    Laser sensor calibration info
    Filament Monitor
    • Ladusse
      Ladusse last edited by
      Hi I just installed my laser sensor and I don't now what I should for the ''R" value. here is my result.
      Thanks
        Have you seen?
        https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion
        Ladusse 1 Reply Last reply Reply Quote 0
        • Ladusse
          Ladusse @Phaedrux last edited by
          @Phaedrux yes I seen it I don't understand the R value the minimum and maximum permitted measured movement as a percentage of commanded movement. As the example calibration reports 43% to 115% then you might choose R30:130.
          Why it choose R30:130 with the reports of 43% to 115%?
          • alankilian
            alankilian last edited by
            The R value says:
            STOP the print if the measured filament amount is less than 30% of the commanded filament amount.
            STOP the print if the measured filament amount is more than 130% of the commanded filament amount.
            Since the filament sensor is not completely accurate, you need to set a range of acceptable values or your print will stop on almost every single extrusion.
            What I did is to set the range large like R10:500 then I did a print and looked at the result values and saw a range of something like 85% to 115% so I set my range to R50:150.
            Ladusse 1 Reply Last reply Reply Quote 1
            • Ladusse
              Ladusse @alankilian last edited by
              @alankilian thanks for the explication it's now more clear.
