    Hotend heater showing 695
    45
    • mrenz999
      mrenz999 last edited by
      Duet 3 using RRF 3.2 RC2
      I replaced my heater cartridge and thermistor. Using the same brand as I was using before. My heater faults and shows 695 degrees.
      Relevant section of Config.g
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S300
      M307 H0 R0.276 C683.100:683.100 D0.20 S1.00 V24.1 B0
      M307 H1 A351.2 C120.5 D7.2 S1.0 V24.1 B0
        Are you sure it's the same as the one it's replacing?
        Does it show that temp right at power on when it's cold?
        3.2 final is available now by the way. https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        mrenz999 1 Reply Last reply Reply Quote 0
        • Veti
          Veti last edited by
          please measure the resistance of the thermistor.
          its possible you bought a pt100 rather than a b 3950
          mrenz999 1 Reply Last reply Reply Quote 1
          • mrenz999
            mrenz999 @Phaedrux last edited by
            @Phaedrux I will upgrade to the final. It shows the crazy temp at bootup. So right away with no heater on and then of course faults right away. It is the same as I was using before for sure. So not sure what happened. Unless they put a different one that looks the same in the same package. I have others and will swap it out tonight when I get home.
            • Veti
              Veti last edited by
              @mrenz999 said in Hotend heater showing 695:
              you really need to measure the resistance
              • mrenz999
                mrenz999 @Veti last edited by
                @Veti Will do that tonight when I get home. On a side note I changed the T to 10000 and it cut the temp showing to 255. So maybe you are right on that.
                • mrenz999
                  @Veti Not sure how to test it. I do have a multi meter. Do I disconnect it and test the 2 leads ?
                  Veti 1 Reply Last reply Reply Quote 0
                  • Veti
                    Veti @mrenz999 last edited by
                    @mrenz999
                    yes disconnect and measure the resistance
