    G32 ERROR
    5.1k
    • moe.adams9093undefined
      moe.adams9093
      No I will do that tonight when I get back home and do some recrackin.
        moe.adams9093 @Phaedrux
        @Phaedrux man your sharp yes I think thats the problem. I will try it tonight because when I homed only that axis was moving and the rest wasn't moving at all. I thought when I combine all of them they should automatically be the same type. Thanks
          moe.adams9093
          So I went ahead and did combine all of my endstops on a single line in this order
          M574 Z2 S1 p"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop";
          it crashed my firmware so I had to do a hard reset and erase firmware and reupload new firmware but this time I did install 3.2. and also I did try just one endstop
          M574 Z2 S1 p"!exp.e2stop . ti did ignore the bed to go down to 500 it went to -500.
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti
            @moe-adams9093 said in G32 ERROR:
            M574 Z2 S1 p
            dunno if it matter but use a capital P
              moe.adams9093
              I tried CAP P still doing the same thing
              • Vetiundefined
                Veti @moe.adams9093
                please post a M122 after the crash
                  moe.adams9093
                  its to late to post M112 because I already fixed this issue. now Im dealing with homing-all problem it just not working. I don't know if the duet can allow to use EndStops on max and Zprob On MIN
                  • fcwiltundefined
                    fcwilt @moe.adams9093
                    Yes it can - just need to get the settings right.
                    Is homing using the Z end stop sensors working?
                      moe.adams9093
                      so now I was able to get one end stop to work but when press the end-stop all 4 z motors stop not individually.
                        moe.adams9093
                        when I write this code and hit save and restart the board Deg light will flash red and the bord is not reachable at this stage so I had to manually erase the firmware and reupload all files again
                        M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop";
                          moe.adams9093
                          M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e5stop+!duex.e6stop";
                          this line of Code it did work but when I press any of the end-stop all 4 Z motors Stop not individually
                          • fcwiltundefined
                            I have no idea why you should have had to erase the firmware - that makes no sense at all.
                            In any case since you had to upload all the files again but post config.g and homeall.g using the </> tag to be sure we are looking at the most recent.
                              Can you please send M122 and M98 P"config.g" and post the results?
                              We are assuming you are on RRF3 but I don't think we've actually checked yet.
                              It certainly can. The endstops are configured with M574 and called into action with a G1 H1 Z move, and the probe is configured with M558/G31 and called into action with G30. So as long as both are configured, you can choose which to use by either using a G1 H1 Z move or a G30/G29.
                              moe.adams9093undefined 1 Reply Last reply Reply Quote 0
                                @Phaedrux Ok so after long hours of troubleshooting and looking on duet documentation and also at duet form to find someone had the same issue. so at first when I added this code line to my config.g
                                the moment when I hit save and restart the system never came back online my Degnostic light on the DuetEthernet Board was flashing red. at that stage, I went and connected via USB to enable M552S1 but my Yat Couldn't find the duet so I went ahead and jumped the 2 erase headers and reinstall the firmware everything came back as it supposed I went back a gain and added same code and it worked fine after that I'm not sure why the board did crash. so now this is my latest configuration files
                                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
                                G90                                                     	; send absolute coordinates...
                                M83                                                     	; ...but relative extruder moves
                                M550 P"DIVINCI-3D (MP4560)"                             	; set printer name
                                M669 K1                                                 	; select CoreXY mode
                                M552 P0.0.0.0 S1                                        	; enable network and acquire dynamic address via DHCP
                                M586 P0 S1                                              	; enable HTTP
                                M586 P1 S0                                              	; disable FTP
                                M586 P2 S0                                              	; disable Telnet
                                M569 P10  R1 T2:2:2:2  S1  									; physical drive 0 goes forwards
                                M569 P11  R1 T2:2:2:2  S1  									; physical drive 1 goes forwards
                                M569 P3 S1                                             		; physical drive 3 goes forwards
                                M569 P4 S1                                              	; physical drive 4 goes forwards
                                M569 P5 S1                                              	; physical drive 5 goes Backwards
                                M569 P6 S1 													; physical drive 6 goes Backwards
                                M569 P8 S0			          								; physical drive 7 goes Backwards
                                M569 P9 S0                                              	; physical drive 9 goes backwards
                                M584 X10 Y11 Z5:6:8:9 E3:4                              	; set drive mapping
                                M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S6    	; ZBelts Near Locations
                                M350 X16 Y16 Z16 E16:16 I1                              	; configure microstepping with interpolation
                                M92 X40.00 Y40.00 Z410.00 E415.00:415.00 					; set steps per mm
                                M566 X900.00 Y900.00 Z12.00 E120.00:120.00              	; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00        		; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z40.00 E250.00:250.00           		; set accelerations (mm/s^2)
                                M906 X1800 Y1800 Z1000 E500:500 I30                     	; set motor currents (mA) and motor idle factor in per cent
                                M84 S30                                                 	; Set idle timeout
                                M208 X0 Y0 Z0 S1                                        	; set axis minima
                                M208 X460 Y460 Z460 S0                                  	; set axis maxima
                                M574 X1 S1 P"!xstop"                                    		; configure active-high endstop for low end on X via pin !xstop
                                M574 Y1 S1 P"!ystop"                                    		; configure active-high endstop for low end on Y via pin !ystop
                                M574 Z1 S2                                              		; configure Z-probe endstop for low end on Z
                                M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop"	; configure Z-probe endstop for low end on Z
                                M558 P1 C"zprobe.in" H25 F600 T6000                      	; set Z probe type to unmodulated and the dive height + speeds
                                G31 P500 X0 Y0 Z2.5                                     	; set Z probe trigger value, offset and trigger height
                                M557 X20:440 Y20:440 S20                                	; define mesh grid
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 	; configure sensor 0 as thermistor on pin bedtemp
                                M950 H0 C"bedheat" T0                                   	; create bed heater output on bedheat and map it to sensor 0
                                M307 H0 A11 C99000 D2000 B1                  				; enable bang-bang mode for the bed heater and set PWM limit
                                M140 H0                                                 	; map heated bed to heater 0
                                M143 H0 S120                                            	; set temperature limit for heater 0 to 120C
                                M308 S1 P"spi.cs1" Y"thermocouple-max31856"             	; configure sensor 1 as thermocouple via CS pin spi.cs1
                                M950 H1 C"e0heat" T1                                    	; create nozzle heater output on e0heat and map it to sensor 1
                                M307 H1 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                                M308 S2 P"spi.cs2" Y"thermocouple-max31856"             	; configure sensor 2 as thermocouple via CS pin spi.cs2
                                M950 H2 C"e1heat" T2                                    	; create nozzle heater output on e1heat and map it to sensor 2
                                M307 H2 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                                M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950       	; configure sensor 3 as thermistor on pin duex.e2temp
                                M950 H3 C"duex.e2heat" T3                               	; create chamber heater output on duex.e2heat and map it to sensor 3
                                M307 H3 A11 C99000 D2000 B1                             	; enable bang-bang mode for the chamber heater and set PWM limit
                                M141 H3                                                 	; map chamber to heater 3
                                M950 F0 C"fan0" Q500                                    	; create fan 0 on pin fan0 and set its frequency
                                M106 P0 S1 H-1                                          	; set fan 0 value. Thermostatic control is turned on
                                M950 F1 C"fan1" Q500                                    	; create fan 1 on pin fan1 and set its frequency
                                M106 P1 S1 H2 T45                                       	; set fan 1 value. Thermostatic control is turned on
                                M950 F2 C"fan2" Q500                                    	; create fan 2 on pin fan2 and set its frequency
                                M106 P2 S1 H1:2 T45                                     	; set fan 2 value. Thermostatic control is turned on
                                M563 P0 S"MAIN EXTRUDER" D0 H1 F0                       	; define tool 0
                                G10 P0 X0 Y0 Z0                                         	; set tool 0 axis offsets
                                G10 P0 R0 S0                                            	; set initial tool 0 active and standby temperatures to 0C
                                M563 P1 S"SECOND EXTRUDER" D1 H2 F0                     	; define tool 1
                                G10 P1 X0 Y0 Z0                                         	; set tool 1 axis offsets
                                G10 P1 R0 S0                                            	; set initial tool 1 active and standby temperatures to 0C
                                M575 P1 S1 B57600                                       	; enable support for PanelDue
                                M501                                                    	; load saved parameters from non-volatile memory
                                M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"      	; set voltage thresholds and actions to run on power loss
                                T0                                                      	; select first tool
                                ; homeall.g
                                ; called to home all axes
                                G1 H1 Z500 F6000          ; lift Z relative to current position
                                G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
                                G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
                                G1 H2 X5 Y5 F6000       ; go back a few mm
                                G1 H1 X-465 F360        ; move slowly to X axis endstop once more (second pass)
                                G1 H1 Y-465 F360        ; then move slowly to Y axis endstop
                                G1 X235 Y235 F6000      ; Prob at Center
                                M558 F600 A1 		    ; Dive fast once
                                G30			            ; probe Z
                                M558 F300 A10 		    ; Slow second dive with more accuracy
                                G30			            ; probe z again
                                1/31/2021, 11:51:21 PM: M122: === Diagnostics ===
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later + DueX5
                                Board ID: 08DLM-996RU-N8PS0-7J9D8-3S86T-1B8VP
                                Used output buffers: 3 of 24 (24 max)
                                Static ram: 23460
                                Dynamic ram: 70344 of which 40 recycled
                                Never used RAM 18236, free system stack 210 words
                                Tasks: NETWORK(ready,173) HEAT(blocked,309) DUEX(blocked,35) MAIN(running,452) IDLE(ready,19)
                                Owned mutexes:
                                Last reset 00:02:05 ago, cause: power up
                                Last software reset at 2021-01-31 23:46, reason: User, GCodes spinning, available RAM 18236, slot 0
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU temperature: min 26.3, current 26.8, max 27.1
                                Supply voltage: min 25.0, current 25.0, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 0, standstill, SG min/max not available
                                Driver 1: position 0, standstill, SG min/max not available
                                Driver 2: position 0, standstill, SG min/max not available
                                Driver 5: position 0, standstill, SG min/max not available
                                Driver 6: position 0, standstill, SG min/max not available
                                Driver 7: position 0, standstill, SG min/max not available
                                Driver 8: position 0, standstill, SG min/max not available
                                Driver 9: position 0, standstill, SG min/max not available
                                Driver 10: position 0
                                Driver 11: position 0
                                Date/time: 2021-01-31 23:51:20
                                Cache data hit count 194997097
                                Slowest loop: 8.94ms; fastest: 0.21ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 3.9ms, write time 2.4ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
                                Heater 1 is on, I-accum = 0.0
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 25.61ms; fastest: 0.07ms
                                HTTP sessions: 2 of 8
                                Interface state active, link 100Mbps full duplex
                                === DueX ===
                                Read count 0, 0.00 reads/min
                                **The Problem now when I click HomeZ only driver number 6 moves down (!exp.e6stop) and if press any end-stop it will stop it but the rest they do not move at all this is the problem I have I don't know if the Duex5 is bad and not communicating effectively with the duet ethernet board. **
                                  @Phaedrux said in G32 ERROR:
                                  And just to confirm, you have all Z motors and endstops connected to the Duex?
                                  And your duex is wired up for power/ground as shown here?
                                  https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                                    moe.adams9093
                                    1/31/2021, 11:51:56 PM: M98 P"config.g": HTTP is enabled on port 80
                                    FTP is disabled
                                    TELNET is disabled
                                    Error: bad grid definition: Too many grid points; suggest increase spacing to 21.0mm
                                    Warning: Macro file config-override.g not found
                                    sorry I thought I did post my M98. but everything works correctly on my duex5 except my end stops. If I run M564 S0 H0 all Zmotors work correctly. the duex5 is wired correctly as and all endstops wired correctly as well
                                    • fcwiltundefined
                                      fcwilt
                                      The comment says 7 the command specifies 8.
                                      Have you manually activated each Z end stop sensor, one at a time, and run M119 to verify the reported end stop state?
                                        moe.adams9093
                                        Yes I did and they all trigger as Z max endstop on m119
                                          moe.adams9093
                                          M569 P5 S1
                                          M569 P6 S1
                                          M569 P8 S0
                                          M569 P9 S0
                                          Yes this is the correct format for all of my z axis motors 2 motors are mirror to the other 2 thats why I have p8 s0 and p9 s0
                                          • fcwiltundefined
                                            Great.
                                            Can you easily remove the bed assembly so we can test each Z stepper one at a time?
