    Smarteffector problems with 3.11 ( update from 2.04)
    1.3k
    • fragleundefined
      fragle
      i gave the 3.1.1 another try and solved nearly all problems , but with one i am stuck for hours ( ans a lot of noise). the smart effector can not be choosen in the reprap configurator.
      The old configuration for the smart effector was
      M558 P8 R0.4 F1200 ; Set Z probe type to switch and the dive height + speedFs
      G31 P100 X0 Y0 Z-0.100 ; Set Z probe trigger value, offset and trigger height
      557 R115 S20 ; Define mesh grid
      G29 S1 ; Load the heightmap
      This was working for version 2.04
      i have changed to
      M558 P5 C"zprobe.in+zprobe.mod" X0 Y0 Z0 H5 R0.4 F1200 T6000
      If i do an G32, the print crash heavily into the printing plate and i have to power off the maschine.
      Maybe anyone have an idea what to do ?
      Kind regards
      Chris
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @fragle
        @fragle
        does a g30 work? a g32 can fail if your height is incorrect.
        • Carloundefined
          Carlo
          @fragle said in Smarteffector problems with 3.11 ( update from 2.04):
          M558 P5 C"zprobe.in+zprobe.mod" X0 Y0 Z0 H35 R0.4 F1200 T6000
          try changing the probe height higher as above
          • fragleundefined
            fragle
            G30 is working, the rods go down, hit the surface and go to +35mm Z
            The heigh settings should be correct, the complete system was running for nearly 16 months with the settings on 2.xx
            To change H35 has nothing changed on the behavior
            Carloundefined 1 Reply Last reply Reply Quote 0
            • Carloundefined
              Carlo @fragle
              @fragle
              M558 P5 C"zprobe.in+zprobe.mod" X0 Y0 Z0 Z- for an sm effector
              • Vetiundefined
                Veti
                home and manually check with G0 Z0 if the height is correct
                  jay_s_uk
                  This should be the valid entry in config.g for the smart effector
                  M558 P8 H4 F1000 T12000 R0.2 S0.02 A5 C"zprobe.in+zprobe.mod"
                  Run each line individually
                  G28
                  G30 X0 Y0
                  G32
                  M500
                  This will home the machine, probe the centre of the bed to determine 0, then run delta calibration and finally save the results.
                  Make sure you have M501 at the end of your config.g
                  • fragleundefined
                    fragle
                    @jay_s_uk said in Smarteffector problems with 3.11 ( update from 2.04):
                    G28 reports only an "Operation has been cancelled" error
                      jay_s_uk @fragle
                      @fragle sounds like you have homing issues then as M558 doesn't interact with homing (G28)
                      • fragleundefined
                        fragle
                        I have found the mistake, there is an optical endstop with some loose contact.
                        now it .
                        Changed to a news one , and your settings are working.
                        But now if i try to run a mesh compensation ( G29), the noozle drives down and then stay around 10mm over the heatplate and stops.
                        If i use the old additional Setting for the Z-probe, than the print head crashes into the Heatplate
                        31 P100 X0 Y0 Z-0.000 ; Set Z probe trigger value, offset and trigger height
                        M557 R150 S20 ; Define mesh grid
                          jay_s_uk @fragle
                          @fragle can you post your current complete config please. Which delta is it as well?
                          • fragleundefined
                            fragle
                            It is a Anycubic Predator with a smart effector and default rods
                            ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
                            G90                                         				; Send absolute coordinates...
                            M83                                         				; ...but relative extruder moves
                            ; Delta Settings
                            M665 L440.000 R227 H430.0 B185.0 						 	; Set delta radius, diagonal rod length, printable radius and homed height
                            M666 X0 Y0 Z0 A0.00 B0.00               			     	; Put your endstop adjustments here, or let auto calibration find them
                            M550 P"Anycubic Predator"                     				; Set machine name
                            M551 P""                         							; Set password
                            M552 S1
                            M552 P192.168.178.10  	                        				; Enable network and acquire dynamic address via DHCP
                            M553 P255.255.255.0
                            M554 P192.168.178.1
                            M586 P0 S1                                  				; Enable HTTP
                            M586 P1 S0                                  				; Disable FTP
                            M586 P2 S0                                  				; Disable Telnet
                            M569 P0 S0                                  				; Drive 0 goes forwards
                            M569 P1 S0                                  				; Drive 1 goes forwards
                            M569 P2 S0                                  				; Drive 2 goes forwards
                            M569 P3 S0                                  				; Drive 3 goes forwards
                            M350 X32 Y32 Z32 E16 I1                     				; Configure microstepping with interpolation
                            M92 X160.00 Y160.00 Z160.00 E415.00             				; Set steps per mm
                            M566 X1000 Y1000 Z1000 E1000    	            			; Set maximum instantaneous speed changes (mm/min)
                            M203 X12000.00 Y12000.00 Z12000.00 E10000 					; Set maximum speeds (mm/min)
                            M201 X3000.00 Y3000.00 Z3000.00 E3000.00    				; Set accelerations (mm/s^2)
                            M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 				; Set motor currents (mA) and motor idle factor in per cent
                            ;M666 X3 Y0 Z0
                            M84 S45                                     				; Set idle timeout
                            ; Retraction
                            M207 S4.0 F5000 R-0.025 T2500 Z0.5							; Firmware retraction
                            M208 Z0 S1                                  				; Set minimum Z
                            M574 X1 S1 P"xstop"   ; X min active high endstop switch
                            M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
                            M574 Z1 S1 P"zstop"   ; Z min active high endstop switch
                            M574 U2 S1 P"e0stop"  ; U max active high endstop switch
                            G31 P100 X0 Y0 Z-0.000                      					; Set Z probe trigger value, offset and trigger height
                            M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
                            M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor
                            M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                            M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                            M140 H0 ; the bed heater is heater 0
                            M143 H0 S130								; Set temperature limit for heater 0 to 120C
                            M143 H1 S280								; Set temperature limit for heater 1 to 280C
                            M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                            ;M106 P0 S0 I0 F100 H-1 C"Print Cooling"     ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                            ;M106 P1 S1 I0 F100 H1 T45 C"Heatsink"       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M563 P0 D0 H1                               				; Define tool 0
                            G10 P0 X0 Y0 Z0                             				; Set tool 0 axis offsets
                            G10 P0 R0 S0                                				; Set initial tool 0 active and standby temperatures to 0C
                            M572 D0 S0.1												; Pressure Advance
                            ;M591 D0 P2 C4 S1											; Activate filament sensor
                            M404 N1.75 													; Set for print monitor
                            M592 D0 A0.07772 B-0.00029 									; Nonlinear extrusion. Set parameters for extruder drive 0
                            M501                                               			; Load saved parameters from non-volatile memory
                            Phaedruxundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @fragle
                              G29 S1
                              Don't load the heightmap in config.g. It should only ever be loaded or freshly created after probing the bed with G30 to set Z0.
                              What do you have in bed.g and homedelta.g?
                              • fragleundefined
                                fragle
                                bed.g
                                ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                ; 16 points, 6 factors, probing radius: 160, probe offset (0, 0)
                                G28
                                G30 P0 X0.00 Y160.00 Z-99999 H0
                                G30 P1 X102.85 Y122.57 Z-99999 H0
                                G30 P2 X157.57 Y27.78 Z-99999 H0
                                G30 P3 X138.56 Y-80.00 Z-99999 H0
                                G30 P4 X54.72 Y-150.35 Z-99999 H0
                                G30 P5 X-54.72 Y-150.35 Z-99999 H0
                                G30 P6 X-138.56 Y-80.00 Z-99999 H0
                                G30 P7 X-157.57 Y27.78 Z-99999 H0
                                G30 P8 X-102.85 Y122.57 Z-99999 H0
                                G30 P9 X0.00 Y80.00 Z-99999 H0
                                G30 P10 X69.28 Y40.00 Z-99999 H0
                                G30 P11 X69.28 Y-40.00 Z-99999 H0
                                G30 P12 X0.00 Y-80.00 Z-99999 H0
                                G30 P13 X-69.28 Y-40.00 Z-99999 H0
                                G30 P14 X-69.28 Y40.00 Z-99999 H0
                                G30 P15 X0 Y0 Z-99999 S6
                                homedelta.g
                                ; homedelta.g
                                G91                        ; relative positioning
                                G1 H1 X470 Y470 Z470 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                                G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                                G90                        ; absolute positioning
                                  jay_s_uk @fragle
                                  @fragle ok
                                  Few issues I can see if your config.
                                  M350 only supports Interpolation of microsteps at x16, so I suggest you change back to x16 and the steps per mm to 80.
                                  Secondly, your endstop settings are incorrect. You have them set as being on the low end when infact they are on the high end. The correct settings are
                                  M574 X2 S1 P"xstop"
                                  M574 Y2 S1 P"ystop"
                                  M574 Z2 S1 P"zstop"
                                  Your G31 should have z set as -0.1
                                  Here is my predator config for reference https://github.com/jaysuk/Anycubic-Predator-Duet/tree/SmartEffectorRRF3
                                    jay_s_uk @fragle
                                    @fragle your homing file is also incorrect as it doesn't move the towers down before trying to home again.
                                    This is what it should contain.
                                    G1 X-5 Y-5 Z-5 F1800 H2    ; go down a few mm
                                    G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
                                    G1 X0 Y0 F6000             ; move X+Y to the centre
                                    • fragleundefined
                                      fragle
                                      I ve adaped my config to your settings, now G32 is working well, but with the mesh compensation i am getting an G29 error Z probe readings are not consistent
                                      At G29 the printhead goes down correctly, make some soft touches to the print plate and after around 4 or 5 point he stand still.
                                      M557 set mesh parameter said 175 radius and 16 spacing
                                      • fragleundefined
                                        fragle
                                        oh i forgot, i have an whambam printplate over the normal print plate
                                          Might need sensitivity adjusted for the smart effector? Higher probe speed?
                                            jay_s_uk @fragle
                                            @fragle you've probably got play in your system with the default arms. Try increasing the S value on M558 to something like 0.05
