    Duet 3 Hangs, Nema23 issues
    1.7k
    • JayTundefined
      JayT
      Dear @dc42 , Tony,
      I am using Duet 3 6HC which holds firmware version 3.0Beta12, Vs: 32V. I drive NEMA23 with it at 1A. The problems that I face are:
      1. The software/firmware hangs. This has happened 2-3 times; the only method to resume is to press 'STOP' on the panelDue. This causes complete reset of the firmware. even reset commands on console are not processed, when it hangs.
      Can upgrading to latest 3.2 version solve this problem? Is there a possibility of the firmware v3.0.beta12 to hang ?
      1. Also, If I give >1A current , the motor hangs. As Duet suggests, we can set up to 60-90%of rated current, but for this Motion King Nema23, I face this issue. Any suggestions?
        P.S. I tried using a lower torque, impedance motor, but found similar issue . It's very abrupt by nature.
        Yes it would be a good idea to update your firmware.
        Since you're on beta 12 you should follow these steps to ensure you can update correctly.
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWC
        JayTundefined 1 Reply Last reply Reply Quote 1
        • JayTundefined
          JayT
          This post is deleted!
          • JayTundefined
            JayT @Phaedrux
            @Phaedrux : Thanks. I was able to upgrade with YAT . I am still to check if updating firmware has any effect on drivers and software hang issue.
              Sending M115 should verify that you have firmware 3.2 now.
              Let us know if you're still having problems. If so, please post your config.g and the results of M122 and M98 P"config.g"
              • JayTundefined
                JayT
                @Phaedrux : M115 I ran after upgrading that confirmed version. -> so firmware upgrade resolved.
                I tried a print at the same speed where earlier software hang was observed (45mm/s @75mm/s2) . Print test worked fine this time. But usually motor was skipping steps at this speed after printing certain layers with old version of firmware. I shall do more testing before describing motor issue further.
                  @Phaedrux said in Duet 3 Hangs, Nema23 issues:
                  These details would be a good start.
                  Also, see this thread on the 3.3 early beta to test some fixes for canbus issues causing some motor issues. May or may not be related to yours.
                  https://forum.duet3d.com/topic/20991/early-rrf-3-3beta-files-available/
                  • JayTundefined
                    JayT
                    @Phaedrux : Thanks to notify on that. I plan to connect to 1XD to use a servo, may be then this info. shall come handy.
                    This issue on motors is without using 1XD. The MB6HC drivers is what I have been referring to . I have read through the Back emf+ rotational back emf information from dc42 and trying to figure out if that is what is causing skipping. strangely I was not able to set upto 60%of rated 3A current of NEMA23 . Even that was causing jamming of motors/skipping. So after firmware upgrade, I will do all tests and post details on this NEMA23 issue
                    (discussion might help people someone with NEMA23 ).
                    • Vetiundefined
                      Veti
                      can you post the specs of the nema23 motors?
                      • deckingmanundefined
                        deckingman @JayT
                        @JayT For info, 3 of the 13 motors on my machine are Nema 23s which I run at 2.8Amps. Two of them are connected to the main board, one is connected to an expansion board. None of them give me any trouble. Suggest you post the information that others have repeatedly asked you to supply.
                        • JayTundefined
                          JayT
                          As mentioned, I will be posting the exact issue soon , after gathering more details with v3.2 RepRap, forum suggestions & to answer other questions
                          @Phaedrux : M122 with beta version didn't return any faults when the motor indeed skipped earlier (before upgrade). Also I am using only 1 config.
                          M92 X800 Y800 Z800.00 E420.00 ; set steps per mm
                          M566 X180.00 Y180.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X3000.00 Y3000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X75.00 Y75.00 Z55.00 E250.00 ; set accelerations (mm/s^2)
                          M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          And as per the emf calculator, for my configuration, there are chances for skipping at 20 mm/s.
                          @Veti : its 23H2A2430. Also tried 23H2A8425 (for 1 of the axis)
                          @deckingman : Even I am able to drive all motors. the point is about running at certain Vs and Accelerations and current values without skipping/jamming. As I said, the print that failed with old firmware version, passed after upgrade to v3.2. I will post the exact problem soon with values of M122 if it saves any fault.
                          • Vetiundefined
                            Veti
                            @JayT said in Duet 3 Hangs, Nema23 issues:
                            that a very high step/mm setting.
                            are you using any gear reduction?
                            • JayTundefined
                              JayT
                              No, gear reduction not used.
                              • Vetiundefined
                                Veti
                                ok why are the step/mm so high then?
                                JayTundefined 1 Reply Last reply Reply Quote 0
                                • JayTundefined
                                  JayT @Veti
                                  @Veti : Using 1/16 microstepping with 4mmpitch.
                                  As per @T3P3Tony , we can set 60-90% of rated current. With this motor, if was setting current >1A for XY axis, even then the motors hanged or skipped. its a Motion King NEMA23. Did anyone face such a problem, that on increasing current from the drive, it hangs the motor? Any method to evaluate current to set for an axis?
                                  Vetiundefined 1 Reply Last reply Reply Quote 0
                                  • Vetiundefined
                                    Veti @JayT
                                    so its a leadscrew based system?
                                    • JayTundefined
                                      JayT @Phaedrux
                                      @Phaedrux, @T3P3Tony @dc42 : Hi, So I tried running motor with low impedance, with Duet 3 onboard drivers and could go only upto speed of 40mm/s with acceleration of upto 100-150 on ballscrew system. Tried expansion board with external drivers on Nema23 (impedance 6.8mh as earlier) motor and it now prints upto 70mm/s with upto 100mm/s2. When the motor skips, and i run M122, it does not show any hiccups neither prints any errors related. M using panelDue (not DWC). I dont understand why M not able to run these motors with onboard drivers of Duet 3 with rated current of upto 4.3 RMS. My motor's rated current is 3A. Any suggestions? The reprap calculator also applies to external drivers used? (Cause I notice different behaviour)
                                      Also David, On running M122, there is a lot of information that scrolls through too quick. Any way to save it in a file?
                                      I am using RRF 3.3Beta version, after which stepper motors run more stable. with 3.2+ 1XD, i noticed more skipping
                                      • T3P3Tonyundefined
                                        T3P3Tony administrators
                                        If you connect using DWC then when you send M122 you will see the whole output.
                                        You mention being able to get higher speeds using external drivers. What drivers at what settings?
                                        70mm/s at 800 steps/mm is a step rate of 56KHz which should be ok on the 1XD running RRF 3.3 beta with the default timing of "fast". Its marginal with T=1 and too high step rate with T=2.5 or higher. This can be confirmed by sending
                                        M122 Bnnn
                                        where "nnn" is the address of the 1XD board. Send this once the print has been running for a while to confirm there are no hiccups.
                                        For the 6HC mainboard that step rate is not an issue unless you have a huge number of very tiny moves in the file, once again use M122 to report any issues on the mainboard.
                                        Please post your M122 output in full, config.g and an example gcode file.
                                        www.duet3d.com
                                        • JayTundefined
                                          JayT @T3P3Tony
                                          @T3P3Tony : Thanks Tony. I shall try that. For the current print, i saw hiccups as non zero(>100 value) for both the axis. What do hiccups mean ? What action can be taken to reduce hiccups?
                                          I will send config, M122 info and sample print by tomorrow.
                                            @JayT, you should be able to achieve the same speeds with the Duet internal drivers as with the external drivers if the driver VIN voltage, load, speed, acceleration etc. is the same in both cases. If the external drivers run at a higher VIN voltage than the Duet accepts (e.g. 48V), then they will support higher speeds than the Duet does.
                                            One possible difference is how the current is set. The M906 command in RRF sets the peak current. The switches on your external drivers may set RMS current - check the documentation for details. When microstepping, peak = 1.414 * rms.
