    Current speed greater than Max speed?
    Duet Web Control
    494
    • User3Dundefined
      User3D
      In DWC, I see top speed greater than my max speed set in config. How is this possible ?
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @User3D
        @User3D does your slicer issue any speed commands that override it?
        i3 clone with a bunch of mods
        User3Dundefined 1 Reply Last reply Reply Quote 0
        • User3Dundefined
          User3D @engikeneer
          @engikeneer I just checked gcode file and found out that it does contain command to set feedrate to a greater value.
          When I am setting max speed using M203 then speed should not go beyond it irrespective of whatever feedrate I set in G1 Fnnn .
          • deckingmanundefined
            deckingman @User3D
            @User3D Can you share your config.g file and config_overide.g file if you use one. Also, the section of the gcode file that you are printing up to the first few print moves. Better still, upload the entire gcode file to Dropbox or Google drive so that we can see the whole thing. And tell us what max speed DWC is reporting while doing that print.
            • User3Dundefined
              User3D @deckingman
              @deckingman I even observed today that when I don't set feedrate and run my axes , it takes feedrate set in paneldue. That feedrate is 6000 and my max speed is 5100 and on giving commands, axes are actually going upto 6000 (confirms DWC). This should not happen.
                1. Post your config.g file.
                2. After observing the speed being higher than you think you have set, send M203 without parameters to see what speed limits it reports.
                • User3Dundefined
                  User3D @dc42
                  @dc42 M203 it reports correct values only .
                  Config:
                  G90                                     ; send absolute coordinates...
                  M83                                     ; ...but relative extruder moves
                  M552 P192.42.42.20 S1                   ; enable network
                  M586 P0 S1                              ; enable HTTP
                  M586 P1 S0                              ; disable FTP
                  M586 P2 S0                              ; disable Telnet
                  M551 P"DUET"							; set Password
                  G4 S1
                  M569 P40.0 S1                             ; physical drive 0 goes forwards
                  M569 P41.0 S1                             ; physical drive 1 goes forwards
                  M569 P0.2 S1                              ; physical drive 2 goes forwards
                  M569 P0.3 S1                              ; physical drive 3 goes forwards
                  M584 X40.0 Y41.0 Z0.2:0.3 E0.4            ; set drive mapping
                  M350 X8 Y8 Z16 E16 I1				      ; set microstepping with interpolation
                  M92 X400.00 Y400.00 Z800.00 E415.00       ; set steps per mm (motor : 1.8 + leadscreaw + TR4)
                  M566 X300 Y300 Z120.00  E300.00     	  ; set maximum instantaneous speed changes (mm/min)
                  M203 X5100.00 Y5100.00 Z1800.00 E6000.00  ; set maximum speeds (mm/min)
                  M201 X300.00 Y300.00 Z55.00 E350.00    	  ; set accelerations (mm/s^2)
                  M906 X2800 Y2800 Z800 E800 I30            ; set motor currents (mA) and  motor idle factor in per cent
                  M84 S30                                   ; Set idle timeout
                  M208 X0 Y0 Z0 S1                          ; set axis minima
                  M208 X290 Y290 Z290 S0                    ; set axis maxima
                  M574 X1 S1 P"40.io0.in"                   ; set active high the low endstop : X
                  M574 Y1 S1 P"41.io0.in"                   ; set active high the high endstop : Y
                  M574 Z1 S1 P"io3.in"                      ; set active high the low endstop : Z
                  ; Filament sensor
                  M591 D0 P2 C"io5.in" S1					  ; configure filament sensor at io_5
                  M950 J1 C"io5.out"
                  M581 P1 T2 R0 S1 				          ; trigger2.g on filament loading
                  ; Z-Probe : BL-Touch
                  M558 P9 C"io4.in" H8 F120 T3000			  ; configure BL-Touch on IO pin - 4
                  M950 S0 C"io4.out"
                  G31 P25 X0 Y60 Z0						  ; set x,y and z offset of bl-touch from printhead
                  M557 X15:275 Y130:300 S80                ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138    ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0							    ; create bed heater o/p on out0 and it map it to sensor 0
                  M307 H0 A33.3 C56.2 D1.9 S1.00 V23.9 B0         ; enable bang-bag mode and set gain,const time ,dead time,PWM,voltage.  unTuned->M307 H0 B0 S1.00
                  M143 H0 S150									; set temperature limit for heater 1 to 150C
                  ;Extruder
                  M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7    ;configure sensor 1 as thermistor on pin temp1 for type SLICE ENGINEERING
                  M950 H1 C"out1" T1 											;create nozzle heater output on out1 and map it to sensor 1
                  M307 H1 B0 S1.00											;disable bang-bang mode for heater and set PWM limit
                  M143 H1 S390                                                ;set temperature limit for heater 1 to 280C
                  M563 P0 S"Extruder" D0 H1 F0            ; define tool 0
                  G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                  G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                  M575 P1 S1 B57600                         			; for panelDue support
                  M280 P0 S160  									 	; set push-pin alarm release
                  M501			   			                        ; run config-override.g
                  T0 												    ;select tool 0 (here, extruder)
                  M140 H0 S45											; set bed heater temerature to 45c
                  M911 S20 R22.7 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F700"   ; set voltage thresholds and actions to run on power loss
                  Config-override :
                  ; config-override.g file generated in response to M500
                  ; Heater model parameters
                  M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  ; Workplace coordinates
                  G10 L2 P1 X0.00 Y0.00 Z0.00
                  G10 L2 P2 X0.00 Y0.00 Z0.00
                  G10 L2 P3 X0.00 Y0.00 Z0.00
                  G10 L2 P4 X0.00 Y0.00 Z0.00
                  G10 L2 P5 X0.00 Y0.00 Z0.00
                  G10 L2 P6 X0.00 Y0.00 Z0.00
                  G10 L2 P7 X0.00 Y0.00 Z0.00
                  G10 L2 P8 X0.00 Y0.00 Z0.00
                  G10 L2 P9 X0.00 Y0.00 Z0.00
                    Please provide a screenshot of DWC showing excessive speed. If your PC runs Windows then you can use shift-Win-S to do freeze the screen and get a screenshot. Also a shot of the M203 report please.
                    Which firmware version are you using?
                    • User3Dundefined
                      User3D @dc42
                      @dc42 FIRMWARE VERSION-3.3beta
                      PANELDUE - 3.2.9
                      DWC - 3.2.0
                      DWC output: (current speed = 100 > max speed) :
                      PanelDue feedrate setting:
                      Before running axes:
                      After:
                        What was the move that you are executed? If it's a Cartesian machine, then as both X and Y can move at 5100mm/min simultaneously, the combined speed of a diagonal move can be higher, up to 5100 * sqrt(2) for a move at 45 degrees.
                        User3Dundefined 1 Reply Last reply Reply Quote 2
                        • User3Dundefined
                          User3D @dc42
                          @dc42 said in Current speed greater than Max speed?:
                          G1 X290 Y290 G1 X0 Y0
                          Got it. This is happening on diagonal moves only. Thank you.
