    Homeall Slams head to far corner
    87
    • mrenz999
      mrenz999 last edited by
      This has been an ongoing issue I can't seem to resolve. I can home x y z. Everything works fine. When I homeall it slams the head to the far back corner. Same when I do a G32 bedleveling command. I am going to post all my files and see if anyone sees anything I am doing wrong there.
      homeall.g
      ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
      G91 ; relative positioning
      G1 H1 X-500 Y-500 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H1 X-500
      G1 H1 Y-500
      G1 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-500 Y-500 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X222 Y201 F9000 ; go to first bed probe point and home Z
      G30 ; probe the bed
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
      G21 ; Set units to MM
      M550 P"Duet 3" ; set printer name
      M669 K1 ; select CoreXY mode
      ;Network
      ;M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S0 ; physical drive 1.0 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E408:408 ; set steps per mm
      M566 X600.00 Y600.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X20000 Y20000 Z600 E2000.00:2000.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z600.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M671 X-55:465:465 Y180:310:45 S9 ; leadscrews at rear left, front middle and rear right
      M208 X Y0 Z0 S1 ; set axis minima
      M208 X410 Y410 Z465 S0 ; set axis maxima
      M574 X1 S1 P"io4.in" ; configure active-high endstop for low end on X via pin !io0.in
      M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
      ;G31 P500 X-40 Y-10 Z1.192 ; set Z probe trigger value, offset and trigger height
      ;M557 X20:430 Y15:410 S20 ; define mesh grid
      Z-Probe
      M558 P8 C"^io7.out" H10 F120 T6000
      G31 P50 X16.795 Y25.4 Z.3
      M557 X20:400 Y20:400 S50
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S300
      M307 H0 R0.276 C683.100:683.100 D0.20 S1.00 V24.1 B0
      M307 H1 R2.032 C110.1 D4.50 S1.00 V24.2
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 S1.0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      ;M563 P1 D1 H1 F0
      ;G10 P1 X0 Y0 Z0
      ;G10 P1 R0 S0
      T0
      M501
      Bed.g
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time)
      G28 ; home
      ;M401 ; deploy Z probe
      G30 P0 X10 Y180 Z-99999 ; probe near an adjusting screw
      G30 P1 X360 Y310 Z-99999 ; probe near an adjusting screw
      G30 P2 X360 Y60 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
      ;G29
      ;M402 ; retract probe
      o_lampe 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt last edited by fcwilt
        @mrenz999 said in Homeall Slams head to far corner:
        I re-posted your files using the </> tag - it improves readability and provides scrolling sections for each file.
        Please posts your other homing files that you say are working for you.
        Thanks.
        config.g
        config.g
        ;Network
        Z-Probe
        M143 H1 S300
        ;M563 P1 D1 H1 F0
        ;G10 P1 X0 Y0 Z0
        ;G10 P1 R0 S0
        T0
        M501
        homeall.g
         G1 H1 X-500
         G1 H1 Y-500
         G30 ; probe the bed
        bed.g
        ; bed.g
        G28 ; home
        ;G29
        mrenz999 1 Reply Last reply Reply Quote 0
        • mrenz999
          mrenz999 @fcwilt last edited by
          @fcwilt
          ; homex.g
          ; called to home the X axis
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:21 GMT-0700 (Pacific Daylight Time)
          G1 H1 X-530 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F6000       ; go back a few mm
          G1 H1 X-530 F360  ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F6000   ; lower Z again
          ; homey.g
          ; called to home the Y axis
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:22 GMT-0700 (Pacific Daylight Time)
          G1 H1 Y-530 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F6000       ; go back a few mm
          G1 H1 Y-530 F360  ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G30 ; home z by probing the bed
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            @fcwilt said in Homeall Slams head to far corner:
            Why is one of these inverted and not the other?
            Did you verify that each is working by manually triggering them and running M119?
            • fcwilt
              fcwilt @mrenz999 last edited by
              @mrenz999
              I forgot to mention that issue with G32 having the same problem is bed.g issues G28 which runs homeall.g which is where the problem is.
              • mrenz999
                @fcwilt both work correctly. Different end stop switches.
                • mrenz999
                  @fcwilt so remove the G28 ?
                  Veti fcwilt 2 Replies Last reply Reply Quote 0
                  • Veti
                    Veti @mrenz999 last edited by
                    so remove the G28 ?
                    no fix the problem in homeall.g
                    • fcwilt
                       G1 H1 X-500
                       G1 H1 Y-500
                      Why do you have lines 2 and 3?
                      • Veti
                        Veti last edited by
                        that for corexy because they cant move independently.
                        execute each line of homeall separately and see where the problem is
                        fcwilt mrenz999 2 Replies Last reply Reply Quote 0
                        • o_lampe
                          o_lampe @mrenz999 last edited by
                          G30 ; probe the bed
                          Is that the line that makes your head crash?
                          Why probe at X222 Y201?
                          • fcwilt
                            fcwilt @Veti last edited by
                            @Veti said in Homeall Slams head to far corner:
                            This isn't my problem - @mrenz999 was the OP - I'm just trying to help him.
                            • mrenz999
                              mrenz999 @o_lampe last edited by
                              @o_lampe To probe the center of the bed.
                              • mrenz999
                                mrenz999 @Veti last edited by
                                @Veti So this is what I did. One line at a time. Commented out the first line G92 and it works correctly now. Strange.
                                • fcwilt
                                  I don't see a G92 in your homeall.g file.
                                  Is that where it was?
