    Duet 3 Mini noisy StealthChop + no sensorless homing
    72
    • Argo
      Argo last edited by Argo
      Hi Forum,
      I recently got my Duet 3 Mini and edited my Duet 2 WiFi config.
      Fans, heaters etc. work but I can't get sensorless homing to work and axis movement in general is very loud and noisy.
      I'm using basically a Prusa MK3 printer with their stock LDO 1.8 stepper motors. I know 0.9 motors are a big problem with TMC2209 so I wanted to start with 1.8 motors.
      Below is my config.g and homeall.g which worked with my Duet 2 WiFi.
      I added V34 to the M569 gcode so that the speed is high enough for homing etc. for StealthChop.
      M569 P0.0
      Drive 0 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 34 (110.3 mm/sec), pwmScaleSum 15, pwmScaleAuto 8, pwmOfsAuto 255, pwmGradAuto 16, pos 872
      I assume I need to find the right settings? With Marlin 2 and TMC2209 (other board) those stepper motors run fine when disabling hybrid mode. Is that possible for the Duet 3 Mini? I'd rather have no SpreadCycle at all and rather stick to slower print speeds (max 100 mm/s) for less problems with the settings.
      My config.g:
      G90                                         ; Send absolute coordinates...
      M83                                         ; ...but relative extruder moves
      M550 P"Pruset II MK3s"                        ; Set machine name
      M552 S1                                     ; Enable network
      ;M552 S2                                     ; Enable AP
      M586 P0 S1                                  ; Enable HTTP
      M586 P1 S0                                  ; Disable FTP
      M586 P2 S0                                  ; Disable Telnet
      M575 P1 S1 B57600							; Panel Due
      ; Drive Mappings
      M569 P0.0 S1 V34                              ; Drive 0 goes forwards: X Axis
      M569 P0.1 S0 V34                            ; Drive 1 goes backwards: Y Axis
      M569 P0.2 S1 V34                            ; Drive 2 goes backwards: Z Axis
      M569 P0.3 S1 V34                           ; Drive 3 goes forwards: E Axis
      M569 P0.4 S1 V34                          ; Drive 4 goes backwards: Z Axis (at E1)
      ; Micrpstepping and Speed
      M350 X16 Y16 E16 Z16 I1                     ; Configure microstepping with interpolation
      M92 X200.00 Y200.00 Z400.00 E415.00         ; Set steps per mm
      ; Speeds, Acceleration and Jerk
      M566 X240.00 Y240.00 Z24.00 E270.00 P1      ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z720.00 E3000.00   ; Set maximum speeds (mm/min)
      M201 X1200.00 Y1200.00 Z1000.00 E500.00    ; Set accelerations (mm/s^2)
      M204 P1200.0 T1200.0   						 ; set print and travel accelerations (mm(s^2)
      ; Motor currents
      M906 X500.00 Y550.00 Z500.00 E550.00 I10    ; Set motor currents (mA) and motor idle factor in percent
      M84 S30                                     ; Set idle timeout
      ; Motor remapping for dual Z and axis Limits
      M584 X0 Y1 Z2:4 E3				; two Z motors connected to driver outputs Z and E1
      M671 X-37:287 Y0:0 S10			; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      ; Printer geometry
      M208 X0:250 Y-4:215 Z-0.2:205  ; X carriage moves from 0 to 250, Y bed goes from 0 to 210
      M564 H0							; allow unhomed movement
      ; Endstops for each Axis
      M574 X1 S3								 ; Set endstops controlled by motor load detection
      M574 Y1 S3                               ; Set endstops controlled by motor load detection
      ; Stallgaurd Sensitivy
      M915 X S0 F0 H200 R0		                ; Set X axis Sensitivity
      M915 Y S0 F0 H200 R0		                ; Set y axis Sensitivity
      ; Z-Probe Super PINDA
      M558 P5 C"^io3.in" I1 H1 F1000 T6000 A20 S0.005 ; PINDA
      ; Probing Mesh Grid and Sheets
      M557 X24:221 Y10:195 P8                     ; Define mesh grid for probing
      ;G31 P1000 X23 Y5 Z1.570 	                 ; Textured
      G31 P1000 X23 Y5 Z1.275 					; PEI
      ; Heatbed Heaters and Thermistor Bed
      ;M308 S0 P"temp0" Y"thermistor" T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 Bed
      M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 0 Bed
      M950 H0 C"out0" T0						; Creates Bed Heater
      M307 H0 A117.2 C382.7 D10.8 V23.2 B0         ; Bed PID Calibration and PWM
      M140 H0										; Bed uses Heater 0
      M143 H0 S120                                ; Set temperature limit for heater 0 to 120C Bed
      ; HotEnd Heaters and Thermistor HotEnd
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8  ;define E0 temperature sensor e3d
      M950 H1 C"out1" T1					; Create HotEnd Heater
      M307 H1 A244.7 C85.1 D3.4 V23.7 B0		; Hotend PID Calibration and PWM
      M143 H1 S285                            ; Set temperature limit for heater 1 to 285C HotEnd
      M302 S185 R185
      M950 F1 C"out5" Q250				; Creates HOTEND Fan
      M106 P1 T45 S255 H1                 ; HOTEND Fan Settings
      M950 F0 C"out6" Q250				; Creates PARTS COOLING FAN
      M106 P0 H-1                         ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
      M563 P0 D0 H1 F0                            ; Define tool 0
      G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
      G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
      M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck"  ; Runout Sensor Logic: Startup with filament = runout sensor active   Startup without filament = autoload active
      My homeall.g:
      G1 Z8 F800 H2          ; lift Z relative to current position
      G1 H1 X-255 F3800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H1 Y-215 F3800 ; move quickly to X and Y axis endstops and stop there (first pass)
      M913 X60 Y60 Z100 ; set X Y Z motors to 60% of their normal current
      G91 ; relative mode
      G1 H2 Z2 F2600 ; raise head 2mm to ensure it is above the Z probe trigger height
      G90 ; back to absolute mode
      G1 X104 Y100 F6000 ; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height```
      • Veti
        Veti last edited by
        @Argo said in Duet 3 Mini noisy StealthChop + no sensorless homing:
        did you update to the 3.2.2? there was a bug with the sensorless homing that the sensitivity was set wrong
        Argo 1 Reply Last reply Reply Quote 0
        • Argo
          Argo last edited by
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-11
          Should be the newest stable version I guess.
          • Veti
            Veti last edited by
            i was wrong . its in the 3.3 beta.
            see
            https://forum.duet3d.com/topic/21108/stall-detection-on-duet-3-mini
            • Argo
              Argo @Veti last edited by Argo
              @Veti
              Thanks just updated to
              FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta1 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-14 16:24:45
              But movements are still very loud and vibrate a LOT.
              I had similar issues with hybrid mode at Marlin 2 and TMC22209. Solution was to just disable hybrid mode. Hope this is somehow possible.
              • gloomyandy
                gloomyandy last edited by
                M569 P0 should show you what speed a switch from stealthchop to spreadcycle will take place. Not sure if the speeds you are using will trigger the switch or not.
                • Argo
                  Argo @gloomyandy last edited by
                  @gloomyandy
                  With
                  I get:
                  Drive 0 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 34 (110.3 mm/sec), pwmScaleSum 34, pwmScaleAuto 2, pwmOfsAuto 207, pwmGradAuto 18, pos 776
                  Homing is set to F3800 = 63,33 mm/s
                  In theory this should work?
                  • Veti
                    Veti last edited by
                    to disable hybrid mode set V to 0
                    • gloomyandy
                      Looks like it should be staying in stealthchop for the homing move.
                      Things you might try...
                      1. Lower the X and Y current before the homing move. You also don't seem to ever be restoring the current back to 100%.
                      2. What happens if you set a very low stall threshold with something like M915 X S-63 F0 H200 R0, do the motors stall then?
                      Argo 1 Reply Last reply Reply Quote 1
                      • Veti
                        Veti last edited by
                        if you have 1.8 degree stepper this should be X100 Y100
                        • Argo
                          @gloomyandy
                          Ah I lowered the currents for testings. Normally I set them back to 100%.
                          I'll try lower settings now.
                          @Veti
                          My bad, thanks for pointing that out. I had 0.9 motors in my Duet Wifi. Argh 😞
                          Veti 1 Reply Last reply Reply Quote 0
                          • Veti
                            Veti @Argo last edited by
                            @Argo
                            do you where running twice the speed. thats where the noise could have come from
                            • Argo
                              Argo last edited by
                              Thank you guys again 😃
                              With the beta version from the Dropbox archive + correct steps settings and lower sensitivity + no hybrid mode, it's working now and the motors are really quiet.
                              • Veti
                                Veti last edited by
                                the real beta 1 is here
                                https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3beta1
                                not on dropbox
                                • Argo
                                  @Veti
                                  Are those versions the same? dc42 posted in the thread you linked that it's an unofficial beta build. Idk if he means not for public or it's just because it's a beta.
                                  • Veti
                                    Veti last edited by
                                    3.3 beta 1 was release 12 days ago.
                                    the dropbox link was from 21.january.
                                    if its not in beta 1 then that would be good to know, in case he forgot to merge the bugfix.
                                      The bug fix is in the official 3.3beta1 release. The builds currently on Dropbox are later.
                                      • Veti
                                        Veti @dc42 last edited by
                                        its not in the changelog
                                          dc42 administrators @Veti last edited by
                                          @Veti said in Duet 3 Mini noisy StealthChop + no sensorless homing:
                                          Thanks for pointing this out. It is now.
