    Wire length spec's
    59
    • specktech
      specktech last edited by
      Hi Duet users and creators, I was wondering if it is okay to lengthen the wire's off my Duet board to around 5 feet. Putting my printer into a containment box. And by having about 5 feet of wire I will have options for the placement of my electronics. Also does the duet have any problems with EMF? Thanks for any info. Peace out.
        dc42 administrators @specktech last edited by
        Which wires in particular?
        specktech 1 Reply Last reply Reply Quote 0
        • specktech
          specktech @dc42 last edited by
          @dc42 All of them.... Putting my Ultimate Xl into a containment box. So all the wires have to be longer. Any ideas?
          • specktech
            specktech @specktech last edited by
            @specktech But my power supply will basically be in the same box. So the power will be close to the Duet. Thought I better check before I complete my re-wire. I will make sure to have a nice buffer/space between the boards.
            • specktech
              Want to make sure i am explaining my project correctly. My printer has a Duet 2 wifi on one side and a 24 volt power supply on the other side. Going to put both the duet and the power supply into one box. This electronic box will sit alongside my containment box. I was thinking about 5 feet of wire would allow me to position the electronic box in a few different locations around my printer. I think everything will be just fine. But just wanted to check.
              • jens55
                jens55 last edited by
                For what it's worth, I have a Duet2 and expansion card running on a 24V supply and other than connector problems were the printer cables join the extension wires, I have not had an issue that I know of. All the issues I have had were normal issues that would have occurred one way or another.
                I suspect that my cables are in the 5 -6 ft range.
                specktech 1 Reply Last reply Reply Quote 1
                • specktech
                  specktech @jens55 last edited by
                  @jens55 Thank you for the nice reply. I really appreciate that info. This little duet board sure is amazing. Peace out.
                  • o_lampe
                    o_lampe last edited by
                    @specktech
                    just make sure the extension wires have the biggest diameter you can crimp the connectors to. And also make sure they are braided or twisted.
                    For sensors I had good results with shielded CAT5 network cable.
