    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.9k
    • Hélder Rochaundefined
      Hélder Rocha
        Its trying to use HTTPS. Change the url to use only http
        Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
          Hélder Rocha
          the same appens on chrome!
            Hélder Rocha @Phaedrux
            @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
            Going to check how that is done...
              Just change the url.
              HTTP: instead of HTTPS:
                it changes again to HTTPS...i erase the "s" but doesnt work
                  Phaedrux Moderator @Hélder Rocha
                  @Hélder-Rocha I don't know if that's a problem or just what it normally does when it can't reach the site.
                  Are you able to connect the duet to your home wifi?
                    Hélder Rocha
                    even if i try the duettest.local... it changes to the https followed by the ip number
                      no... i am trying by the access point given by the board
                        Hélder Rocha
                        the blue led on the board is lit... the duet is working fine... after dinner ill try a different computer
                          @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                          Yes I understand that, but do you have a local WIFI network that you can test connecting to?
                            @Phaedrux yes offcouse. Also tried that way... could get in!
                              Hélder Rocha
                              With my home network:
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                              Board ID: 08DGM-917DA-G4MSD-6J1F2-3S06L-T9VVB
                              Used output buffers: 1 of 24 (1 max)
                              Static ram: 23460
                              Dynamic ram: 77144 of which 40 recycled
                              Never used RAM 11436, free system stack 170 words
                              Tasks: NETWORK(ready,408) HEAT(blocked,323) MAIN(running,474) IDLE(ready,19)
                              Owned mutexes: USB(MAIN)
                              Last reset 01:33:55 ago, cause: power up
                              Last software reset at 2021-01-30 15:46, reason: User, GCodes spinning, available RAM 15160, slot 2
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 20.1, current 25.6, max 26.4
                              Supply voltage: min 0.7, current 1.6, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                              Driver 0: position 0, ok, SG min/max not available
                              Driver 1: position 0, ok, SG min/max not available
                              Driver 2: position 0, ok, SG min/max not available
                              Driver 3: position 0, ok, SG min/max not available
                              Driver 4: position 0, ok, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Slowest loop: 99.97ms; fastest: 0.14ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is ready with "M122" in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 199.51ms; fastest: 0.00ms
                              HTTP sessions: 0 of 8
                              • WiFi -
                                Network state is active
                                WiFi firmware version 1.25
                                WiFi MAC address cc:50:e3:0d:1f:26
                                WiFi Vcc 3.36, reset reason Turned on by main processor
                                WiFi flash size 4194304, free heap 28272
                                WiFi IP address 192.168.0.23
                                WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                                Clock register 00002002
                                ok
                                Hélder Rocha
                                tried to access from a different computer, throw my home network and couldnt get there either.... what the hell can i be doing wrong!?
                                  The duet IP address is 192.168.0.23
                                  What is the IP address of your own computer?
                                  Are they even in the same subnet?
                                    @Phaedrux
                                    IPv4 address.............192.168.1.2
                                    subnet Mask.............255.255.255.0
                                    Default Gateway.......192.168.1.1
                                      Hélder Rocha @Hélder Rocha
                                      @Hélder-Rocha i beleave i found the error.... when i was working on the RRF config tool, in the end, in the network setings panel, i havent change the Ip, nor the subnet mask or the gateway... i let it be as it was, thinking those were the correct ones!
                                        so... whem i upload this settings as new config, i uploaded the wrong Ip etc etc
                                          Are you assigning the IP address to the duet or is it getting a DHCP address?
                                          If your PC is on 192.168.1 then the duet will also need to be on 182.168.1
                                            DHCP address
                                            I dont know....is there a way to find out?
