    PanelDue 7i stuck at 'connecting'
    PanelDue
    • dom
      dom last edited by
      Hi all,
      I purchased a PanelDue 7i and am attempting to connect with my Duet2 Wifi. I have the latest paneldue firmware installed this morning, and am running 2.05.1 firmware on the duet2 wifi.
      I have the correct M575 command in the config file and the paneldue is set to 57600 as well for the baudrate.
      I have both the 4 wire cable and ribbon cable connected. There does not appear to be an issue with the any of the 4-wire pins (all are continuous), and I have swapped through several ribbon cables already.
      I can send commands from the Paneldue to the board, and home the axes, move the axes, etc. But it is still stuck on connecting and will not recognize any files on the SD card.
      Appreciate any help. Thank you.
      BoA 1 Reply Last reply Reply Quote 0
      • BoA
        BoA @dom last edited by
        @dom I think latest paneldue will not work properly with 2.05.1 firmware. Update Duet firmware to 3.2.2
        • Simonjb
          Simonjb last edited by Simonjb
          From github -
          Version 3.2.11
          Upgrade Notes:
          This release is compatible with RepRapFirmware 3.2 or later.
          Someone that knows more may correct me but I think the last 100% 2.05 compatible version was 1.24 of the PanelDue firmware
          Phaedrux 1 Reply Last reply Reply Quote 1
            Phaedrux Moderator @Simonjb last edited by
            @Simonjb said in PanelDue 7i stuck at 'connecting':
            That would be the safe bet, yes.
            • dom
              dom last edited by
              Fantastic. Thank you all. I will update the firmware and let you know. Thanks again.
