    dual z axis sync and bltouch issues..
    487
    • FeedingFilamentundefined
      FeedingFilament
      Hey Gang,
      I have a CR10S with 2 Z motors, every X time, the motor on the right seems to get out of adjustment or not synchronized well, but I never get a correct bed leveling, I always have to move the rod a little on the side of that motor.
      I leave my configuration waiting for someone to tell me if I have something wrong configured or I have left something, I thank you in advance for your help.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.25
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 02 2021 10:08:42 GMT+0100 (Central European Standard Time)
      G29  ; probe the bed and enable compensation
      G28 ; home
      G30 P0 X30 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M569 P0 S1                               ; Drive 0 goes forwards
      M569 P1 S1                               ; Drive 1 goes forwards
      M569 P2 S0                               ; Drive 2 goes backwards
      M569 P3 S1                               ; Drive 3 goes forwards
      M569 P4 S0                               ; Drive 4 goes backwards
      M584 X0 Y1 Z2:4 E3 P3; set drive mapping
      M350 X256 Y256 Z256 E16 I0                         ; configure microstepping without interpolation
      M92 X1280.00 Y1280.00 Z6400.00 E415.00             ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 E3000                        ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z900 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                     ; Set idle timeout
      M208 X300 Y300 Z400 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M143 H1 S280
      M950 S0 C"exp.heater3"                                  ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H3 F120 T6000        ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-0 Y-11 Z0.61  			 ; set Z probe trigger value, offset and trigger height
      M557 X50:240 Y65:240 S38
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H1 B0 S3.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 B0 S1.00                                     ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M911 S20 R20 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Tue Nov 19 2019 22:40:08 GMT+0000 (Hora padrão da Europa Ocidental)
      G1 H2 Z2 F6000          ; lift Z relative to current position
      G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-305 Y-305 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G1 H2 X5 Y20 F6000     ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      ;G91                    ; relative positioning
      ;G1 S2 Z2 F100          ; lift Z relative to current position
      ;G90                    ; absolute positioning
      ; homex.g
      ; called to home the X axis
      G1 H1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000    ; go back a few mm
      G1 H1 X-305 F360  ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-2 F6000   ; lower Z again
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000    ; go back a few mm
      G1 H1 Y-305 F360  ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue May 12 2020 11:39:06 GMT+0200 (Central European Summer Time)
      G1 X15 Y15 F6000 ; go to first probe point
      ;G1 Z2 F100      ; lift Z relative to current position
      Cheers
      droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk
        You don't need P3 on your M584 as its doing nothing
        You won't be gaining anything having x256 microstepping so you should switch back to x16 with interpolation. x256 will probably overload the duet.
        I don't see an M671 anywhere which will be why you levelling isn't working
          droftarts administrators @FeedingFilament
          @FeedingFilament I don't see an M671 command in your config.g that defines the location of the leadscrews. When levelling with the two G30 commands in your bed.g, it needs these to calculate how much to adjust each leadscrew. I'm not sure what is used as the default without this.
          See M671 command: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
          and guide to levelling with independent Z: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command. The M671 command must also come after any M667 or M669 command.
            @FeedingFilament
            Also, you're using the default thermistor values, which are unlikely to be correct for your thermistors. See if you can find the correct values for the CR10S.
            • fcwiltundefined
              fcwilt
              I really do not like the configuration tool. It doesn't "think" the way I do.
              Consider these lines from bed.g;
              M561                        ; clear any bed transform
              G28                         ; home
              Since G32 invokes bed.g and G32 is used for, in your case, auto bed leveling why is the height map for mesh compensation created there (G29) and before the bed is homed and leveled?
              Consider these lines from homeALL.g:
              and these lines from homeZ.g:
              Where does that tool get those X and Y values? And why the H2 in the line from homeALL.g?
              Anyway here is what I was taught:
              • When setting the Z=0 datum with G30 it should always be at the same XY position and that the center of the bed is best.
              • When executing a G29 to create/load the height map for mesh compensation you must always set the Z=0 datum first.
              I would get rid of the G29 in the bed.g file and move it whatever code you execute when starting a print. And don't forget to set the Z=0 datum first.
                FeedingFilament
                Thanks @droftarts @jay_s_uk @fcwilt
                I think I am making some progress with the issues, which I had, at the moment I can do a more or less decent print test, I have taken some of your suggestions and "I think" that I am on the right track.
                • The steps I have taken have been
                Z leadscrew coordinates (-20.0,100.0) (325.0,100.0), factor 1.00, maximum correction 1.00mm, manual adjusting screw pitch 0.50mm
                Then:
                3/4/2021, 7:11:40 PM	G30 S-1
                Stopped at height 0.805 mm
                3/4/2021, 7:11:08 PM	Leadscrew adjustments made: -0.065 -0.117, points used 2, (mean, deviation) before (-0.084, 0.011) after (0.000, 0.000)
                3/4/2021, 7:10:42 PM	G32
                30 points probed, min error -0.168, max error 0.130, mean -0.023, deviation 0.068
                Height map saved to file 0:/sys/heightmap.csv
                bed
                I leave my configuration again in case you see any point that I can optimize.
                ; bed.g
                G28 ; home
                M584 X0 Y1 Z2:4 E3						 ; set drive mapping
                M92 X80.00 Y80.00 Z400.00 E420.00                  ; set steps per mm
                M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
                M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                M143 H1 S280
                G31 P25 X-0 Y-11 Z0.800  			 ; set Z probe trigger value, offset and trigger height
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
                M307 H1 B0 S1.00
                ; Lead Screw Offsets
                M671 X-20.0:325.0 Y100.0:100.0 ; leadscrew offsets from home
                ; homez.g
                ; homeall.g
                Thanks to everyone!!!!
                • fcwiltundefined
                  fcwilt
                  Did you read and understand what I posted?
                  Your configuration files are still a bit of a mess.
                  I will be glad to try to clarify what I posted.
                  FeedingFilamentundefined 1 Reply Last reply Reply Quote 1
                    FeedingFilament @fcwilt
                    @fcwilt many thanks! so apart from eliminating the G29 from the bed.g
                    I think I have understood the rest and I believe that I have followed the same process, I will tell you if I am right or I am doing something wrong.
                    G1 Z5
                    G90
                    G1 X150 Y150 F6000
                    G91
                    M561
                    M564 S0
                    M291 S3 Z1 R"Down to zero" P"0"
                    G92 Z0
                    G1 Z5
                    G30 S-1
                    once I have the z offset in the config.g this should work fine, right?
                    I really appreciate your interest and help, tell me if there is something that I am not doing well or that I can optimize.
                    Thanks
                    • fcwiltundefined
                      fcwilt @FeedingFilament
                      @FeedingFilament said in dual z axis sync and bltouch issues..:
                      G1 Z5
                      G90
                      G1 X150 Y150 F6000
                      G91
                      M561
                      M564 S0
                      G92 Z0
                      G1 Z5
                      G30 S-1
                      What exactly are you trying to do there?
                      FeedingFilamentundefined 1 Reply Last reply Reply Quote 0
                        @fcwilt I am trying to figure out the height of the offset for that from the center of the bed. Then I lower the nozzle to 0, I adjust the bed with the paper, I do a height test to know how high it is and I modify it in the config.g. This is how I configure the distance from the nozzle to the bed.
                        • fcwiltundefined
                          OK now I see what you are doing.
                          I always install a Z axis endstop sensor so I can home all my axes first and start from there - so my approach to determining the Z probe trigger height is a bit different.
