macro executing if wanted after print ?
414
  • undefined
    joeko
    hallo,
    is it possible to create a macro that i can start manual when a print is running and will run after the print is finish ?
    for example after the fan is off shut down with M81.
    ? undefined 3 Replies Last reply 13 Jan 2021, 12:41 Reply Quote 0
      A Former User @joeko
      @joeko
      You might consider giving this a vote "up" if it would likely fit your needs:
      https://forum.duet3d.com/topic/20708/start-g-end-g?_=1610541552963
      • undefined
        DIY-O-Sphere @joeko
        @joeko said in macro executing if wanted after print ?:
        You don't need a macro for that
        Put "M81 S1" in the slicer end code......
        (UTC+1)
        undefined 1 Reply Last reply 13 Jan 2021, 13:20 Reply Quote 0
        • undefined
          fcwilt @DIY-O-Sphere
          @DIY-O-Sphere said in macro executing if wanted after print ?:
          Will that wait for the fan to stop running before it shuts off power?
          undefined 1 Reply Last reply 13 Jan 2021, 13:31 Reply Quote 0
            @joeko
            Or - In your case you might make a screen-message-request with M291 within stop.g that is called via "M0 command at the end of the print job"?
            • undefined
              Veti @fcwilt
              @fcwilt said in macro executing if wanted after print ?:
              yes
              Sn n=0 turn power off immediately (default), n=1 turn power off when all thermostatic fans have turned off (RepRapFirmware 1.20 and later only)
              • undefined
                joeko
                i use also a printer with repetier server.
                in repetier server there is a button and when i click on this button while a print is running a command will execute after the print is finished and this command is m81 s1 or what i set in this command.
                i can set rules what happen after a print.
                when i set m81 s1 in the slicer this will run after every print but i would like do this only if i want.
                • undefined
                  https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Job_Control
                  Enable auto-sleep may be what you want?
                  The print control section has a check box to "Enable Auto-Sleep". If this is selected then the M1 G-Code is sent at the end of the print which runs the "sleep.g" macro file. This for example would allow the shutting down of the main power supply once the print has completed (assuming the printer hardware is set up to allow this).
                  undefined 1 Reply Last reply 13 Jan 2021, 21:08 Reply Quote 0
                  • undefined
                    joeko @Phaedrux
                    @Phaedrux said in macro executing if wanted after print ?:
                    yes it seems that is what i am looking for 🙂
                    perfect and thank you 🙂
                    • undefined
                      joeko
                      hmm,
                      doesnt work.
                      do i have to open the browser ? after closeing the browser and open again the auto-sleep is disable again.
                      undefined 1 Reply Last reply 14 Jan 2021, 17:05 Reply Quote 0
                      • undefined
                        appjaws
                        I have a macro for auto shutdown which you could call from an entry in the end section of your slicer:-
                        M98 P"0:/macros/extra/Auto Shutdown
                        this is my macro:-
                        "M291 P"Shutdown Started" R"Shutdown" S1 T0; Display message
                        M98 P"0:/macros/extra/Set LED Red"
                        M140 S0 ; turn off bed heater
                        M104 S0 ; turn off extruder heater
                        if move.axes[0].homed || move.axes[1].homed || move.axes[3].homed || move.axes[4].homed
                        G91 ; relative mode
                        G1 Z5 F2000 ; move bed down 5mm
                        G90 ; absolute mode
                        G1 Y228 V228 X118 U118 F3000 ; Park position
                        else M291 P"ERROR - Drives not homed, Please shutdown manually" R"Shutdown" S1 T0; Display message
                        break
                        while heat.heaters[1].current > 42
                        M98 P"0:/macros/extra/Set LED Green"
                        M291 P{"Waiting for nozzle to reduce to 42C, Extruder temperature = " ^ floor(heat.heaters[1].current + 0.5)}
                        M106 P0 S255 ;set cooling fan to maximum
                        G4 S5 ;Wait for 5 second
                        M106 P0 S0 ;set cooling fan to zero
                        M106 P3 S0
                        M106 P4 S0
                        M106 P5 S0
                        M291 P"Shutdown Completed" R"Shutdown"; Display message
                        you could put everything you need to happen in this macro but keep the section
                        Hope that helps
                        appjaws - Core XYUV Duet Ethernet Duex5
                        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                        Ormerod 1-converted to laser engraver, Duet wifi
                        OpenSCAD version 2024.03.18
                        Simplify3D 5.1.2
                        • undefined
                          Phaedrux Moderator @joeko
                          hmm,
                          doesnt work.
                          It may very well be one of the few features that depends on DWC being open. Another I can think of is the fan speed override lock.
                          • undefined
                            joeko
                            ok, maybe a option in future firmware
                            7 out of 13
