    Uploaded files via CURL are empty
    928
    • MartinNYHCundefined
      MartinNYHC
      /usr/bin/curl -v -d foo.mcf.pre.gcode -X PUT http://192.168.255.30/machine/file/gcodes/Palette/foo.mcf.pre.gcode
      *   Trying 192.168.255.30...
      * TCP_NODELAY set
      * Connected to 192.168.255.30 (192.168.255.30) port 80 (#0)
      > PUT /machine/file/gcodes/Palette/foo.mcf.pre.gcode HTTP/1.1
      > Host: 192.168.255.30
      > User-Agent: curl/7.64.1
      > Accept: */*
      > Content-Length: 17
      > Content-Type: application/x-www-form-urlencoded
      * upload completely sent off: 17 out of 17 bytes
      < HTTP/1.1 201 Created
      < Date: Thu, 28 Jan 2021 11:31:57 GMT
      < Server: Kestrel
      < Content-Length: 0
      < Location: gcodes/Palette/foo.mcf.pre.gcode
      * Connection #0 to host 192.168.255.30 left intact
      * Closing connection 0
      Am I missing something?
      • felekundefined
        felek
        @MartinNYHC Why are you using PUT? Try to use POST method.
          MartinNYHC
          When using POST i get HTTP error code 405
          /usr/bin/curl -v -d foo.mcf.pre.gcode -X POST http://192.168.255.30/machine/file/gcodes/Palette/foo.mcf.pre.gcode
          Note: Unnecessary use of -X or --request, POST is already inferred.
          * TCP_NODELAY set
          > POST /machine/file/gcodes/Palette/foo.mcf.pre.gcode HTTP/1.1
          > Accept: */*
          > Content-Length: 17
          < HTTP/1.1 405 Method Not Allowed
          < Date: Thu, 28 Jan 2021 11:49:27 GMT
          < Server: Kestrel
          < Content-Length: 0
          < Allow: DELETE, GET, PUT
          • Vetiundefined
            Veti
            see
            https://confluence.alitecs.de/display/3DP/Upload+to+Duet+(Wifi)+when+slicing
              MartinNYHC
              @Veti Also tried that but then I get HTTP/1.1 404 Not Found.
              * TCP_NODELAY set
              > POST /rr_upload?name=gcodes/foo.mcf.pre.gcode HTTP/1.1
              > Accept: */*
              > Content-Length: 156
              > Content-Type: multipart/form-data; boundary=------------------------b7bdfc0b11202264
              * We are completely uploaded and fine
              < HTTP/1.1 404 Not Found
              < Date: Thu, 28 Jan 2021 11:53:02 GMT
              < Server: Kestrel
              < Content-Length: 0
                MartinNYHC
                Any other ideas? No matter what I try, I get 404/405 or the file is there but empty.
                • matt3oundefined
                  matt3o
                  never tried personally but isn't the upload URL something like http://duet.local/rr_upload?...
                  • Vetiundefined
                    Veti
                    or use ftp
                    see
                    https://reprap.org/wiki/Duet_Firmware_Update#Use_FTP_to_transfer_new_files_on_the_SD_card
                      MartinNYHC
                      Yes, but I would like to know if I'm simply to stupid or if something strange is going on 😉
                      • Vetiundefined
                        Veti
                        i just checked and upload using dwc
                        POST
                        http://192.168.1.220/rr_upload?name=0:/gcodes/duet_pa.gcode&time=2018-11-3T6:14:59&crc32=365da967
                          MartinNYHC
                          Very strange....404 error.
                          curl -v -F file=foo.mcf.pre.gcode http://192.168.255.30/rr_upload?name=0:/gcodes/duet_pa.gcode&time=2018-11-3T6:14:59&crc32=365da967
                          * TCP_NODELAY set
                          > POST /rr_upload?name=0:/gcodes/duet_pa.gcode&time=2018-11-3T6:14:59&crc32=365da967 HTTP/1.1
                          > Accept: */*
                          > Content-Length: 156
                          > Content-Type: multipart/form-data; boundary=------------------------deaa13d4181c5fac
                          < Date: Thu, 28 Jan 2021 16:13:43 GMT
                          < Server: Kestrel
                          < Content-Length: 0
                          • chrishammundefined
                            chrishamm administrators
                            @MartinNYHC I don't think the Content-Type is correct. The body must be the raw file content, e.g.
                            curl -X PUT -H "Content-Type: text/plain" --data "this is raw data"  ...
                            @Veti The upload requests for DSF are different, so POST rr_upload will not work.
                            Duet software engineer
                            MartinNYHCundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                              MartinNYHC @chrishamm
                              @chrishamm said in Uploaded files via CURL are empty:
                              Yup, that makes sense...
                              curl -v -X PUT -H "Content-Type: text/plain" --data @foo.mcf.pre.gcode "http://192.168.255.30/machine/file/gcodes/foo.mcf.gcode"
                              * TCP_NODELAY set
                              > PUT /machine/file/gcodes/foo.mcf.gcode HTTP/1.1
                              > Accept: */*
                              > Content-Length: 8368
                              > Expect: 100-continue
                              < HTTP/1.1 100 Continue
                              < Date: Thu, 28 Jan 2021 16:21:19 GMT
                              < Server: Kestrel
                              < Content-Length: 0
                              < Location: gcodes/foo.mcf.gcode
                              That works.
                              Thanks @chrishamm !
                              • Vetiundefined
                                Veti @chrishamm
                                DSF
                                if you are running a pi it would be easier to just upload the file via ssh with scp.
                                • stewartundefined
                                  stewart
                                  This post is deleted!
