G32 ERROR
5.4k
  • undefined
    moe.adams9093
    Re: Auto bed leveling
    Hello everyone I'm having problems when I send command G32 to perform true bed leveling. My build uses 4 motors NEMA 17 with worm gear box to drive Z axis. Z axis is belt driven with rod end bearing to eliminate resistance when I send G32 my DC 42 IR sensor it triggers the 4 corners but I get these Errors
    ( g32: Error: Some computed corrections exceed configured limit of 1.00mm: 9.056 -8.629 -10.350 8.226)
    config File
    Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
    M550 P"DIVINCI-3D (MP4560)" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P10 R1 T2:2:2:2 S1 ; physical drive 0 goes forwards
    M569 P11 R1 T2:2:2:2 S1 ; physical drive 1 goes forwards
    M569 P4 S1 ; physical drive 4 goes forwards
    M569 P5 S1 ; physical drive 5 goes Backwards
    M569 P6 S1 ; physical drive 6 goes Backwards
    M569 P8 S0 ; physical drive 7 goes Backwards
    M569 P9 S0 ; physical drive 9 goes backwards
    M584 X10 Y11 Z5:6:8:9 E3:4 ; set drive mapping
    M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 ; ZBelts Near Locations
    M350 X32 Y32 Z16 E16:16 I1 ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z410.00 E415.00:415.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
    M906 X1800 Y1800 Z1000 E500:500 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X460 Y460 Z460 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P1 C"zprobe.in" H25 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X20:440 Y20:440 S20 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
    M307 H0 A11 C99000 D2000 B1 ; enable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs1
    M308 S2 P"spi.cs2" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs2
    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950 ; configure sensor 3 as thermistor on pin duex.e2temp
    M950 H3 C"duex.e2heat" T3 ; create chamber heater output on duex.e2heat and map it to sensor 3
    M307 H3 A11 C99000 D2000 B1 ; enable bang-bang mode for the chamber heater and set PWM limit
    M141 H3 ; map chamber to heater 3
    M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on
    M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on
    M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
    M563 P0 S"MAIN EXTRUDER" D0 H1 F0 ; define tool 0
    M563 P1 S"SECOND EXTRUDER" D1 H2 F0 ; define tool 1
    G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
    T0 ; select first tool
    bed.g file
    ; bed.g
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 30 2020 23:57:44 GMT-0500 (Central Daylight Time)
    G30 P0 X5 Y25 Z-999999;
    G30 P1 X455 Y25 Z-999999;
    G30 P2 X455 Y455 Z-999999; probe near a leadscrew, half way along Y axis
    G30 P3 X5 Y455 Z-999999 S4; probe near a leadscrew and calibrate 2 motors
    Homeall.g
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H2 Z0 F6000 ; lift Z relative to current position
    G1 H1 X-465 F4000 ; move quickly to X endstop and stop there (first pass)
    G1 H1 Y-465 F4000 ; move quickly to Y endstop and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-465 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-465 F360 ; then move slowly to Y axis endstop
    G1 X235 Y235 F6000 ; Prob at Center
    M558 F600 A1 ; Dive fast once
    G30 ; probe Z
    M558 F100 A10 ; Slow second dive with more accuracy
    G30 ; probe z again
    please share your expertise and knowledge to help me over come this problem. Thank you
    • undefined
      Veti
      @moe-adams9093 said in G32 ERROR:
      M671
      see the S parameter
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
      • undefined
        moe.adams9093
        I looked over this document to understand M671 few times and I have changed the S parameters between 2 to -10 all of them gave out the same error. So I don't know what I need to change at this time. Correct me if I'm wrong does it mean the S parameters will allow to compensate the difference for example if my M671 X 25 : 455: 25:455 Y 25: 25:455:455 S-10 does that mean the bed 4 corners will adjust between 0 & -10.
        • undefined
          jay_s_uk
          The S value is the maximum adjustment that it will account for.
          If you set it to 5 and it comes out with a difference of 4, it will adjust. If it comes out at 6, it won;t be adjusted.
          I have mine typically set at 10 so any out of adjustment up to 10mm will be automatically adjusted.
          You shouldn't be setting S to a negative value
          fcwiltundefined 1 Reply Last reply 26 Jan 2021, 15:17 Reply Quote 0
          • undefined
            Veti
            you have a difference of 19.3 mm between the points
            • fcwiltundefined
              fcwilt @jay_s_uk
              @jay_s_uk said in G32 ERROR:
              Have you verified this by testing?
              When I read "Maximum correction to apply to each leadscrew in mm" I took it to mean it would make adjustments up to the S parameter value but no more.
              Thanks.
              undefined 1 Reply Last reply 26 Jan 2021, 15:23 Reply Quote 0
              • undefined
                moe.adams9093
                Thanks for the info. I will try to remove negative value and work alone the positive and see my results
                • undefined
                  jay_s_uk @fcwilt
                  @fcwilt yes.
                  As when I had an adjustment larger than the specified S value, no adjustment took place
                  fcwiltundefined 1 Reply Last reply 26 Jan 2021, 15:35 Reply Quote 0
                  • fcwiltundefined
                    fcwilt @jay_s_uk
                    @fcwilt yes.
                    Thanks.
                    @Phaedrux - would you check the docs for the S parameter of M671 and see if you think it is consistent with the observed behavior?
                    Thanks.
                    Phaedruxundefined 1 Reply Last reply 26 Jan 2021, 19:22 Reply Quote 0
                      Phaedrux Moderator @fcwilt
                      @fcwilt Yes the word "apply" would seem to indicate that something will be done.
                      Snn Maximum correction to apply to each leadscrew in mm
                      I'll change that to Maximum correction allowed for each leadscrew in mm. Which captures that corrections beyond that are not allowed.
                      • undefined
                        moe.adams9093
                        Thank you for your help I have figured out my S value needed to be at 6. Another problem im facing now when I home All I need my Z axis to travel to Zmax first and hit all 4 Endstops which they are correspond to each separate Driver then to travel up to the Zmin which will stop by the IR sensor and perform the probing sequence. So long story short I added to my configuration file
                        M574 Z2 S1 P" exp.e2stop+exp.e3stop+exp.e5stop+exp.e6stop"; and its not doing what it supposed to. Like when I hit home all the z axis won't move at all. I did change some code im my homeall.g where the Z will travel to 500 first then home x and y the can go back to -500 but its not working Correctly. Thanks in advance
                        fcwiltundefined 1 Reply Last reply 29 Jan 2021, 07:46 Reply Quote 0
                        • fcwiltundefined
                          fcwilt @moe.adams9093
                          Another problem im facing now when I home All...
                          Please post your current config.g and homeall.g files - using the </> tag.
                          • undefined
                            moe.adams9093
                            oh heres my latest files and configuration
                            config file
                            M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S6 ; ZBelts Near Locations
                            M574 Z2 S1 p"!exp.e2stop+exp.e3stop+exp.e5stop+exp.e6stop" ; Configure active- high endstops for high end on Z
                            ; homeall.g
                            G1 H1 Z500 F6000 ; lift Z relative to current position
                            G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
                            G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
                            G1 H2 Z-500 F6000;
                            G30 ; probe Z
                            M558 F300 A10 ; Slow second dive with more accuracy
                            G30 ; probe z again
                            • fcwiltundefined
                              fcwilt
                              This post is deleted!
                              • undefined
                                moe.adams9093
                                ; homeall.g
                                G1 H2 Z-500 F6000;
                                G30 ; probe Z
                                G30 ; probe z again
                                Sorry this is in the requested format
                                • undefined
                                  moe.adams9093
                                  thank you
                                  • fcwiltundefined
                                    fcwilt
                                    Try removing the M574 Z1 S2 command from config.g - or comment it out - and see if that makes a difference.
                                    In the G31 command you have the probe X and Y offsets as 0 - that means the probe is in the same place as the nozzle - is that the case?
                                    Have you verified that each Z end stop sensor responds correctly as indicated by issuing an M119 command if you operated them manuall?
                                    • undefined
                                      moe.adams9093
                                      The printer still under construction so I havent made any offset measurements yet to G31 that would be my next step. But I need to solve this issue first where it home correctly as I wanted to do so. Also when I run m119 I get Z endstops to trigger correctly. But the problem is when I click home all the only one axis moves down the other 3 sets as where they are
                                      fcwiltundefined 1 Reply Last reply 29 Jan 2021, 16:04 Reply Quote 0
                                      • fcwiltundefined
                                        Before you mapped all four of those steppers to Z did you try them mapped just one at time to Z to verify that each worked?
                                          You have one of the switches inverted with !, but not the rest. I assume they are all the same type of switch, yes? If so, you would need a ! before each pin name.
                                          undefined 1 Reply Last reply 29 Jan 2021, 16:37 Reply Quote 0
                                          1 out of 108
