    Paneldue5" kills VIN
    Using Duet Controllers
    59
    • TomasL
      TomasL last edited by
      When I connect the panel due to duett2 VIN dropps dramatically, and DUETT2 refuses to run any motors.
      Without the panel VIN according to webinterface is 12V
      When the panel is connected VIN dropps to 8,5V
      Powersupply measures to 12V regardles.
      So, whats wrong, and how do I fix it?
      • caviara
        caviara last edited by
        What happens if you connect PanelDue via USB?
        (disconnected from the printer)
        • felek
          felek last edited by felek
          @TomasL Does PanelDue work normally?
          Do not connect PanelDue to the computer. It can damage your usb port. Max current is 500mA.
          Let's use multimeter to check VIN and GND is shorted.
          • Veti
            Veti last edited by
            how are you donnecting due paneldue?
            did you try the 4 pin cable?
            • alankilian
              alankilian last edited by
              @felek said in Paneldue5" kills VIN:
              That's how I reprogram the PanelDue each time.
              I've never had a problem doing it.
              If your PC does not have USB over current protection built in I guess it could cause a problem if you short something on the PanelDue, but just plugging it in to reprogram it shouldn't be a problem at all.
              The 7" paneldue draws 650 mA so that might trip an overcurrent on some PCs.
                dc42 administrators @alankilian last edited by
                @alankilian said in Paneldue5" kills VIN:
                That's true; but normally it just causes the PC or laptop to shut off power to the USB port.
                alankilian 1 Reply Last reply Reply Quote 0
                • alankilian
                  alankilian @dc42 last edited by
                  @dc42 I should have said "... might trip the USB overcurrent sensing on some PCs..."
                  That would have been more clear.
                  • TomasL
                    Well, since I am a brilliant engineer, I dont need to read any documentation, since everything is perfectly clear, well, not so.
                    I managed to put the ribbon vable in the wrong connectore, moving it from "LCD" to SD" solved the thing.
                    • alankilian
                      Ha ha!
                      I've done things like that also.
                      When I really try, I can get a USB keyboard plugged into the HDMI connector on my laptop.
