    can't connect to DWC via different devices.
    Duet Web Control
    645
    • robh345undefined
      robh345
      when i try to connect to the DWC i get a connection time out error. this is on my laptop and smartphone. i can connect to it via my main pc (wired connection) and via the laptop op my parents. what could be the problem?
      i didn't had this problem in the beginning with my laptop. i did had it with my phone.
      diagnostics of my duet 2 wifi
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N85T0-6J9FG-3S86Q-KBSRN
      Used output buffers: 3 of 24 (22 max)
      Static ram: 23460
      Dynamic ram: 73476 of which 76 recycled
      Never used RAM 15068, free system stack 103 words
      Tasks: NETWORK(ready,169) HEAT(blocked,309) MAIN(running,456) IDLE(ready,19)
      Owned mutexes: WiFi(NETWORK)
      Last reset 01:25:47 ago, cause: software
      Last software reset details not available
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 25.2, current 28.8, max 29.4
      Supply voltage: min 23.6, current 23.8, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 21268, ok, SG min/max 0/250
      Driver 1: position -934, standstill, SG min/max 0/1023
      Driver 2: position 440, ok, SG min/max 0/1023
      Driver 3: position 0, ok, SG min/max 0/190
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-01-08 11:48:25
      Slowest loop: 71.98ms; fastest: 0.20ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 4.2ms, write time 1.0ms, max retries 0
      DMs created 83, maxWait 3660008ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 2783, completed moves 2780, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.5
      Heater 1 is on, I-accum = 0.6
      Segments left: 1
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X182.915 Y196.174 E529.0788" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 201.44ms; fastest: 0.10ms
      HTTP sessions: 2 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.25
      WiFi MAC address ec:fa:bc:5b:3c:72
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27000
      WiFi IP address 192.168.1.244
      WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      i had this problem with 3.1.1 and also with 3.2 (just updated to this).
      dbruce.ae05undefined 1 Reply Last reply Reply Quote 0
        Does your router isolate wired and wireless devices?
        robh345undefined 2 Replies Last reply Reply Quote 0
        • robh345undefined
          robh345 @Phaedrux
          This post is deleted!
          • robh345undefined
            robh345 @Phaedrux
            @Phaedrux as far as i know not, except for devices that are connected to wireless connection for quests but my laptop or 3d printer isn't connected to this. i have a netgear Nighthawk X4S. maybe there is something i overlooked in the settings that you can say that can cause the problem? when i try to ping the 3d printer from the devices that can't connect i get connection timed out. from the other devices i get a reply. i also could connect to it via a other laptop that is connected via wifi.
              Are you able to ping the IP?
              robh345undefined 1 Reply Last reply Reply Quote 0
              • robh345undefined
                robh345 @Phaedrux
                @Phaedrux via the pc that can get to DWC yes, via devices that can't connect to DWC not
                  Then you've definitely got a network isolation problem.
                  Are the ips even in the same subnet?
                  • robh345undefined
                    robh345 @Phaedrux
                    @Phaedrux yes, all devices are in the same subnet. i also have a raspberry pi and i can connect to that from all devices in my network. i can also do remote desktop to my other pc that can connect to the 3d printer.
                    • robh345undefined
                      robh345
                      i have removed the printer from the network and reconnected it. it looks like it is working now. i wil look if it stays working the comming days and let it know if it still works.
                        I wonder if the router tried to shunt the Duetwifi over to the 5Ghz network?
                        • robh345undefined
                          robh345 @Phaedrux
                          @Phaedrux in my router i have this option disabled, so i don't think this caused the problem.
                          also i haven't had any problems since i reconnected the printer with the network, thanks for your help.
                          • dbruce.ae05undefined
                            dbruce.ae05 @robh345
                            @robh345 same issue for me..
                            All devices on the same network. I can connect to DWC with iPad, iPhone, and until recently my laptop. Now, the raspberry pi connected to the Duet3 doesn't respond to pings from my laptop, but it does from other devices.
                              Phaedrux Moderator @dbruce.ae05
                              @dbruce-ae05 Best to start a new thread.
