    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.9k
    • Vetiundefined
      Veti
      looks ok.
      the bltouch port depends on the port where you connected it
      Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
      • Hélder Rochaundefined
        Hélder Rocha @Veti
        @Veti said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
        looks ok.
        Yes... i have it on the 4th pin near the red and the broun. I beleave is nº7
          Hélder Rocha
          do you have an idea abou the trigger height i should give to the Bltouch?
          • Vetiundefined
            Veti
            take the value from your old config
              Hélder Rocha @Hélder Rocha
              @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
              looks ok.
              I change it to heater 3... the connections are just like the ones you find here:
              https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                Hélder Rocha
                Done...i am now uploading the new config
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
                  Here's a walk through of the config tool for RRF3 and an Ender3, which is pretty similar to the CR-10.
                    Hélder Rocha @Phaedrux
                    @Phaedrux Tks.... at the momment im with other problem. Forgot to include in the new config file the access point and now, i cant get access to it!
                      If it was added once before the SSID should be saved on the wifi module itself and sending M552 S1 should enable the module and it will try to connect to the strongest SSID it knows about.
                      If it doesn't seem to be doing that you can try re-adding it. Same steps as initial connection.
                      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                        @Phaedrux I think i messed this up... it steel giving me the message that the access point is working, and i can connect to it, but i dont know why, im not ablet to accesse the IP... "page not work"
                          Are you sure the IP address is the same?
                          If you send M552 the Duet will respond with what the current IP address is.
                          What is the exact error message?
                            @Phaedrux yap....is the same
                            Hélder Rochaundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                              Could be anything in the new config i uploaded?
                              • Vetiundefined
                                Veti @Hélder Rocha
                                that is not the exact error message
                                  Try clearing your browser cache.
                                  And if that doesn't work, I would check the /www folder on the SD card and replace the files there with a fresh copy of DWC.
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
                                    Hélder Rocha
                                    at the momment on YAT, it is sayng that the wifi module is connected to my home network! Do you know ohow to disable it, and reeturn to Duet access point?
                                    • Vetiundefined
                                      Veti
                                      Send M552 S2 to start up in access point mode (if it is already running in station mode then you need to send M552 S0 first).
                                        Hélder Rocha @Veti
                                        @Veti keeps saying "Enable to connect after i digit the IP on adress bar. I can stablish the access point, but cant access the DWC.
                                          Hélder Rocha
                                          The blue signal on the board is lit
                                            Phaedrux Moderator @Hélder Rocha
                                            Are you wanting to run in access point mode where you connect to the Duet directly with your PC/phone? Or normal mode where the Duet connects to your home wifi network?
                                            In access point mode you need to connect to the Duet SSID with your PC.
