Duet 3 HC6 one final try before i give up.
When i try to print there is allways a new issue, when i fix it the next time there are two more.
When trying to update firmware and stuff it results in an unresponsive printter and a hasle to reupload everything via usb.
Webcontrol has connection issues and a super slow speed 11-300KiB/s.
A list of things i have rules out not be the issue.
-All of the wiring is good, this has been tested many times.
-Micro sd is fine.
-Router is fine.
-Ethernet cable is fine.
-My pc is fine
-g.code is mostly fine, just cant change the ip configuration to static in the machine only in my router.
-Steppers are good.
-Bed and nozzle are good.
-Endstops and bltouch are good.
-Duet temps are stable 26c at idle 30-38c when printing.
-Fuzes are good.Thigs that it might be.
-Firmware
-Webcontroll
-The fact that i cant change the ip to statick in g.code.
-The board could be bad.Info.
M122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
Board ID: 08DJM-956L2-G43S4-6J1FL-3SJ6T-186QH
Used output buffers: 2 of 40 (23 max)
Static ram: 154604
Dynamic ram: 162784 of which 20 recycled
Exception stack ram used: 376
Never used ram: 75432
Tasks: NETWORK(ready,276) ETHERNET(blocked,404) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,196) MAIN(running,4512) IDLE(ready,76)
Owned mutexes:
Last reset 00:24:59 ago, cause: power up
Last software reset at 2021-01-29 22:57, reason: User, spinning module GCodes, available RAM 75264 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 23.1, current 23.3, max 23.4
Supply voltage: min 23.6, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Driver 0: standstill, reads 34723, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 34723, writes 0 timeouts 0, SG min/max not available
Driver 2: standstill, reads 34722, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 34723, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 34722, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 34722, writes 0 timeouts 0, SG min/max not available
Date/time: 2021-02-04 13:33:09
Slowest loop: 5.13ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 3.3ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Heater 0 is on, I-accum = 0.7
Heater 1 is on, I-accum = 0.6
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 5.77ms; fastest: 0.03ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 1 of 8Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 5 2 2 2 2 2 0 2 === CAN === Messages sent 29, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 1499565ms ago RX/TX seq numbers: 0/1 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0
M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 465C
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 10 2020 22:00:06 GMT+0300 (Itä-Euroopan kesäaika); General preferences
M550 P"Useless junk" ; set printer name; Network
M551 P"Sirsnip1337" ; set password
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X15600.00 Y15600.00 Z180.00 E3600.00 ; set maximum speeds (mm/min)
M201 X2800.00 Y2800.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X1100 Y1100 Z1100 E1197 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S120 ; Set idle timeout; Axis Limits
M208 X210 Y200 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y41 Z3.0 ; set Z probe trigger value, offset and trigger height
M557 X15:210 Y15:200 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T97700 B4619 C9.743561e-8 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S285 ; set temperature limit for heater 1 to 285C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out9" Q10 ; create fan 0 on pin out9 and set its frequency
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend/extruder" D0 H1 F0 ; define tool 0
T0 ; select first tool
-Your firmware is way out of date (and 3.1.1 was a s.show lol)
-M552: Set IP address, enable/disable network interface
Support Marlin RepRapFirmware Repetier Smoothie Klipper Prusa MK4duo MakerBot
Yes: 2.0.8 Yes No No ??? No Yes No
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa
No No No No No No No No
Parameters
Innn (Optional) Number of the network interface to manage (defaults to 0)
Pnnn IP address, 0.0.0.0 means acquire an IP address using DHCP
Snnn (optional) -1 = reset network interface, 0 = disable networking, 1 = enable networking as a client, 2 = enable networking as an access point (WiFi-enabled electronics only)
Rnnn (optional, RepRapFirmware 1.17 and earlier only) HTTP port, default 80
Example
M552 P192.168.1.14
Sets the IP address of the machine to (in this case) 192.168.1.14. If the S parameter is not present then the enable/disable state of the network interface is not changed.In RepRapFirmware 1.18 and later the HTTP port address is set using the M586 command, so the R parameter of this command is no longer supported.
M552 with no parameters reports the current network state and IP address.
that is to get a fixed IP.
Lost me at,
Parameters
ExampleWhat is all this yes no stuff? Allso any other ip result in a crash and a nightmare.
First thing that stands out, you’re missing the declaration of the kinematic style at the top. are you running a Cartesian, xy, or delta? The machine has no idea what to do. You need a M669 command
Allso is it possible to update 3.1.1 to 3.2 from webcontroll?
Since the update via usb takes around 4 hours to get the board out of its hideyhole and dont have a laptop to avoid ground loops.
@Snippy said in Duet 3 HC6 one final try before i give up.:
yes
see
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedurebut since you did the update to 3.1.1 not via web interface you might be missing the 3.0 files.
@Nuramori Never had any print quality issues, if it desides to load the gcode.
Its a cartesian system.
@Veti
O lord have mercy.
Sorry to hear you are having problems.
Could you provide me with brief list of the things that are not working for you?
I have a MBH6C board on my workbench at the moment and it is working fine. It's very likely I can get yours working for you as well.
I have printers running both 3.1.1 and 3.2.
@Snippy I just copi/pasted from the reprap gcode page, about how to use m552
WOW... the webcontroll update from 3.1.1 to 3.2 worked without a sacrifice.
Just so you know 3.2 has issues of it's own that occur in certain configurations that are somewhat uncommon.
@fcwilt was not supriced
Well the update seems to have increased the upload speed significantly.
allso now my independent twin print cooling systems seems to work.
