    Pressure Advance:Duet Wifi Ender 3 double print time
    451
    • ProntoPrintundefined
      ProntoPrint
      I have printed a shell on different printers all the same parameters in prusa except different Printer with different hardware and this one with duet wifi.
      So all printing parameter remain the same except the printer specific
      printtime difference:
      other printers 8-9 hours
      Ender 3 Duet wifi
      about 17 hours!!!!!
      The only thing I can see is Pressure Advance on the duet wifi.
      What I can see by eye during movement it seems the speed is as on the other printer,but
      sometimes it nearly comes to a halt (I think at layer change)
      Does anybody have experiences with "Pressure Advance" take massiv more print time!?
      engikeneerundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        post your config
          ProntoPrint
          I have set it in the start gcode , anyway attached both start gcode and config.g:?
          G28 ;Home all
          ;G91
          ;G1 Z10 F6000 ; lift Z relative to current position
          ;G90 ; Make sure we are in absolute mode
          ;G1 X150 Y122 F6000 ;Fahre zur Mitte des Betts
          ;G30 ; Do a Single probe to home Z axis
          M572 D0 S0.55 ; Pressure Advance Duet Wifi
          ;M593 F40.0 ; cancel ringing at 40.0Hz Dynamic Acceleration Adjustment (DAA)
          Config.g:
          Ender3ProDuetWifi
          Send code...
          Status
          Printing
          Mode: FFF
          Tool Position
          X
          150.0
          Y
          135.0
          Z
          6.50
          Extruder Drives
          Drive 0
          0.0
          Speeds
          Requested Speed
          0 mm/s
          Top Speed
          0 mm/s
          Sensors
          Vin
          23.6 V
          MCU Temperature
          23.7 C
          Z-Probe
          0
          Tools
          Extra
          Control All
          Tool Heater Current Active Standby
          Tool 0
          T0 - Load Filament Heater 1
          active 222.1 C
          225
          225
          Bed Heater 0
          active 65.1 C
          65
          0
          Temperature Chart
          System Directory
          0:/sys/config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sat Nov 28 2020 19:48:11 GMT+0100 (Mitteleuropäische Normalzeit)
          M550 P"Ender3ProDuetWifi" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P3 S0 ; 3dp Extruder reverse physical drive 3 goes backward
          M92 X80.00 Y80.00 Z400.00 E131.00 ; set steps per mm E Basis 95
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X235 Y230 Z250 S0 ; set axis maxima
          M574 Z1 S2 ; configure active-high endstop for low end on Z via BLTouch
          ;M574 Z1 S1 P"zstop" ; org configure active-high endstop for low end on Z via pin zstop
          ; Z-Probe Achtung Reprap V3!
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
          M950 S0 C"exp.heater7"
          ;----------------------Trigger-------------------------
          G31 P500 X-40 Y-12 Z1.50 ; Set Z probe trigger value, offset and trigger height je GROESSER desto NAEHER DRAN
          M557 X35:235 Y35:200 S40 ; Define mesh grid S40 bedeutet die Grid-Messpunkte sind 40mm voneinenander entfernt
          M671 X35:200:200:35 Y200:200:35:35 P0.5 ; point1 (35,200), point2 (200,200), point3 (200,35), point4 (35,35)
          ;M308 S0 P"bedtemp" Y"thermistor" T107600 B4183 R4700 ; configure sensor 0 as thermistor on pin bedtemp
          ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; Umbau Silikonheizbett NTC 3950 100kOhm configure sensor 0 as thermistor on pin bedtemp
          ;M307 H0 B0 S1.00 ; diable bang-bang mode for the bed heater and set PWM limit "B1 is on"
          M307 H0 P558.6 I136.699 D327.8 B0 S1.00 ; diable bang-bang mode for the bed heater and set PWM limit "B1 is on"
          M143 H0 S135 ; set temperature limit for heater 0 to 120C
          M143 H1 S280 ; set temperature limit for heater 1 to 250C
          M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
          • engikeneerundefined
            engikeneer @ProntoPrint
            @ProntoPrint post your config.g
            I'd look at your speed/accel/jerk settings for all axes. And compare to what the other printers are set at (remembering the different units!) If they're too low for your extruder, then that will become the limiting factor at some points (e.g. pressure advance, retraction etc) and slow things down. Also, if its too low for Z, things like layer changes will be slower. Are you using 'retract on layer change' and do you have any z hop enabled?
            i3 clone with a bunch of mods
              droftarts administrators @ProntoPrint
              @ProntoPrint said in Pressure Advance:Duet Wifi Ender 3 double print time:
              M572 D0 S0.55
              Have you tuned your pressure advance? S0.55 is a lot unless you have a long Bowden Tube. See https://duet3d.dozuki.com/Wiki/Pressure_advance
              See the side effects here, particularly related to extreme jerk: https://duet3d.dozuki.com/Wiki/Pressure_advance#Section_Side_effects_of_enabling_pressure_advance
                jay_s_uk
                On my ender 3 using the stock length bowden tube, I have a pressure advance value of 1.3
                ProntoPrintundefined 1 Reply Last reply Reply Quote 0
                  ProntoPrint @jay_s_uk
                  @jay_s_uk
                  Thank you for that information,
                  I have the same stock lenght but replaced the extruder with a full metal and dual driven gears.
                  As I can remember, I have set up a test via Prusa gcode settings vary every n-layers of height
                  going through all values of PA up to 1.0
                  I was pretty sure to pick .55 on purpose but right now I have found Chris Basment youtube video about pressure advance and his value is as well 1.3.
                  so without further considerations I will setup PA to 1.3
                  and
                  also found Chris settings especial tuned to the ender 3 with much higher Jerk and accelerations
                  and go on testing from this point
                  P.S.:(shocking for me was Chris motor current settings on x and y of 500mA) way too low considering my other post with layer shift!
                    jay_s_uk @ProntoPrint
                    @ProntoPrint
                    My config can be found here https://github.com/TeamGloomy/ender-3-fly-E3/blob/main/sys/config.g
                    This is for a stock machine with only the board changed. In practise, I also run a cloned BMG extruder.
                    I run my motors at 1200ma (80% of the 1500ma motor rating) and have had no issues with layer shifts etc.
                    I currently see increased print times compared to the slicer time in the order of roughly 20% but I have yet to find the time to optimise this further. The quality of the prints I am achieving on my machine is at a level I'm happy.
                      ProntoPrint
                      Went back to PA .55-.6 with 1.3 the corners and other edges went totally crap
                      with upping all the jerk and acceleration settings like Chris it looks very promising in print time and visuable print quality now
                      I reduced motor current on x and y to 1000mA I have crazy oscillations on x axis at high speed .
                      if the print now turns good on print quality with 80mm/s, I will return to to the
                      for improving the ringing arround the edges.
                      on the last print with 1200mA current I could see
                      different oscillations visualized on long straight x edges, at last print, it seems that the high motor current
                      gets into a resonance frequency at high speed double the peak distance than cornering frequency.
                      Question: is there an other setting for frequencys on reprap controlling (not DAA), frequencys of high speed?
                        ProntoPrint
                        Total Print time!!:
                        again I was searching for the total "true" time of the print.
                        all research in the forum ended with no such simple and absoltuly necessary found.
                        Do I miss something if yes please tell me how to find total print times,
                        to have a comparison print time wise between variation of printing and driving parameters.
                          @ProntoPrint Do you mean a stored value for the time a real print took? Unfortunately that isn't stored at the moment, but has been suggested. However, you can simulate prints, and updating the parameters and repeating simulating should show how the parameter changes affect print time.
                            ProntoPrint
                            Thanks Ian
                            that just answered what I found during research .
                            It is really a shame, such a super piece of hardware and no way of getting the total print time out of it.
                            I am working and building octoprint servers, There it is a feature ever there since I can think;
                            even more with the "print time genius" plugin you get more precise predictions of print time already during print, so if you change parameters on Slicer even if not printed to the end you already can predict total print time
