Temp hotend not stop other limit and have error
Hi, have duet 2 wifi, version 1.0.4c original, and have this problem.
I if start charge filament, i set temp 190c start temp and not stop 190 and create error high temp 15c, have change cable, problem not solve.
For this not have start test my first print
Please post your config.g and the results of sending these commands in the console:
M122
andM98 P"config.g"
Have you done a PID auto tune of the heaters yet?
This can help prevent overshoot on heat up.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
@Phaedrux said in Temp hotend not stop other limit and have error:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N8PS4-6J9D0-3SJ6J-KATZR
Used output buffers: 1 of 24 (8 max)
Static ram: 25712
Dynamic ram: 92660 of which 340 recycled
Exception stack ram used: 312
Never used ram: 12048
Tasks: NETWORK(ready,676) HEAT(blocked,824) MAIN(running,3752) IDLE(ready,160)
Owned mutexes:
Last reset 00:21:19 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11968 bytes (slot 1)
Error status: 0
Free file entries: 10
SD card longest block write time: 2.8ms, max retries 0
MCU temperature: min 16.8, current 22.5, max 22.7
Supply voltage: min 23.6, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2021-02-04 11:26:22
Cache data hit count 3651532045
Slowest loop: 7.96ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 1 is on, I-accum = 0.1
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.77ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:5b:42:c5
WiFi Vcc 3.45, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26056
WiFi IP address 192.168.1.32
WiFi signal strength -63dBm, reconnections 0, sleep mode modem
=== Filament sensors ===
Extruder 0 sensor: ok
- WiFi -
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: M916: No resume file found
My print is delta
; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Feb 03 2021 14:20:11 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M83 ; ...but relative extruder moves; Impostazioni delta
M550 P"OTS Print Turbo Predator" ; set printer name
M665 R175 L430 B165 H431.70 ; imposta raggio delta, lunghezza asta diagonale, raggio stampabile e altezza home
M666 X0 Y0 Z0 ; metti qui le tue regolazioni del finecorsa; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S1 ; Motore X
M569 P1 S1 ; Motore Y
M569 P2 S1 ; Motore Z
M569 P3 S0 ; Motore Estrusore E0
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Retraction
M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction; Axis Limits
M208 Z0 S1 ; set minimum Z; Fine Corsa
M574 X2 Y2 Z2 S1 ; set active high endstops; Smart Effector
M558 P0 H25 F600 T4800 ; disable Z probe but set dive height, probe speed and travel speed
M557 R165 S40 ; define mesh grid; Rilevamento Filamento Interrotto
M591 P1 C3 S1 D0; Ripristino in Caso di Alimentazione Bassa
M911 S8.0: 19,5: 22,0 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"; Ripresa di Stampa in Caso di Alimentazione Interrotta
M916; Heaters
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 Hotbend
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 Hotend
M143 H1 S280 ; set temperature limit for heater 1 to 280c
;M570 H1 P4 T15 S0 ; Errore Riscaldatore Hotend
;M570 H0 P4 T15 S0 ; Errore Riscaldatore Hotbend;Calibrazione Hotend
; M303 H1 P1 T100000 S280 ; impostazione hotend ( H1 ) a piena potentza ( P1 ) termistore ( T ) valore temperatura ( S )
M302 S190 R110 ; Consentire l'estrusione a partire da 120 ° C e le retrazioni già da 110 ° C; Fans
M106 P0 S0.5 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
T0 ; select first tool; Memorizza
M500; Leggi Parametri
M501
@stefano said in Temp hotend not stop other limit and have error:
; Memorizza
M500
; Leggi Parametri
M501this is bad there should be no M500 in config.g
@Veti remove M500
now you need to pid tune again, because that has deleted the results of the pid tune
@Veti new auto tune ok. If not solve write
4/2/2021, 18:30:14 Warning: Auto tune of heater 1 failed due to bad curve fit (A=1970.5, C=166.0, D=5.6)
4/2/2021, 18:27:40 Auto tune phase 3, peak temperature was 325.5
4/2/2021, 18:27:30 Auto tune phase 2, heater off
4/2/2021, 18:27:00 Auto tune phase 1, heater on
4/2/2021, 18:26:54 M303 H1 S280
Auto tuning heater 1 using target temperature 280.0°C and PWM 0.80 - do not leave printer unattended
What thermistor do you have? These values may not be correct for your thermistor.
If you're unsure, try changing B4138 to B3950.
have thermistore HE3D
Based on a quick google it looks like B3950 should work better.
tomorrow change value and tell if have solve, have list with all code thermistore? have gcode for test thermistore o for see correct number
B3950
Have this error Warning: Auto tune of heater 1 failed due to bad curve fit (A=1636.8, C=129.8, D=6.1)
With that overshoot in temperature I have to wonder if it's a problem with using a 12volt heater cartridge on a 24volt system.
Can you please measure the resistance of the heater cartridge?
Are you sure the heater is 24v?
