    looking for gt2 pulleys
    3D Printing General Chat
    455
    • hackinistratorundefined
      hackinistrator
      for 9mm belts , with 6.35 or 8mm inner diameter (nema23 motors)
      the only place i can find them is on aliexpress or banggood . not sure if the quality is ok . any experience ?
      thanks
        jay_s_uk @hackinistrator
        @hackinistrator the ones from the Mellow store I got for my coreXY are good quality
        hackinistratorundefined 1 Reply Last reply Reply Quote 0
          hackinistrator @jay_s_uk
          @jay_s_uk is that aliexpress store?
          i'll check them out thanks
          • fcwiltundefined
            fcwilt
            Would pulleys that might be 10mm work?
            On AliExpress I purchased a number of items from POWGE.
            They were listed in one place as 9mm and in another as 10mm.
            • sebkritikelundefined
              sebkritikel
              GT2 or 2GT?
              GT2, 2mm pitch (Technically the link below is is GT3, GT2/GT3 does not indicate pitch, rather it indicates series. GT2/GT3 pulleys are identical) - starts at 24mm for 6.35mm shaft
              https://us.misumi-ec.com/vona2/detail/110303273930/?curSearch={"field"%3A"%40search"%2C"seriesCode"%3A"110303273930"%2C"innerCode"%3A""%2C"sort"%3A1%2C"specSortFlag"%3A0%2C"allSpecFlag"%3A0%2C"page"%3A1%2C"pageSize"%3A"60"%2C"00000029798"%3A"mig00000001419862"%2C"00000331192"%3A"6.35"}&Tab=wysiwyg_area_0
              GT2/GT3, 8mm - starts at 26 teeth:
              https://us.misumi-ec.com/vona2/detail/110303273930/?curSearch={"field"%3A"%40search"%2C"seriesCode"%3A"110303273930"%2C"innerCode"%3A""%2C"sort"%3A1%2C"specSortFlag"%3A0%2C"allSpecFlag"%3A0%2C"page"%3A1%2C"pageSize"%3A"60"%2C"00000029798"%3A"mig00000001419862"%2C"00000331192"%3A"8"}&Tab=wysiwyg_area_0
              2GT, 6.35mm - starts at 32 teeth:
              https://us.misumi-ec.com/vona2/detail/110302193470/?CategorySpec=00000029797%3A%3Aaf&curSearch={"field"%3A"%40search"%2C"seriesCode"%3A"110302193470"%2C"innerCode"%3A""%2C"sort"%3A1%2C"specSortFlag"%3A0%2C"allSpecFlag"%3A0%2C"page"%3A1%2C"pageSize"%3A"60"%2C"00000029798"%3A"mig00000001419862"%2C"00000331144"%3A"6.35"%2C"00000029797"%3A"af"}&Tab=wysiwyg_area_0
              2GT, 8mm - starts at 32 teeth as well.
              https://us.misumi-ec.com/vona2/detail/110302193470/?CategorySpec=00000029797%3A%3Aaf&curSearch={"field"%3A"%40search"%2C"seriesCode"%3A"110302193470"%2C"innerCode"%3A""%2C"sort"%3A1%2C"specSortFlag"%3A0%2C"allSpecFlag"%3A0%2C"page"%3A1%2C"pageSize"%3A"60"%2C"00000029798"%3A"mig00000001419862"%2C"00000331144"%3A"8"%2C"00000029797"%3A"af"}&Tab=wysiwyg_area_0
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
                hackinistrator @fcwilt
                @fcwilt 10mm is ok for 9mm belt
                fcwiltundefined 1 Reply Last reply Reply Quote 1
                • fcwiltundefined
                  fcwilt @hackinistrator
                  @hackinistrator said in looking for gt2 pulleys:
                  Here is a link to where I ordered my 20 tooth pulleys. They have a wide selection of such items.
                  POWGE Pulleys
                    hackinistrator
                    i bought from mellow store , thanks guys .
                    i have another question - i own kollmorgen powermax 2 motors , model m22nrxb . unfortunately they come with imperial shaft with key . the shaft is 3/8" diameter . any chance to find a suitable pulley for this shaft and a 9mm 2gt gates belt?
                    i can get away using couplings , not sure if its worth it over regular stepperonline nema23 motors .
                    • Vetiundefined
                      Veti
                      https://www.electromate.com/m22nrxb-l/
                      this says the shaft is 0.25 inch.
                        hackinistrator @Veti
                        @Veti there is custom config available for those motors , i have dual shaft 3/8"
                        see here http://www.portalnaukowy.edu.pl/allegro/powermax22.pdf
                        • Vetiundefined
                          Veti
                          i think your best bet is to ask the stepper motor manufacturer if they make them.
