ToolBoard 1LC noob questions...
Hi *,
I got my two toolboards 1LC today. Nice peace of engineering, they are small and nice and have cool connectors on it! I like the green screw terminals, they are much better for me and my crimping skills than the usual connectors.
I have a stupid questions now and I want to ask them before I bring up the holy smoke.
Am I right that I can use GND from OUT_1 and OUT_2 to control two 24V Fans connected plus to 24V? (Like the 12Vbug trick for fan control on the mainboard.)
Cheers, Chriss
@Chriss said in ToolBoard 1LC noob questions...:
Yes. Alternatively, it's safe on the tool board to add a wire on the back to connect the +12V external output (as found on the two OUT connectors) to +VIN, because external +12V is diode-isolated from internal +12V. The next version of the tool board will include a jumper to do this.
The reason we went for 12V fans is that fans with tachos and fans with separate PWM control are much easier to get in 12V.
@dc42 said in ToolBoard 1LC noob questions...:
Thanks for your fast reply David!
This is a good idea with the wire, that makes sure that I will brick a fan in the future because the docu says 12V and I modded it to 24V and forget the wire.The next version of the tool board will include a jumper to do this.
THAT is indeed a very, very good idea.
24V is more than common nowadays in this industry.
Yes, you are right, I did not sought about the final setup, I bought some fans and it was obvious for me to source 24V because of the power supply. At the end is it my bad that I did not went though the docu first.
And for the next version: Could you please consider to get rid of that JST-ZH connectors? It is nearly impossible to get connectors to crimp and pliers for them. The screw terminal are much much better here. And I hate it to solder a wire with a connector to a fan. That looks like somebody have extended a wire which was cut to short.
Cheers, Chriss
This is good news!
When this question comes up in our Discord server I keep saying it is not possible based on your response here: https://forum.duet3d.com/post/160986
The last person with a Toolboard before @Chriss's arrival asked the question, which I responded not possible, but Chriss did not ask and good thing he didn't!I was unaware of the same discussion in this thread: https://forum.duet3d.com/post/166630
PS: You did not respond with the test results which might put some people offDavid, do you want me to add some text to the wiki?
