    [Video] Adding a USB Webcam to DWC with a Raspberry Pi
    Third-party software
    1.6k
    • PCRundefined
      PCR
      https://www.youtube.com/watch?v=JZkytb3yGp0
      Works with USB Cameras. Its not tested with Pi Cams.
        Thanks for that.
        • stuartofmtundefined
          stuartofmt
          I've tried a few different packages that present the Pi camera as a web cam. The simplest I have found (and one I currently use) is here:
          http://picamera.readthedocs.io/en/latest/recipes2.html#web-streaming
          I have used it in the past with DWC but do not normally. I use it daily as a web cam for general monitoring of my printer http://<ip address:port> and as a feed to timelapse software.
          Having said that I just tried with DWC. There does seem to be a problem with DWC in the version I have (1.23). It does not "like" the URL. It sometimes even adds irrelevant paths to the url for the camera. For example I put in http://<ip address:port> and it changes it to http://<ip address:port>/Job. So there may be an issue there - or I simply am not doing something right.
          EDIT: Solved the issue - entirely my error. Needs to be in an iframe
          Phaedruxundefined 1 Reply Last reply Reply Quote 1
            Phaedrux Moderator @stuartofmt
            @stuartofmt said in [Video] Adding a USB Webcam to DWC with a Raspberry Pi:
            That's a quite old version of DWC now as well. Things are a bit different in DWC3.x
            stuartofmtundefined 1 Reply Last reply Reply Quote 0
              stuartofmt @Phaedrux
              @Phaedrux
              Sorry - I have DWiFi Server 1.23 and DWC 3.1.1 -- looked but didn't look 😞
              • fractalengineerundefined
                fractalengineer
                brilliant, thank you. I never knew how to make it work but that step by step guide is of great help.
                I seem to be stuck halfway though; I installed snapd and mjpg streamer and everything seems to be running well (see the snapd process)
                pi@duet3:~ $ ps -A
                  PID TTY          TIME CMD
                    1 ?        00:00:06 systemd
                    2 ?        00:00:00 kthreadd
                    3 ?        00:00:00 rcu_gp
                    4 ?        00:00:00 rcu_par_gp
                    7 ?        00:00:00 kworker/u8:0-events_unbound
                    8 ?        00:00:00 mm_percpu_wq
                    9 ?        00:00:00 ksoftirqd/0
                   10 ?        00:00:00 rcu_sched
                   11 ?        00:00:00 migration/0
                   12 ?        00:00:00 cpuhp/0
                   13 ?        00:00:00 cpuhp/1
                   14 ?        00:00:00 migration/1
                   15 ?        00:00:00 ksoftirqd/1
                   18 ?        00:00:00 cpuhp/2
                   19 ?        00:00:00 migration/2
                   20 ?        00:00:00 ksoftirqd/2
                   23 ?        00:00:00 cpuhp/3
                   24 ?        00:00:00 migration/3
                   25 ?        00:00:00 ksoftirqd/3
                   28 ?        00:00:00 kdevtmpfs
                   29 ?        00:00:00 netns
                   30 ?        00:00:00 kworker/0:1-events
                   32 ?        00:00:00 kauditd
                   33 ?        00:00:00 khungtaskd
                   34 ?        00:00:00 oom_reaper
                   35 ?        00:00:00 writeback
                   36 ?        00:00:00 kcompactd0
                   54 ?        00:00:00 kblockd
                   55 ?        00:00:00 blkcg_punt_bio
                   56 ?        00:00:00 watchdogd
                   58 ?        00:00:00 rpciod
                   59 ?        00:00:00 kworker/u9:0-hci0
                   60 ?        00:00:00 xprtiod
                   61 ?        00:00:00 kswapd0
                   62 ?        00:00:00 nfsiod
                   64 ?        00:00:00 iscsi_eh
                   65 ?        00:00:00 dwc_otg
                   66 ?        00:00:00 DWC Notificatio
                   67 ?        00:00:00 kworker/1:2-events
                   68 ?        00:00:00 vchiq-slot/0
                   69 ?        00:00:00 vchiq-recy/0
                   70 ?        00:00:00 vchiq-sync/0
                   71 ?        00:00:00 vchiq-keep/0
                   72 ?        00:00:00 SMIO
                   73 ?        00:00:00 kworker/1:3-events_freezable
                   74 ?        00:00:00 mmc_complete
                   75 ?        00:00:00 kworker/1:1H-kblockd
                   76 ?        00:00:00 kworker/0:1H-mmc_complete
                   77 ?        00:00:00 jbd2/mmcblk0p2-
                   78 ?        00:00:00 ext4-rsv-conver
                   79 ?        00:00:00 kworker/0:2H-kblockd
                   80 ?        00:00:00 ipv6_addrconf
                   84 ?        00:00:00 kworker/2:1H-kblockd
                   86 ?        00:00:00 kworker/3:1H-kblockd
                  101 ?        00:00:00 kworker/1:2H
                  102 ?        00:00:00 kworker/3:2H-kblockd
                  108 ?        00:00:00 irq/166-usb-001
                  111 ?        00:00:00 kworker/2:2H-kblockd
                  123 ?        00:00:03 systemd-journal
                  144 ?        00:00:01 kworker/u8:2-events_unbound
                  148 ?        00:00:01 systemd-udevd
                  149 ?        00:00:00 loop0
                  150 ?        00:00:00 loop1
                  172 ?        00:00:00 SMIO
                  179 ?        00:00:00 mmal-vchiq
                  180 ?        00:00:01 spi0
                  183 ?        00:00:00 mmal-vchiq
                  186 ?        00:00:00 mmal-vchiq
                  189 ?        00:00:00 mmal-vchiq
                  233 ?        00:00:00 cfg80211
                  241 ?        00:00:00 brcmf_wq/mmc1:0
                  244 ?        00:00:00 brcmf_wdog/mmc1
                  321 ?        00:00:00 systemd-timesyn
                  358 ?        00:00:00 cron
                  359 ?        00:00:00 rsyslogd
                  360 ?        00:00:00 dbus-daemon
                  362 ?        00:01:25 DuetControlServ
                  363 ?        00:00:00 thd
                  366 ?        00:00:00 wpa_supplicant
                  368 ?        00:00:00 rngd
                  373 ?        00:00:00 avahi-daemon
                  374 ?        00:00:00 alsactl
                  377 ?        00:00:00 systemd-logind
                  397 ?        00:00:02 snapd
                  425 ?        00:00:00 avahi-daemon
                  471 ?        00:00:00 wpa_supplicant
                  479 ?        00:00:00 kworker/3:4-events_power_efficient
                  534 ?        00:00:02 irq/167-dcs-trp
                  549 ?        00:00:00 kworker/2:2-events
                  553 ?        00:00:00 hciattach
                  555 ?        00:00:00 kworker/u9:1-hci0
                  557 ?        00:00:00 bluetoothd
                  558 ?        00:00:00 bluealsa
                  573 ?        00:00:00 krfcommd
                  628 ?        00:00:00 dhcpcd
                  633 ?        00:00:21 DuetWebServer
                  645 tty1     00:00:00 agetty
                  654 ?        00:00:00 sshd
                  666 ?        00:00:00 sshd
                  795 ?        00:00:00 systemd
                  796 ?        00:00:00 (sd-pam)
                  810 ?        00:00:00 sshd
                  811 pts/0    00:00:00 bash
                  834 pts/0    00:00:00 sudo
                  835 pts/0    00:00:00 nano
                  984 ?        00:00:00 kworker/0:0-events
                  985 ?        00:00:00 kworker/3:1-cgroup_destroy
                  988 ?        00:00:00 kworker/2:0-mm_percpu_wq
                  994 ?        00:00:00 kworker/0:0H
                  995 ?        00:00:00 kworker/3:0H
                  996 ?        00:00:00 kworker/1:0-events
                 1005 ?        00:00:00 kworker/u8:1-events_unbound
                 1053 ?        00:00:00 kworker/3:0-events_power_efficient
                 1154 ?        00:00:00 kworker/0:2-events
                 1157 ?        00:00:00 kworker/2:1-events
                 1159 pts/0    00:00:00 ps
                mjpg is well installed
                pi@duet3:~ $ sudo snap install mjpg-streamer
                snap "mjpg-streamer" is already installed, see 'snap help refresh'
                And I've copied exactly the same config file as yours
                pi@duet3:~ $ sudo nano /var/snap/mjpg-streamer/current/config
                  GNU nano 3.2        /var/snap/mjpg-streamer/current/config
                INPUTOPTS="input_uvc.so -y -r 640x480 -d /dev/video0"
                PORT="-p 8080"
                DAEMON="true"
                And yet when I enter my duet IP :8080, I get no response.
                Any hint on what could be the issue?
                Using a RPi 3B+ on Duet3
                Thanks!
                Railcore II ZL
                • PCRundefined
                  PCR
                  Which USB Camera are you using?
                  fractalengineerundefined 1 Reply Last reply Reply Quote 0
                    fractalengineer @PCR
                    @PCR well I'm not; I got a raspi cam.
                    My first attempt was with the line INPUTOPTS="input_raspi.so" as described in the guide but that didn't work out either.
                    I thought I would try with your config that seemed to be working as it seems the issue is with the interface not loading; I would assume if the camera was setup wrong the GUI would still load, just show no image.
                    Railcore II ZL
                    • PCRundefined
                      PCR
                      Sorry. Raspi Cam is Not working with the SNAP. Interface will only be loade when camera is working.
                      I saw on github a new plugin for raspi cams for DWC
                      Best
                      • PCRundefined
                        PCR
                        @fractalengineer
                        use this
                        https://desertbot.io/blog/how-to-stream-the-picamera
                        fractalengineerundefined 1 Reply Last reply Reply Quote 1
                          @PCR Thanks, I did manage to get it working just for a few moments before it froze and I can't get it to run again lol (the interface load, not the cam)
                          But I'll keep trying and keep you posted
                          Railcore II ZL
                          • gdefrancundefined
                            gdefranc
                            Installed on rasp pi3 with octoprint and activated on DWC with Logitech C270 webcam. It works.
                            Now I have to fix the Timelapse.
                            PCRundefined 1 Reply Last reply Reply Quote 0
                            • PCRundefined
                              PCR @gdefranc
                              @gdefranc with duetlapse easy. But use the snapshot Screen of Mjpg
                              • PCRundefined
                                PCR
                                And the DuetAPI from @jay_s_uk
                                • fmaundefined
                                  fma
                                  You can turn a Pi zero+ cam as a usb webcam, using https://github.com/showmewebcam/showmewebcam
                                  Frédéric
                                    I use a PizeroW with the Pi cam module and MotionOS to turn it into a webcam. It works very well with DWC and makes for a very small and very functional cam.
                                    https://github.com/ccrisan/motioneyeos/wiki
