    How to add translation code(scpecific screen communication) ?
    Firmware developers
    592
    • pavelsplavelundefined
      pavelsplavel
      How to add translation code to RepRap? I want to connect some screen. So when it receives instructions starting with 5AA5, it can translate those instructions into G-code language to identify. Then it will convert the content that needs to be fed back to the screen into the instructions starting with 5AA5, and send it to the screen for communication interaction.
        Please provide a link to the technical details of the screen that you want to connect.
        • alankilianundefined
          alankilian
          Maybe it has something to do with this?
          http://www.dwin.com.cn/home/english/news_detail.html?nId=1181
            pavelsplavel
            @alankilian You right! I want to connect DWIN screen
            @dc42 DWIN communication protocol and address to drive the serial port:
            5A A5 04 82 1000 01 (5A A5 is the framehead, 04 is the datalength, 82 means read, 1000 means VP address (shall be same as your photo), 01 is the data.
            What is the Duet 2 wifi communication protocol and address which drives the serial port?
              pavelsplavel
              @dc42 here is the link:
              https://drive.google.com/file/d/1fhcOW1s-67v5Vx8_pmW1Grp9FbZ7RrR2/view
              • wilrikerundefined
                wilriker @pavelsplavel
                @pavelsplavel So as of now RepRapFirmware uses a plain-text communication on the serial port. It expects to receive GCodes and sends out whatever the result is - when communicating with a PanelDue this will always be JSON.
                Unfortunately the document you linked in Google Drive is access restricted and I cannot view it. The page linked by @alankilian only gives a coarse overview.
                So from this sparse information you either need to adjust DWINOS to deal with the JSON that RepRapFirmware sends or you need to implement a driver that is able to talk the DWIN protocol in RepRapFirmware.
                Manuel
                My Tool Collection
                  pavelsplavel
                  Development Guide of T5L ASIC_20200624 .pdf
                  @wilriker So, i attached here
                  • wilrikerundefined
                    @pavelsplavel Unfortunately this document is not very helpful as it describes the processor and how it is programmed. I think instead you need to search and provide the documentation of the communication protocol you described above.
                    Manuel
                    My Tool Collection
                      pavelsplavel
                      @wilriker Soon i will upload here the documentation of the DWIN communication protocol.
                      By the way DWIN asked me to get the documentation of the DUET communication protocol. Does somebody can give it to me ?
                      • T3P3Tonyundefined
                        T3P3Tony administrators @wilriker
                        @pavelsplavel I think it would be better to adapt the DWIN OS to communicate with RRF using the UART. @wilriker describes it here:
                        @wilriker said in How to add translation code(scpecific screen communication) ?:
                        So you send plain text GCODE command and parse the JSON response.
                        www.duet3d.com
                          pavelsplavel
                          @wilriker @T3P3Tony Okay. Thank you!
                            dc42 administrators @alankilian
                            @alankilian said in How to add translation code(scpecific screen communication) ?:
                            Malwarebytes thinks that page carries a trojan.
                              alankilian
                              @dc42 said in How to add translation code(scpecific screen communication) ?:
                              Bummer.
                              It comes out clean with other scanners, but.... Better safe than sorry.
                                pavelsplavel
                                Protocol communication_PNG.png @wilriker @dc42
                                Hey there!
                                Here is serial protocol communication of Dwin screen.![0_1612172004966_Protocol communication.jfif](Uploading 100%)
