    G32 ERROR
    5.6k
    • moe.adams9093undefined
      moe.adams9093
      Re: Auto bed leveling
      Hello everyone I'm having problems when I send command G32 to perform true bed leveling. My build uses 4 motors NEMA 17 with worm gear box to drive Z axis. Z axis is belt driven with rod end bearing to eliminate resistance when I send G32 my DC 42 IR sensor it triggers the 4 corners but I get these Errors
      ( g32: Error: Some computed corrections exceed configured limit of 1.00mm: 9.056 -8.629 -10.350 8.226)
      config File
      Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
      M550 P"DIVINCI-3D (MP4560)" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P10 R1 T2:2:2:2 S1 ; physical drive 0 goes forwards
      M569 P11 R1 T2:2:2:2 S1 ; physical drive 1 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P5 S1 ; physical drive 5 goes Backwards
      M569 P6 S1 ; physical drive 6 goes Backwards
      M569 P8 S0 ; physical drive 7 goes Backwards
      M569 P9 S0 ; physical drive 9 goes backwards
      M584 X10 Y11 Z5:6:8:9 E3:4 ; set drive mapping
      M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 ; ZBelts Near Locations
      M350 X32 Y32 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z410.00 E415.00:415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1000 E500:500 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X460 Y460 Z460 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in" H25 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X20:440 Y20:440 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 A11 C99000 D2000 B1 ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M308 S2 P"spi.cs2" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs2
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950 ; configure sensor 3 as thermistor on pin duex.e2temp
      M950 H3 C"duex.e2heat" T3 ; create chamber heater output on duex.e2heat and map it to sensor 3
      M307 H3 A11 C99000 D2000 B1 ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H3 ; map chamber to heater 3
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on
      M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on
      M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"MAIN EXTRUDER" D0 H1 F0 ; define tool 0
      M563 P1 S"SECOND EXTRUDER" D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      T0 ; select first tool
      bed.g file
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 30 2020 23:57:44 GMT-0500 (Central Daylight Time)
      G30 P0 X5 Y25 Z-999999;
      G30 P1 X455 Y25 Z-999999;
      G30 P2 X455 Y455 Z-999999; probe near a leadscrew, half way along Y axis
      G30 P3 X5 Y455 Z-999999 S4; probe near a leadscrew and calibrate 2 motors
      Homeall.g
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H2 Z0 F6000 ; lift Z relative to current position
      G1 H1 X-465 F4000 ; move quickly to X endstop and stop there (first pass)
      G1 H1 Y-465 F4000 ; move quickly to Y endstop and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-465 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-465 F360 ; then move slowly to Y axis endstop
      G1 X235 Y235 F6000 ; Prob at Center
      M558 F600 A1 ; Dive fast once
      G30 ; probe Z
      M558 F100 A10 ; Slow second dive with more accuracy
      G30 ; probe z again
      please share your expertise and knowledge to help me over come this problem. Thank you
      • Vetiundefined
        Veti
        @moe-adams9093 said in G32 ERROR:
        M671
        see the S parameter
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
          moe.adams9093
          I looked over this document to understand M671 few times and I have changed the S parameters between 2 to -10 all of them gave out the same error. So I don't know what I need to change at this time. Correct me if I'm wrong does it mean the S parameters will allow to compensate the difference for example if my M671 X 25 : 455: 25:455 Y 25: 25:455:455 S-10 does that mean the bed 4 corners will adjust between 0 & -10.
            jay_s_uk
            The S value is the maximum adjustment that it will account for.
            If you set it to 5 and it comes out with a difference of 4, it will adjust. If it comes out at 6, it won;t be adjusted.
            I have mine typically set at 10 so any out of adjustment up to 10mm will be automatically adjusted.
            You shouldn't be setting S to a negative value
            • Vetiundefined
              Veti
              you have a difference of 19.3 mm between the points
              • fcwiltundefined
                fcwilt @jay_s_uk
                @jay_s_uk said in G32 ERROR:
                Have you verified this by testing?
                When I read "Maximum correction to apply to each leadscrew in mm" I took it to mean it would make adjustments up to the S parameter value but no more.
                Thanks.
                  moe.adams9093
                  Thanks for the info. I will try to remove negative value and work alone the positive and see my results
                    jay_s_uk @fcwilt
                    @fcwilt yes.
                    As when I had an adjustment larger than the specified S value, no adjustment took place
                    • fcwiltundefined
                      fcwilt @jay_s_uk
                      @fcwilt yes.
                      Thanks.
                      @Phaedrux - would you check the docs for the S parameter of M671 and see if you think it is consistent with the observed behavior?
                      Thanks.
                        Phaedrux Moderator @fcwilt
                        @fcwilt Yes the word "apply" would seem to indicate that something will be done.
                        Snn Maximum correction to apply to each leadscrew in mm
                        I'll change that to Maximum correction allowed for each leadscrew in mm. Which captures that corrections beyond that are not allowed.
                          moe.adams9093
                          Thank you for your help I have figured out my S value needed to be at 6. Another problem im facing now when I home All I need my Z axis to travel to Zmax first and hit all 4 Endstops which they are correspond to each separate Driver then to travel up to the Zmin which will stop by the IR sensor and perform the probing sequence. So long story short I added to my configuration file
                          M574 Z2 S1 P" exp.e2stop+exp.e3stop+exp.e5stop+exp.e6stop"; and its not doing what it supposed to. Like when I hit home all the z axis won't move at all. I did change some code im my homeall.g where the Z will travel to 500 first then home x and y the can go back to -500 but its not working Correctly. Thanks in advance
                          • fcwiltundefined
                            fcwilt @moe.adams9093
                            Another problem im facing now when I home All...
                            Please post your current config.g and homeall.g files - using the </> tag.
                              moe.adams9093
                              oh heres my latest files and configuration
                              config file
                              M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S6 ; ZBelts Near Locations
                              M574 Z2 S1 p"!exp.e2stop+exp.e3stop+exp.e5stop+exp.e6stop" ; Configure active- high endstops for high end on Z
                              ; homeall.g
                              G1 H1 Z500 F6000 ; lift Z relative to current position
                              G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
                              G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
                              G1 H2 Z-500 F6000;
                              G30 ; probe Z
                              M558 F300 A10 ; Slow second dive with more accuracy
                              G30 ; probe z again
                              • fcwiltundefined
                                fcwilt
                                This post is deleted!
                                  moe.adams9093
                                  G90                                                     	; send absolute coordinates...
                                  M83                                                     	; ...but relative extruder moves
                                  M208 X0 Y0 Z0 S1                                        	; set axis minima
                                  M140 H0                                                 	; map heated bed to heater 0
                                  M143 H0 S120                                            	; set temperature limit for heater 0 to 120C
                                  M950 H1 C"e0heat" T1                                    	; create nozzle heater output on e0heat and map it to sensor 1
                                  M307 H1 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
                                  M950 F0 C"fan0" Q500                                    	; create fan 0 on pin fan0 and set its frequency
                                  G10 P0 X0 Y0 Z0                                         	; set tool 0 axis offsets
                                  G10 P0 R0 S0                                            	; set initial tool 0 active and standby temperatures to 0C
                                  ; homeall.g
                                  G1 H2 Z-500 F6000;
                                  G30			            ; probe Z
                                  G30			            ; probe z again
                                  Sorry this is in the requested format
                                    moe.adams9093
                                    thank you
                                    • fcwiltundefined
                                      fcwilt
                                      Try removing the M574 Z1 S2 command from config.g - or comment it out - and see if that makes a difference.
                                      In the G31 command you have the probe X and Y offsets as 0 - that means the probe is in the same place as the nozzle - is that the case?
                                      Have you verified that each Z end stop sensor responds correctly as indicated by issuing an M119 command if you operated them manuall?
                                        moe.adams9093
                                        The printer still under construction so I havent made any offset measurements yet to G31 that would be my next step. But I need to solve this issue first where it home correctly as I wanted to do so. Also when I run m119 I get Z endstops to trigger correctly. But the problem is when I click home all the only one axis moves down the other 3 sets as where they are
                                        • fcwiltundefined
                                          Before you mapped all four of those steppers to Z did you try them mapped just one at time to Z to verify that each worked?
                                            You have one of the switches inverted with !, but not the rest. I assume they are all the same type of switch, yes? If so, you would need a ! before each pin name.
                                            moe.adams9093undefined 1 Reply Last reply Reply Quote 0
