; physical drive 2 goes forwards
                  M569 P3 S1                                             ; physical drive 3 goes forwards
                  M584 X0 Y1 Z2 E3                                       ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
                  M92 X160.00 Y160.00 Z160.00 E192                   ; set steps per mm
                  M566 X1200.00 Y1200.00 Z1200.00 E2000.00               ; set maximum instantaneous speed changes (mm/min)
                  M203 X18000.00 Y18000.00 Z18000.00 E4000.00            ; set maximum speeds (mm/min)
                  M201 X4000.00 Y4000.00 Z4000.00 E1500.00               ; set accelerations (mm/s^2)
                  M906 X1400 Y1400 Z1400 E1400 I30                       ; set motor currents (mA) and motor idle factor in per cent
                  i3 clone with a bunch of mods
                  • jmshepundefined
                    jmshep
                    Thank you both for your replies.
                    If understand correctly, the colour display has been disabled in DWC for touch devices (which I don't have).
                    The description of the 'Code Snippet' tool explains why I don't see my normal file listings in colour on my PC monitor
                    and I am not missing out on a feature.
                      jay_s_uk @jmshep
                      @jmshep the colour display in DWC is broken not disabled.
                      • jmshepundefined
                        jmshep
                        Just upgraded from 3.2RC to 3.2 and file listings are now in colour.
