    Driver 3 too hot error
    377
    • wdenkerundefined
      wdenker
      I was getting a driver 3 too hot error from my duet, I removed the duex 5 board and that resolved the error long enough to have the driver 3 driver actually show signs of melting.
      Here is the M122.
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6M2-NW4SN-6J9D4-3S46T-KVS3L
      Used output buffers: 3 of 24 (14 max)
      Static ram: 25712
      Dynamic ram: 92880 of which 120 recycled
      Exception stack ram used: 304
      Never used ram: 12056
      Tasks: NETWORK(ready,676) HEAT(blocked,912) MAIN(running,3732) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:18:04 ago, cause: power up
      Last software reset at 2021-01-11 19:58, reason: User, spinning module GCodes, available RAM 10816 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 35.5, current 35.8, max 36.1
      Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Date/time: 2021-01-27 20:03:26
      Cache data hit count 4215967080
      Slowest loop: 5.10ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 200.42ms; fastest: 0.07ms
      HTTP sessions: 1 of 8
      WiFi -
      Network state is running
      Failed messages: pending 0, notready 0, noresp 20
      WiFi firmware version 1.23
      WiFi MAC address 84:0d:8e:b2:f4:96
      WiFi Vcc 3.42, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23000
      WiFi IP address 192.168.1.177
      WiFi signal strength -41dBm, reconnections 0, sleep mode modem
      www.bd3dcustoms.com | BD3DCUSTOMS Supercube
        Can you start from the top and try and explain what happened?
        You have a Duet2Ethernet and a Duex5?
        How was everything connected?
        Were you in the web interface yet?
        If you're unable to see the Duet via USB, try going through this document: https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        Photo of the board?
        When and where was it purchased?
        • wdenkerundefined
          wdenker
          Plugged it in like all my other builds, 2,5,6,7 to my z 0,1 to x and y 3 to my extruder. Was giving driver too hot error which I had read before that duex 5 board sometimes causes that error to show so I removed the duex 5 board while powered down and powered it back up and the driver 3 then started smoking and is now fried. Both boards at this point don't work. Was in the web interface with no issues. Can still see the duet no problem but driver 3 is toast. Bought first week of January for 8 custom builds I had for a customer just now getting into wiring all of them. Bought from filastruder. @Phaedrux
          • wdenkerundefined
            wdenker
            • A Former User?
              A Former User
              Top picture might indicate issues with the 3v3 regulator U2; but its clearly not the same board as shown with the scorched driver 3 (E0).
              wdenkerundefined 1 Reply Last reply Reply Quote 0
              • wdenkerundefined
                wdenker @A Former User
                @bearer nope have another set with issues as well. Must have gotten them mixed up.
                  Yes it appears that U2 has exploded. Please contact Filastruder and initiate a warranty exchange for this Duet. Include a link to this thread as authorization.
                  • wdenkerundefined
                    wdenker @Phaedrux
                    @Phaedrux as well as the duex 5?
                      The Duex5 on this one also stopped working?
                      • elmoretundefined
                        elmoret
                        Is that Duex5 genuine? It would appear not to me.
