    [RRF3.2] M207 T-parameter ignored?
    Duet Web Control
    m207 retraction speed
    • o_lampeundefined
      o_lampe
      Hi folks,
      My retraction settings look like that
      ;	Retraction
      M207 T0 S0.4 R0.05 F3600 T2400 Z0.2
      where the T-parameter should specify a slower unretract speed.
      But the answer in DWC console ignores the T-parameter.
      Is it a bug in DWC?
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • User3Dundefined
        User3D
        In RRF 3.01 and later, if a P parameter is provided then only the retraction parameters for the specified tool will be set. says : https://duet3d.dozuki.com/Wiki/Gcode#Section_M207_Set_retract_length
        o_lampeundefined 1 Reply Last reply Reply Quote 2
        • o_lampeundefined
          o_lampe @User3D
          @User3D
          thanks for noticing my typo 👍
          Will try again with P0
          • engikeneerundefined
            engikeneer @o_lampe
            @o_lampe you have two T parameters in your command. I think the first one should be P0 to apply the settings to Tool 0?
            i3 clone with a bunch of mods
            • o_lampeundefined
              o_lampe
              Yup, the P0 solved it!
              User3Dundefined 1 Reply Last reply Reply Quote 0
              • User3Dundefined
                User3D @o_lampe
                @o_lampe : )
