    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.9k
    • Hélder Rochaundefined
      Hélder Rocha
      wait...to small
        Hélder Rocha
          Its trying to use HTTPS. Change the url to use only http
          Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
            Hélder Rocha
            the same appens on chrome!
              Hélder Rocha @Phaedrux
              @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
              Going to check how that is done...
                Just change the url.
                HTTP: instead of HTTPS:
                  it changes again to HTTPS...i erase the "s" but doesnt work
                    Phaedrux Moderator @Hélder Rocha
                    @Hélder-Rocha I don't know if that's a problem or just what it normally does when it can't reach the site.
                    Are you able to connect the duet to your home wifi?
                      Hélder Rocha
                      even if i try the duettest.local... it changes to the https followed by the ip number
                        no... i am trying by the access point given by the board
                          Hélder Rocha
                          the blue led on the board is lit... the duet is working fine... after dinner ill try a different computer
                            @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                            Yes I understand that, but do you have a local WIFI network that you can test connecting to?
                              @Phaedrux yes offcouse. Also tried that way... could get in!
                                Hélder Rocha
                                With my home network:
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                                Board ID: 08DGM-917DA-G4MSD-6J1F2-3S06L-T9VVB
                                Used output buffers: 1 of 24 (1 max)
                                Static ram: 23460
                                Dynamic ram: 77144 of which 40 recycled
                                Never used RAM 11436, free system stack 170 words
                                Tasks: NETWORK(ready,408) HEAT(blocked,323) MAIN(running,474) IDLE(ready,19)
                                Owned mutexes: USB(MAIN)
                                Last reset 01:33:55 ago, cause: power up
                                Last software reset at 2021-01-30 15:46, reason: User, GCodes spinning, available RAM 15160, slot 2
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                MCU temperature: min 20.1, current 25.6, max 26.4
                                Supply voltage: min 0.7, current 1.6, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                                Driver 0: position 0, ok, SG min/max not available
                                Driver 1: position 0, ok, SG min/max not available
                                Driver 2: position 0, ok, SG min/max not available
                                Driver 3: position 0, ok, SG min/max not available
                                Driver 4: position 0, ok, SG min/max not available
                                Driver 5: position 0
                                Driver 6: position 0
                                Driver 7: position 0
                                Driver 8: position 0
                                Driver 9: position 0
                                Driver 10: position 0
                                Driver 11: position 0
                                Slowest loop: 99.97ms; fastest: 0.14ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is ready with "M122" in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 199.51ms; fastest: 0.00ms
                                HTTP sessions: 0 of 8
                                • WiFi -
                                  Network state is active
                                  WiFi firmware version 1.25
                                  WiFi MAC address cc:50:e3:0d:1f:26
                                  WiFi Vcc 3.36, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 28272
                                  WiFi IP address 192.168.0.23
                                  WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Clock register 00002002
                                  ok
                                  Hélder Rocha
                                  tried to access from a different computer, throw my home network and couldnt get there either.... what the hell can i be doing wrong!?
                                    The duet IP address is 192.168.0.23
                                    What is the IP address of your own computer?
                                    Are they even in the same subnet?
                                      @Phaedrux
                                      IPv4 address.............192.168.1.2
                                      subnet Mask.............255.255.255.0
                                      Default Gateway.......192.168.1.1
                                        Hélder Rocha @Hélder Rocha
                                        @Hélder-Rocha i beleave i found the error.... when i was working on the RRF config tool, in the end, in the network setings panel, i havent change the Ip, nor the subnet mask or the gateway... i let it be as it was, thinking those were the correct ones!
                                          so... whem i upload this settings as new config, i uploaded the wrong Ip etc etc
                                            Are you assigning the IP address to the duet or is it getting a DHCP address?
                                            If your PC is on 192.168.1 then the duet will also need to be on 182.168.1
