    SOLVED Set current to zero?
    155
    • tenaja
      tenaja last edited by tenaja
      Is there a way to set the current to zero? The "idle current" command says it has a minimum of 100mA, and I would like to set it to zero so it can free-wheel.
      Thanks!
      garyd9 1 Reply Last reply Reply Quote 0
      • tenaja
        tenaja @Veti last edited by tenaja
        @Veti said in Set current to zero?:
        G92
        I did that, from the command line (top of DWC web page), and it did not work.
        Perhaps G92 after a M913?
        coming back after Duet restart (because it always loses connection)
        Yes!
        M913 Y100 does not turn power back on... It's still freewheeling after that....but the commands do work. (M913 then G92)
        Thanks, I'm back in business!
        Veti tenaja dc42 3 Replies Last reply Reply Quote 0
        • garyd9
          garyd9 @tenaja last edited by garyd9
          @tenaja
          Some more context might be useful. For example, I'm taking a guess that you're referring to M906 as the "idle current command", but I'm not entirely sure.
          If you ARE referring to M906, please note the footnote to the "I" ("eye", not "el") parameter. I've added emphasis to the part that seems to relate to your query:
          This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off. The default value is 30% and will always be at least 100mA - starting from RRF 2.02 setting it to 0 will disable the steppers after timeout like M18|M84 do and if an axis is related to the motor, throw out the "homing" of it, since it is likely that the position cannot be precisely determined anymore. Note that the idle current is applied globally for all motors and cannot be set per axis.
          Source: https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
          "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
          tenaja 1 Reply Last reply Reply Quote 0
          • fcwilt
            fcwilt last edited by
            As I recall you can turn individual stepper drivers off with M84.
            • tenaja
              tenaja @garyd9 last edited by
              @garyd9 , Yes, that is what I meant. This is not an axis that is "homed"--it is rotary, which needs to freewheel at times. So, how do I do that? I'm getting a "axis not homed" error or something like that.
              Should I just issue a G92 to set it to zero right before I turn it back on?
              Thanks again!
              • tenaja
                tenaja @fcwilt last edited by tenaja
                @fcwilt said in Set current to zero?:
                That did it, now I need to figure out how to "home" an axis that is not homed, and can not be homed.
                Veti 1 Reply Last reply Reply Quote 0
                • Veti
                  Veti @tenaja last edited by
                  @tenaja said in Set current to zero?:
                  use G92 to set a position
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position
                  • tenaja
                    G92
                    Yes!
                    • Veti
                      whats the exact G92 command you issued?
                      • tenaja
                        tenaja @tenaja last edited by
                        I guess the only question left is how you cancel an M84 (Stop Idle Hold), without issuing a move command? Or to put it another way, how do you Resume Idle Hold?
                        fcwilt 1 Reply Last reply Reply Quote 0
                        • tenaja
                          G92 Y0
                          • fcwilt
                            fcwilt @tenaja last edited by
                            What is the letter assigned to this axis and what G92 command did you issue?
                            Issuing a G1 command for that axis should turn the driver back on - is there some reason you cannot do that?
                            • Veti
                              Veti last edited by
                              I just tested it and the axis became homed
                              • tenaja
                                @Veti
                                Thanks, as I pointed out in Post #8, it does work if you put it in the gcode. But you have to do it in sequence, with the M913 first.
                                And, the motor does not have power, even though you issued an M913 Y100. ("Set motor percentage of normal current", to 100%)
                                • Veti
                                  @tenaja
                                  try a small movement G0 Y0.1 followed by G0 Y0
                                  • tenaja
                                    @tenaja
                                    As expected, that will do it. It seems odd there's a way to power-down a motor, but not a "safe" way to power it back up. ("Safe" = no-motion).
                                    I would like to know how to restore it safely, for trivial/future reasons, but for my current application, my needs are met.
                                    I really appreciate all of the help provided.
                                      dc42 administrators @tenaja last edited by
                                      Any movement command will turn it back on. RRF 3.3 (for which we will soon release a beta) also supports M17 to turn on motor current.
                                      oozeBot tenaja 2 Replies Last reply Reply Quote 0
                                      • oozeBot
                                        oozeBot @dc42 last edited by
                                        @dc42 said in Set current to zero?:
                                        I'm very interested in testing this as I believe it will really help when releasing the stepper brake on our z-axis.. currently, we have to slightly move the z-axis to energize the steppers to keep the gantry from dropping.
                                        • tenaja
                                          tenaja @dc42 last edited by
                                          Thanks...
                                          Will a "relative" move of zero, like G1 Y0 do it? Or is physical motion the only way to get power back on?
                                            If you work out your step resolution you could have a move of exactly a single motor step.
                                              dc42 administrators @oozeBot last edited by
                                              @oozeBot said in Set current to zero?:
                                              I expect to provide an unofficial 3.3beta tomorrow.
