Error: Attempting to extrude with no tool selected.
Hello everyone after updating to 3.2 every time a part prints i have an error and the filament stopped coming out and printing continues without filament any idea?
Thank you allM0 H1
Error: Attempting to extrude with no tool selected.Error: Attempting to extrude with no tool selected.
config.g; General preferences M80 ; Turns on the ATX power supply G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M550 P"sgk008" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M669 K1 ; select CoreXY mode ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z M591 D0 P1 C"e0stop" S1 ; configure filament runout sensor for high end on extruder drive 0 via pin i03.in M575 P1 S1 B57600 ; Set things up for the PanelDue ; Filament sensor M591 D0 P1 C3 S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0 ; Drives M569 P0 S0 ; Drive 0 goes backwards blv: its was S1 M569 P1 S0 ; Drive 1 goes backwards blv: its was S1 M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes backwards WAS 0 M569 P4 S0 ; Drive 4 goes forwards M584 X0 Y1 Z2:4 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X200 Y200 Z400 E429.71 ; Set steps per mm for Bondtech. M566 X600 Y600 Z1000 E200 ; Set maximum instantaneous speed changes (Jerk) (mm/min) M203 X20000 Y20000 Z600 E2000 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Pressure advance M572 D0 S0.05 ; disabled Pressure advance ; Axis Limits M208 X-23 Y0 Z0 S1 ; Set axis minima M208 X320 Y321 Z350 S0 ; Set axis maxima ; Z-Probe M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor G31 P500 X-2 Y-16.4 Z0.310 ; Set Z probe trigger value, offset and trigger height M557 X20:270 Y20:270 S240 ; Define mesh grid ; Heaters M307 H0 R0.288 C376.3 D10.07 S1.00 V23.6 ; Set PID for heated bed values M307 H1 R2.229 C128.4 D8.73 S1.00 V23.9 ; Set PID for hotend values M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 R4700 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C0.0000000706 R4700 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S260 ; set temperature limit for heater 0 to 260C M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor ; Tools M563 P0 S"Some Printhead" D0 H1 F1 ; define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Access point is configured manually via M587 by the user ;M586 P0 S1 ; Enable HTTP ;M586 P1 S1 ; Enable FTP ;M586 P2 S1 ; Enable Telnet ;Hot End fan tool M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"HE Fan" S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on 100% at 45deg ;Tool Fan/ Layer Fan M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off ;MB cooling fan layer M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 C"MB Fan" S1 H2 T35:55 ; set fan 2 value. Thermostatic control is turned on Temp Range of 35 - 55 deg ; Custom settings M572 D0 S0.275 ; Set bowden extruder elasticity compensation for E0 M572 D1 S0.275 ; Set bowden extruder elasticity compensation for E1 M207 S4.0 F2400 Z0.075 ; Set firmware retraction parameters ; Scanner support (debug) ;M750 ; Set up DHT sensor on channels 101-102 ;M305 P101 X405 S"DHT temperature" T11 ;M305 P102 X455 S"DHT humidity [%]" T11 ; Automatic power saving M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss ; Custom settings are not configured M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons ; Miscellaneous M501 ; load saved parameters from non-volatile memory T0 ; select first tool
Please post your config.g and an example print (or at least the first layer of an example print)
Sounds like you don't have a tool selected at the start of a print.
Usually you'd add a T0 to the end of config.g and/or to the slicer start gcode.
Can you post an example gcode file?
Also the results of M122 and M98 P"config.g" please.
It's done with all the gcode files and all the slices
M122
=== Diagnostics === RepRapFirmware pour Duet 2 WiFi / Ethernet version 3.2 fonctionnant sur Duet WiFi 1.02 ou version ultérieure ID de carte: 08DGM-9T6BU-FG3S8-6JKDJ-3SN6S-1SLHH Tampons de sortie utilisés: 3 sur 24 (9 max) = == RTOS === RAM statique: 23460 RAM dynamique: 73620 dont 40 recyclées Jamais utilisé RAM 14960, pile système libre 191 mots Tâches: NETWORK (ready, 241) HEAT (bloqué, 307) MAIN (running, 448) IDLE ( prêt, 19) Mutex possédés: WiFi (NETWORK) === Plate-forme === Dernière réinitialisation il y a 00:00:28, cause: mise sous tension Heure de réinitialisation du logiciel inconnue, raison: Utilisateur, GCodes tournant, RAM disponible 14900, emplacement 1 Code de réinitialisation du logiciel 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Tâche MAIN Freestk 0 n / a État d' erreur: 0x00 Erreurs Aux0 0,0,0 Température MCU: min 17,1, courant 19,7, max 20,2 Tension d'alimentation: min 23,8, courant 24,0, max 24,2, événements de sous-tension: 0, événements de surtension: 0, puissance bonne: oui Driver 0: position 0, arrêt, SG min / max non disponible Driver 1: position 0, arrêt, SG min / max non disponible Driver 2: position 0, arrêt, SG min / max non disponible Pilote 3: position 0, arrêt, SG min / max non disponible Pilote 4: position 0, arrêt, SG min / max non disponible Pilote 5: position 0 Pilote 6: position 0 Pilote 7: position 0 Pilote 8: position 0 Pilote 9: position 0 Pilote 10: position 0 Pilote 11: position 0 Date / heure: 2021-02-10 22:54:56 Nombre de succès des données du cache 34262637 Boucle la plus lente: 4,72 ms; plus rapide: 0.20 ms erreurs I2C nak 0, délais d'envoi 0, délais de réception 0, finishTimeouts 0, réinitialisation 0 === Stockage === Entrées de fichiers gratuites: 10 carte SD 0 détectée, vitesse d'interface: 20,0 Mo / s Lecture la plus longue de la carte SD temps 2,6 ms, temps d'écriture 0,0 ms, nombre maximum de tentatives 0 === Move === DM créés 83, maxWait 0ms, compensation de lit en cours d'utilisation: aucune, compensation de compensation 0,000 === MainDDARing === Mouvements programmés 0, mouvements terminés 0 , hoquet 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Mouvements programmés 0, coups terminés 0, hoquet 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Chauffe-lits = 0 -1 -1 -1, ChamberHeaters = -1 -1 -1 -1 Le chauffage 1 est allumé , I-accum = 0.0 === GCodes === Segments à gauche: 0 Verrou de mouvement maintenu par null HTTP est inactif dans l'état (s) 0 Telnet est inactif dans l'état (s) 0 Le fichier est inactif dans l'état (s) 0 L' USB est inactif dans l'état (s) 0 Aux est inactif dans l'état (s) 0 Le déclencheur est inactif dans l'état (s) 0 La file d'attente est inactive dans l'état (s) 0 L' écran LCD est inactif dans l'état (s) 0 Le démon est inactif dans l'état (s) 0 L' autopause est inactif dans l'état (s) 0 La file d'attente de codes est vide. === Réseau === Boucle la plus lente: 15,72 ms; le plus rapide: 0,00 ms États du répondeur: HTTP (0) HTTP (0) HTTP (0) HTTP (0) FTP (0) Telnet (0), 0 session Sessions HTTP: 1 sur 8 - WiFi - L'état du réseau est actif Le module WiFi est connecté au point d'accès Messages d'échec: en attente 0, pas prêt 0, noresp 0 version du micrologiciel WiFi 1.25 WiFi adresse MAC 84: f3: eb: e3: f6: ac WiFi Vcc 3.42, raison de réinitialisation Mettre sous tension la taille du flash WiFi 4194304, tas gratuit 27248 WiFi Adresse IP 192.168.1.24 Puissance du signal WiFi -51dBm, mode 802.11n, reconnexions 0, modem en mode veille Registre d'horloge 00002002 États des prises : 4 0 0 0 0 0 0 0
edit
M98 P "config.g"
Warning: Macro file "config.g" not found
@sgk said in Error: Attempting to extrude with no tool selected.:
M98 P "config.g"
No space between the P and "
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: in file macro line 30 column 13: M591: string expected
Error: Invalid extruder number '1'
Warning: Macro file config-override.g not found
For the first error with the sensor, you need to provide the actual pin name instead of C3
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M591_RepRapFirmware_Num_3
How do you have it connected? It should be C"e0stop" if you were using the e0 endstop pin for example.
For the second error, you have two extruders configured for pressure advance, but you only have a single extruder defined. So remove that entry entirely.
It would still be useful to see an example gcode file so we can see what is happening at the start of a print. If the file is too large to share, you can copy and paste the first 50 lines or so, or host it on dropbox or something.
I have only one extruder
So then remove
that I delete
M572 D0 S0.05
and this
M591 E1 P1 C3 S1
M591 E1 P1 C3 S1
You need to change C3 to be C"PINNAME" where the pin name is whatever pin you are connecting your sensor to. E0stop for example.
I'm sorry
I'm a beginner
the sensor of what
M591 D0 P1 C"E0" S1
like that
connecting the extruder to the duet card
i have 2x this
M591 D0 P1 C"e0stop" S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0M575 P1 S1 B57600 ; Set things up for the PanelDue
; Filament sensor
M591 D0 P1 C"E0stop" S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0
maybe i had a mistake
Phaedrux
thank you very much for your help
i will try now
thanks again
Are you still getting this error?
great it works thank you
infinitely for your help
now more than knowing how to get good quality, I have been looking for 1 year for how to get good quality.
