    M307 in startup gcode gives heater over-powered warnings
    220
    • DanS79
      DanS79 last edited by
      I want to experiment with custom M307 commands for my various slicer profiles so i added some to my startup gcode, but I now get annoying warnings at the start of every print.
      Warning: Heater 0 appears to be over-powered.   .....
      Warning: Heater 1 appears to be over-powered.   .....
      I have defaults in config.g but no M501 at the end.
      I thought maybe adding some combination of M500, and M502 to my startup gcode would make the warnings go away, but I've had no luck.
      Is there nothing i can do to make the warning go away?
      • A Former User
        A Former User last edited by
        The warning is about the (available) power and potential maximum temperature of left on at 100% power due to a fault. so you'll need to change the heater (or heatloss) to get rid of the warning
        DanS79 1 Reply Last reply Reply Quote 0
        • DanS79
          DanS79 @Guest last edited by
          @bearer said in M307 in startup gcode gives heater over-powered warnings:
          I'm pretty confident that not the issue, as the parameters used are from pid tuning the heaters using M303.
          Additionally If I remove the M307 from my startup gcode and put them in config.g (the exact same commands) i get no warnings.
          It seems like the firmware doesn't like Having M307 in config.g and in the gcode file for a print at the same time.
          I should add I've validated it's using the parameters set in the start up gcode, even though it gives the warning.
          I think either i'm missing something, or this is an edge case bug.
          A Former User 1 Reply Last reply Reply Quote 0
          • Veti
            Veti last edited by
            see
            https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
            • DanS79
              DanS79 @Veti last edited by
              @Veti said in M307 in startup gcode gives heater over-powered warnings:
              see
              That's a little ambiguous, because as I mentioned above if I set them in config.g I get no warning.
              engikeneer 1 Reply Last reply Reply Quote 0
              • Veti
                Veti last edited by
                update to 3.2 and you wont get the message
                • DanS79
                  What does 3.2 do to make them go away?
                  • Veti
                    Veti last edited by
                    introduce a new heater tuning
                    • DanS79
                      That seems unlikely. If it was related to the algorithm, i'd expect it to complain no matter how the parameters where loaded.
                      • DanS79
                        For @dc42 or any of the other developers you might look at this.
                        Board: Duet WiFi 1.02 or later + DueX5
                        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
                        Duet WiFi Server Version: 1.23
                        • A Former User
                          A Former User @DanS79 last edited by
                          @DanS79 said in M307 in startup gcode gives heater over-powered warnings:
                          You still get the warning, it's just a one time thing at boot instead of each print
                          • A Former User
                            @bearer said in PanelDue 7i - warning message at start-up:
                            const float noWarnTemp = (temperatureLimit - NormalAmbientTemperature) * 1.5 + 50.0; // allow 50% extra power plus enough for an extra 50C
                            not sure if that panned out for that guy, but the issue is the firmware has calculated the theoretical maximum temperature for the heater if left on, and if that exceeds the formula above the warning is issued ... so in theory increasing the allowable temperature so the noWarnTemp becomes higher than what the warning is for then no warning (maybe)
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M143_Maximum_heater_temperature
                            • deckingman
                              deckingman @DanS79 last edited by
                              @DanS79 The warning is just that. It's a warning that the heater is over powered and so, if a MOSFET was to fail, there is a potential fire hazard. IIRC, it was introduced a few years back, along with a couple of other features when a user did in fact have such a fire, and complained that the firmware did not report that the hazard existed. IIRC, the other features which were introduced at the same time were checking for erratic temperature excursions which might indicate that a heater cartridge had fallen out or other such potential faults.
                              So you might find a way to remove the "annoying" warning, but you'll be left with the fundamental problem of using over powered heaters and the potential fire hazard that causes. You might find that a fire will be somewhat more annoying than the warning message. If I were part of the Duet team, and because we live in a world of litigation, I would most certainly not remove what is essentially a safety feature from the firmware because a user with over powered heaters found the warning message annoying.
                              • engikeneer
                                engikeneer @DanS79 last edited by
                                @DanS79 I would also add that you won't see the warning when in config.g because it is run at boot, so dwc hasn't started yet so you won't see the message. If you run M98 P"config.g" from console, it will re run your config file and you will see the warning message.
                                You will also have seen the warning message when you originally tuned the heaters.
                                i3 clone with a bunch of mods
                                • DanS79
                                  DanS79 @engikeneer last edited by
                                  @engikeneer said in M307 in startup gcode gives heater over-powered warnings:
                                  I tried the M98, and did indeed get the warnings. Yes, I got them when i did the pid tune, but thats really the only place I would expect to see them.
                                  Everytime they get loaded is almost like annoyware imo.
                                    Phaedrux Moderator @DanS79 last edited by
                                    Does the seatbelt light in your car annoy you too?
                                    DanS79 deckingman 2 Replies Last reply Reply Quote 0
                                    • DanS79
                                      DanS79 @Phaedrux last edited by DanS79
                                      @Phaedrux said in M307 in startup gcode gives heater over-powered warnings:
                                      Yes, and while i can't disable the light I did disable the annoying chime....
                                      • A Former User
                                        did you even try M143 or are you confident enough to complain without trying it?
                                        DanS79 2 Replies Last reply Reply Quote 0
                                        • Veti
                                          Veti last edited by
                                          he just wants to complain
                                          • DanS79
                                            This post is deleted!
                                            • DanS79
                                              I did the math and that would require raising the HE limit to 582°C. That's well above even the theoretical maximum recommended by the manufacture, so i disregarded that as an option.
                                              dc42 A Former User 2 Replies Last reply Reply Quote 0
                                              • DanS79
                                                You can shove off!
                                                  dc42 administrators @DanS79 last edited by
                                                  In that case, the estimated hot end temperature reached if you were unlucky enough to get a stuck heater would be even more above the manufacturer's recommended limit, probably enough to melt the heater block if it is aluminium.
                                                  • A Former User
                                                    lol, its not gonna change the teperature to set the m413 before and after m307 ... you'll still have an overpowered heater if you do or you don't.
                                                    think of it like printing a dummy seatbelt clip to get rid of the pesky sounds in the car...
                                                    • DanS79
                                                      DanS79 @dc42 last edited by
                                                      @dc42 said in [M307 in startup gcode gives heater over-powered warnings]
                                                      It's an E3D copper block, so its recommended max is 500°C.
