    Formulas behind the emf-calculator
    1.1k
    • ZipZapundefined
      ZipZap
      Dear co-printers,
      for an internal research paper i would like to better understand the calculations behind the emf-calculator on reprapfirmware.org.
      Does anybody know (or can give me a hint/link) the formulas behind this calculator?
      I am a hardcore mechanic - though basic electronics is present, such calculations exceed my knowledge.
      Is there an easier way than to look through the site-code?
      Many thanks in advance and greetings from germany,
      Julien
      Most important guide -> Triffid Hunter's Calibration Guide
      HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
      A Former User? droftartsundefined 2 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User @ZipZap
        @ZipZap
        I dunno bout what they use in the RRF-calculator, but maybe these websites could be of help for ya:
        https://www.linearmotiontips.com/electromagnetism-basics-for-mechanical-engineers/
        https://www.motioncontroltips.com/lenzs-law/
        https://www.motioncontroltips.com/tag/back-emf/
        Use dict.leo.org or translate.google.com if you are not so fluent
        Or get an "old fashion" book e.g. here: https://www.lehmanns.de/search/quick?PHPSESSID=dk0t4m42jq6cdevmk0h553q9a4&mediatype_id=&q=antriebsauslegung
          droftarts administrators @ZipZap
          @ZipZap Thanks to @chrishamm, who wrote it, it's plain JavaScript, so you can open the EMF calculator and see what it's doing: https://www.reprapfirmware.org/js/main.js
          I'm sure Chris will welcome any suggestions for improvement!
          • chrishammundefined
            chrishamm administrators
            @ZipZap @droftarts The EMF tool on reprapfirmware.org uses the calculations from this StepperMotor spreadsheet by @dc42. You may find that helpful too.
            Duet software engineer
            • ZipZapundefined
              ZipZap
              Thanks to everyone, great answers.
              I will work my way through the spreadsheet whilst trying to undertand the theory from @LB 's links.
              I have to say, this is one of the few "BS-free" forums i've met. Lots of competent answers and less guesswork 🙂 .
              /Julien
                The formula for back emf due to rotation comes from matching the input and output energy. Basically, torque x angular_velocity = back_emf_due_to_rotation x current but you need to allow for the phase angle between the back emf and the current.
                • tombrazierundefined
                  tombrazier
                  @dc42 and @chrishamm thank you for the EMF calculator. I was busy replicating this work when I found it.
                  I think I have found several errors in the calculations of the "Speed at which torque starts to drop" values. (Just to give some credence to what I suggest below it might be helpful to know I am a Marlin dev.)
                  • When calculating revsTorqueDropLowSlip and revsTorqueDropHighSlip I think just dividing speed by the number of motors is incorrect. Instead, the value of supplyVoltage should be divided by the number of motors. i.e. motors in series form a potential divider for the supply voltage. An easy way to test my assertion is to consider what happens with two motors in series when resistance * motorCurrent > supplyVoltage / 2. That should result in "n/a" because the voltage cannot even drive the requested current through the two winding resistances. But, instead, the web page just halves the speeds.
                  • driverVoltageDrop is double counted. It is incorporated when voltageDrop is calculated and then, later, when revsTorqueDropLowSlip and revsTorqueDropHighSlip are calculated, it is added on to voltageDrop again.
                  • revsTorqueDropHighSlip is missing voltageDrop in two places. This formula is the result of applying the quadratic formula to solve for revs in the equation supplyVoltage = sqrt( (revs * inductiveBackEmfPerRevSec)^2 + (revs * motionBackEmfPerRevSec + voltageDrop)^2 ). This expands to0 = revs^2 * inductiveBackEmfPerRevSec^2 + revs^2 * motionBackEmfPerRevSec^2 + 2 * revs^2 * motionBackEmfPerRevSec * voltageDrop + voltageDrop^2 - supplyVoltage^2. The b coefficient in this equation is 2 * motionBackEmfPerRevSec * voltageDrop and it is this voltageDrop which is lost when the quadratic formula is applied to calculate revsTorqueDropHighSlip.
                  o_lampeundefined 1 Reply Last reply Reply Quote 4
                  • o_lampeundefined
                    o_lampe @tombrazier
                    @chrishamm
                    Not sure if there is something wrong with the formulas, but bringing up the subject reminded my of my request to integrate the EMF calculator in DWC as plugin.
                    So, if it would need rewriting, please consider this option too
                      tombrazier
                      Ah, bother, there is an error in one of my formulae and akismet won't let me correct it. The third bullet point should have "This expands to..." with 2 * revs * motionBackEmfPerRevSec * voltageDrop in the middle of the equation (where revs is not squared).
                      • tombrazierundefined tombrazier referenced this topic
