Z calibration offset
  • Greetings,
    I need help with my calibration file or with other words with my machine.
    I don't know what the hell is going on. I printed two parts 300mm diameter with no problem, and then i didn't change anything and this happens. The bed calibration was off. Can somebody tell me what to change that the machine will work. I know the bed is curved, but i will solve this first ( Bl-touch,CR105S)
    Here is my config file:
    homeall.g config.g bed.g
    Thank you.
  • your coming file does not use the bltouch. ( missing g30 command instead of switch command)
    also the height map must be loaded after z=0 determination
    see
    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe
  • Ok did some changes, would you take a look a the new files. 🙂homeall.g config.g bed.g
  • there is no g30 in your home script.
  • @Thunder said in Z calibration offset:
    If you get in the habit of using the </> tag to post your gcode files then we don't have to download them to look at them.
    Here is your config.g file using the tag:
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 24 2020 20:05:38 GMT+0200 (Central European Summer Time)
    M550 P"My Printer"                                 ; set printer name
    M551 P"GoBevk"                                     ; set password
    M569 P0 S0                                         ; physical drive 0 goes backwards
    M569 P1 S0                                         ; physical drive 1 goes backwards
    M569 P2 S1                                         ; physical drive 2 goes forwards
    M569 P3 S1                                         ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                                   ; set drive mapping
    M92 X160.00 Y80.00 Z800.00 E837                   ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
    M906 X1400 Y1700 Z1400 E800 I50                    ; set motor currents (mA) and motor idle factor in per cent
    M84 S50                                       ; Set idle timeout
    M208 X500 Y500 Z500 S0                             ; set axis maxima
    M574 X1 Y1 Z1 S1                                   ; set active high endstops
    M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
    M574 X1 Y2 S1                                      ;  X home to min. Y home to max. Normally Closed limit switches
    M574 Z 1                                        ; Define Z to use Probe. Home to Min
    M558 P5 H5 F500 T4000 X0 Y0 Z1                     ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-66.4 Y-10.2 Z2.15                       ; set Z probe trigger value, offset and trigger height
    M557 X70:430 Y70:450 S50                           ; define mesh grid
    M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    Here is your homeall.g file using the tag:
    ; homeall.g
    ; called to home all axes
    G91                      ; relative positioning
    G1 H2 Z10 F24000          ; lift Z relative to current position
    G1 H1 X-505 Y-505 F12000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F24000       ; go back a few mm
    G1 H1 X-505 Y-505 F240   ; move slowly to X and Y axis endstops once more (second pass)
    G1 H1 Z-505 F240         ; move Z down stopping at the endstop
    G90                      ; absolute positioning
    G92 Z-5.10                 ; set Z position to axis minimum (you may want to adjust this)
    G1 Z10 F400              ; lift Z relative to current position
    Where is the your code to create the height map?
  • Ok, how about now ?[0_1612359597243_homeall (1).g](Uploading 100%)
  • @fcwilt Ok will do that 🙂
    Great.
    It looks like you attempted to post an updated homeall.g file but something went wrong.
  • ; homeall.g
    G1 X100 Y100 F2000 ; put head over the centre of the bed, or wherever you want to probe
    G30 ; lower head, stop when probe triggered and set Z to trigger height
    Here is my file, also i dont understand "Where is the your code to create the height map?" ? I was folowing this guide :link text
  • @fcwilt said in Z calibration offset:
    M574 Z 1
    I don't use v2 firmware but I think that command above should be M574 Z1 S2
    I don't think X100 Y100 is going to put your probe over the center of the bed which is really the best place.
    I guess you are issuing the G29 command from the DWC?
  • Yes, this is right. Ok, came home and started the machine and a couple of settings were wrong. Now I have managed the home all to touch the probe for z and started the G29 S0
    but I still get the same result. Can anybody point out what I am doing wrong? I am new to programming and this kind of setup.
    System
    My Printer
    g29 s0
    Status
    Busy
    Tool Position
    X
    346.4
    Y
    320.2
    Z
    7.15
    Extruder Drives
    Drive 0
    0.0
    Speeds
    Requested Speed
    3 mm/s
    Top Speed
    3 mm/s
    Sensors
    Vin
    12.0 V
    MCU Temperature
    28.4 C
    Fan RPM
    0
    Z-Probe
    0
     Tools
     Extra
     Control All
    Tool	Heater	Current	Active	Standby
    Tool 0
    T0 - Load Filament	Heater 1
    off	16.9 C
    0
    0
    Bed	Heater 0
    off	18.2 C
    0
    0
    Temperature Chart
    System Directory
    0:/sys/config.g
    ;Bl-touch heaters
    M574 X1 Y1 S1;                                   ; set active high endstops
    M574 Z1 S2;
    M558 P9 H5 F500 T4000 X0 Y0 Z1                     ; set Z probe type to bltouch and the dive height + speeds
    M557 X70:433.6 Y70:498.8 S30                           ; define mesh grid
    ; homeall.g
    ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sun Sep 15 2019 21:01:39 GMT+0200 (Central European Summer Time)
    G1 S1 X-500 Y-500 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 X5 Y5 F6000 ; go back a few mm
    G1 S1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
    G1 X250 Y250 F6000 ; go to first bed probe point and home Z
    G1 S2 Z20 F100 ; lift Z relative to current position
    Thanks in advance 🙂
  • And here is the picture 🙂
    For now that G1 command above is OK but it doesn't take into account the z probe X and Y offsets - so you're getting close to the center of the bed but you're not at the center.
    You have to be sure that G30 is setting the Z co-ordinate correctly before G29 will work as desired.
    So do the following:
    After the G30 in homeall.g comment out the G91 and the G1 commands.
    Run homeall.g and see what the Z co-ordinate readout in the DWC is after the execution of G30.
    Verify that it is correct either by measuring the gap between the nozzle and the bed OR jog down to Z=0 and see if the nozzle is just touching the bed.
    Let me know what you find.
  • Ok, I have now managed the calibration. But when I start the program from the slicer I get the Error: M375: Heightmap file bareplate.csv not found I think this means my startup code is not ok
    thank you 🙂
  • @Thunder
    Well you must have a command somewhere like this G29 S1 P"bareplate.scv".
    For that to work at some point you would have to created that file with G29 S3 P"bareplate.csv".
    Did you do so?
  • @fcwilt
    Ok i checked and you are right. In the startup i had a M375 command. I deleted the line and replaced the command with G29 S1. And now my next question if load the g code of a part for printing the machine homes and makes the printer use the height map that i did eariler with G29 S0. But my nozzle is stil a few 0.1 mm from build plate. Do i correct this with baby steps ?
    Thanks for all of your input 🙂
    And now my next question if load the g code of a part for printing the machine homes and makes the printer use the > height map that i did eariler with G29 S0. But my nozzle is stil a few 0.1 mm from build plate. Do i correct this with baby
    Refresh my memory please.
    When creating the height map do you have commands something like these:
    G90
    G1 Xaaa Ybbb ; move the z probe to the center of the bed
    G30          ; set the Z=0 datum
    G29          ; probe the bed and create the height map
    When loading the height map do you have commands something like these:
    G90
    G29 S1       ; load the height map
  • @fcwilt
    Yes like the last one, this code is in slicer start program.
    @fcwilt
    Great.
    How about when creating the height map?
    The G30 for creating and loading need to use the exact same X and Y position.
  • Do you mean in the home all section? Sorry I am a little slow when programing 🙂
    I don't know where you create the height map.
    I have a pair of files that I created called mech_comp_map_create.g and mesh_comp_map_load.g.
    The first is invoked from a DWC macro as I create the height map manually.
    The second is invoked from another file that I created called print_begin.g which is invoked by the slicer at the start of a print.
    The essential commands in mech_comp_map_create.g are below
    G90
    The essential commands in mech_comp_map_load.g are below
    G90
    The important thing to notice is that G30 must be used before creating (G29) or loading (G29 S1) the height map.
