    Manual Bed Levelling & Mesh Levelling on a corexy printer?
    1.8k
    • natty15dundefined
      natty15d
      Needing some advice on the best way to set up Manual Bed Levelling and Manual Bed Mesh Levelling on a corexy printer using a Duet2 wifi
      Ive read through these
      https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
      https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Checking_the_trigger_height
      They are helpful but i want to be sure i’ve understood it correctly
      My 500x400mm glass sheet is very slightly warped along the 500mm (front to back)
      I’m using a regular mechanical Z stop & i only want to manually relevel the bed as required, would it be best to use a “User-Defined Macro” to do this. If i use the following code will the printhead travel to each specified point in turn, pause while i manually adjust the bed height & give me a prompt on the LCD to go to the next point?
      G28 ; home
      G30 P0 X90 Y313 Z0 ; probe near an adjusting screw
      G30 P1 X290 Y313 Z0 ; probe near an adjusting screw
      G30 P2 X290 Y110 Z0 ; probe near an adjusting screw
      G30 P2 X90 Y110 Z0 ; probe near an adjusting screw
      Or should it be added to “Config.g”, would i then be forced to relevel everytime?
      Once the bed is level it’s perfect for all of my regular sized prints & only rarely needs to be relevelled
      It's only prints that extend to the front and back edges that need compensation.
      Can I configure the Manual Bed Mesh Levelling to only be used on certain prints?
      I’m using a mechanical Z stop, will the Manual bed Levelling be able to adjust past the end stop as the outermost edges are too far away from the hotend. Or should I have a second “User-Defined Macro” for manually levelling the bed with the 4 set points on the outer edges of the bed, making the centre the high point and then any adjustments would be to lower the bed and not trigger the mechanical z stop?
      • fcwiltundefined
        fcwilt @natty15d
        @natty15d
        It helps to use the correct terms so we know we are all talking about the same thing.
        In regards to leveling the bed the firmware has two features: Auto Bed Leveling (ABL) and the Manual Bed Leveling Assistant (MBLA).
        The commands to use ABL or MBLA are normally placed in **bed.**g and the command G32 is used to invoke bed.g.
        To compensate for bed surface irregularities the firmware has Mesh Bed Compensation (MBC) . It has nothing to do with leveling.
        First question: What Duet hardware are you using and what version of firmware is it running?
        natty15dundefined 1 Reply Last reply Reply Quote 0
        • natty15dundefined
          natty15d @fcwilt
          @fcwilt thank you, I'm running a duet2 wifi with 3.1.1
          • fcwiltundefined
            fcwilt
            Thanks for the info.
            The way the Manual Bed Leveling Assistant works is upon executing a G32 command the commands in bed.g are executed.
            In your example the bed will be probed 4 times, the results computed and the actions you need to take will be displayed.
            For each adjustment screw you will be told how many turns and in what direction you need to adjust the screw. It will also report how far the bed at that adjustment screw needs to be raised or lowered.
            I find that I have to execute G32 several times to get the adjustment screws all adjusted correctly as performing a 0.32 turn of an adjustment screw is rather difficult, at least for me.
            • natty15dundefined
              natty15d @fcwilt
              @fcwilt should z be set at 0 or - 99999?
              So if I set it up correctly and run the g32 command the print bed will go to zero, then the print head moves to the 1st set point and I level the bed with the corresponding screw, accept when level and the print head moves to the next set point?
              If this is what happens why does it have to be split between the config.g and bed file instead of a macro?
              Sorry for all the questions, this level of printer control is new to me and still getting to grips with everything the duet has to offer
              • fcwiltundefined
                fcwilt @natty15d
                @natty15d said in Manual Bed Levelling & Mesh Levelling on a corexy printer?:
                I prefer to have X=0 Y=0 at the center of my bed. So the ranges for my X and Y axes, as set in my config file, are -150 to +150.
                Here is the essence of my bed.g file:
                G1 X{-sensors.probes[0].offsets[0]}, Y{-sensors.probes[0].offsets[1]}, F6000 ; move probe to center of bed
                G30                              ; probe bed and set Z=0 datum
                M671 X-160:-160:160  Y-160:160:0 ; specify where bed leveling adjustment screws are located
                G30 P0 X-130 Y-130  Z-99999      ; probe near adjusting screw #1 (left front  )
                G30 P1 X-130 Y130   Z-99999      ; probe near adjusting screw #2 (left rear   )
                G30 P2 X130  Y0     Z-99999 S3   ; probe near adjusting screw #3 (right middle) and compute results
                To invoke bed.g I execute G32 from the DWC.
                The results of probing the bed are displayed AFTER the probing is complete. Then I use the instructions contained in the results and adjust each screw as best I can.
                I then repeat G32 as many times as it takes to get things perfect.
                You cannot do this in config.g as the required conditions do not exist until after config.g is executed.
                You should not attempt to perform ANY motions commands in config.g.
                • natty15dundefined
                  natty15d @fcwilt
                  @fcwilt so m671 can be added to the bed file rather than the config.g file?
                  Would that same coding work if added as a macro rather than added to the bed file?
                  That way I wouldn't have to remember g32 to activate it as the macro has a dedicated on screen button nothing needs to be saved as the bed is levelled manually by using the screws?
                  • fcwiltundefined
                    fcwilt @natty15d
                    Yes - there are many things that most folks put into the config.g file that I put in other macros to keep related commands together.
                    It most likely would but then the G32 command would not work.
                    If you want a dedicated macro button just create one with a G32 command and use bed.g as intended.
                    That way the DWC menu command True Bed Leveling works as well as your macro button.
                    And if for some reason G32 does something behind the scenes that we are not aware of everything will still work.
                    • natty15dundefined
                      natty15d @fcwilt
                      @fcwilt thank you that's a massive help, will try that out tomorrow and let you know how it goes
                      • natty15dundefined
                        natty15d
                        Setting up the Manual Bed Leveling Assistant (MBLA)
                        Measured the printer today and have located all the screws relative to Home position 0,0 which is Front Left on my CoreXY.
                        I've listed the screws in config.g in order Rear Left, Rear Right, Front Right & Front Left
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 17:51:25 GMT+0000 (Greenwich Mean Time)
                        M550 P"Eniac40" ; set printer name
                        M669 K1 ; select CoreXY mode
                        M671 X-34:413:413:-34 Y434:434:13:13 P0.5 ; 1screwRL(-34,434), 2screwRR(413,434), 3screwFR(413,13), 4screwFL(-34,13), thread pitch 0.5mm
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M92 X80.24 Y80.24 Z399.44 E412.00 ; set steps per mm
                        M566 X900.00 Y900.00 Z60.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X15000.00 Y15000.00 Z720.00 E15000.00 ; set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                        M906 X1700 Y1700 Z1700 E680 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X380 Y423 Z405 S0 ; set axis maxima
                        M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
                        M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                        M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                        M558 P0 H2 F120 T15000 ; disable Z probe but set dive height, probe speed and travel speed
                        M557 X15:215 Y15:195 S20 ; define mesh grid
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                        M307 H0 A84.5 C94.6 D0.7 S1.00 V11.9 B0 ; PID heated bed
                        M143 H0 S80 ; set temperature limit for heater 0 to 80C
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                        M307 H1 A298.1 C175.7 D3.8 S1.00 V11.8 B0 ; PID hotend heater
                        M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on
                        M591 D0 P2 C"e0_stop" S1 ; filament monitor connected to E0_stop
                        T0 ; select first tool
                        Then in bed.g i listed the probe points in the same order RL, RR, FR, FL. I also added M561 to clear any previous settings, & deactivated M401 & M402 as i dont have a z probe and want to use the 4 manual levelling screws to adjust the bed hieght, is that the right thing to do?
                        ; bed.g
                        ; G29 ; probe the bed and enable compensation
                        G28 ; home
                        ; M401 ; deploy Z probe (disabled)
                        G30 P0 X87 Y314 Z-99999 ; probe near an adjusting screw RL
                        G30 P1 X293 Y314 Z-99999 ; probe near an adjusting screw RR
                        G30 P2 X293 Y110 Z-99999 ; probe near an adjusting screw FR
                        G30 P3 X87 Y110 Z-99999 S4 ; probe near an adjusting screw FL and report adjustments needed
                        ; M402 ; retract probe (disabled)
                        Does that look like a useable Config.g & Bed.g or have i missed anything?
                        Nathan
                        • fcwiltundefined
                          fcwilt
                          Are those probe points as close to the adjustment screws as you can get?
                          natty15dundefined 2 Replies Last reply Reply Quote 0
                          • natty15dundefined
                            natty15d @fcwilt
                            @fcwilt using those positions gives me a large level area covering roughly 3/5ths of the glass and is big enough for 99% of what I print. This means I don't have to run a mesh levelling routine to compensate for any uneveness.
                            If I level at the extremes then only the outer front and rear edges are printable and the centre section is too high and I'd have to use mesh compensation all the time when I just want to use it for very occasional prints
                            • natty15dundefined
                              natty15d @fcwilt
                              @fcwilt Just a thought, could I set the following as a macro and use it for regular sized prints that don't need mesh bed compensation
                              ; macro to perform manual bed levelling assistance
                              ; Preheat PLA
                              M140 S60;
                              M104 S180 T0;
                              G28 ; home
                              Then have my bed.g file, that i'd activate with G32, with a different set of probe co-ordinates closer to the edge, and then follow that up with mesh bed compensation?
                              • fcwiltundefined
                                fcwilt
                                Have you done anything with the conditional gcode feature of v3 firmware?
                                I use it to control things like choosing between mesh compensation being enabled or not at the start of a print.
                                Since v3 doesn't currently have variables I used dummy fan names as a text variable that I could set and test.
                                If you would like I could give you the details.
                                natty15dundefined 1 Reply Last reply Reply Quote 1
                                • natty15dundefined
                                  natty15d @fcwilt
                                  @fcwilt No I haven't read up on those
                                  I have the code ready and will try it tomorrow morning but worried I'm going to damage my printer if i mess this code up or it doesn't do what I think it'll do
                                  How i want it to operate is run G32,
                                  the print head will move to P0 and the bed will hit the mechanical end stop and stop at "0"
                                  then i adjust the screw on the bed corner to allow a sheet of paper to just pass between the bed and the nozzle, then tell the printer to move to the next point and so on till all four corners are level
                                  Is this what will happen with this code?
                                  ; bed.g
                                  G28 ; home
                                  • fcwiltundefined
                                    fcwilt @natty15d
                                    ; bed.g
                                    G28 ; home
                                    No it doesn't work that way.
                                    It will probe all for points first and then calculate the required adjustments and display them.
                                    At least that is how it works with an actual Z probe.
                                    Have you considered getting one for your printer?
                                    • natty15dundefined
                                      natty15d @fcwilt
                                      @fcwilt Thought about it but only need it for prints that take up the entire bed which for me is rare, and it'll add extra weight the carriage.
                                      Came across a post by @Phaedrux who did something very close to what i want to do so I've altered it to this
                                      ; macro to perform manual bed levelling assistance to the centre of the bed only for regular prints
                                      ; Preheat PLA
                                      M140 S60;
                                      M104 S180 T0;
                                      G28 X ; home X
                                      G28 Y ; home Y
                                      G28 Z ; home Z
                                      ; Move nozzle to leveling points and prompt user to level bed at each point
                                      M291 P"Nozzle will now move to the 4 leveling points RL, RR, FR & FL." S1 T2
                                      ; Move to Rear Left leveling point P0
                                      G1 Z5 ; move to z5 for travel
                                      G1 X87 Y314 ; Move to rear left corner
                                      G1 Z0 ; move to z0 to level the bed
                                      M400
                                      M291 P"Adjust RL using a piece of paper, when set click Confirm to go to RR" R"CONFIRM" S2 Z0
                                      ; Move to Rear Right leveling point P1
                                      G1 X293 Y314 ; Move to rear right corner
                                      M400
                                      M291 P"Adjust RR using a piece of paper, when set click Confirm to go to FR" R"CONFIRM" S2 Z0
                                      ; Move to Front Right leveling point P2
                                      G1 X293 Y110 ; Move to front right corner
                                      M400
                                      M291 P"Adjust FR using a piece of paper, when set click Confirm to go to FL" R"CONFIRM" S2 Z0
                                      ; Move to Front Left leveling point P3
                                      G1 X87 Y110 ; Move to front left corner
                                      M400
                                      M291 P"Adjust FL using a piece of paper, when set click Confirm" R"CONFIRM" S2 Z0
                                      ; Move Z
                                      G1 Z50 ; Drop bed to z50 for nozzle clearance
                                      M291 P"The bed has been mechanically leveled" S2
                                      • fcwiltundefined
                                        fcwilt @natty15d
                                        That might work. You may have to run it more than once.
                                        The actual Manual Bed Leveling Assistant (which works best with a Z probe) takes into account how each adjustment screw will interact with the others and the suggested adjustments reflect that.
                                        • natty15dundefined
                                          natty15d @fcwilt
                                          @fcwilt Just created a second one to level the entire bed, then ill follow that up with Mesh Bed Compensation. That's going to be another head scratcher LOL
                                          ; macro to perform manual bed levelling assistance to the Entire bed for large prints
                                          ; Preheat PLA
                                          M140 S60;
                                          M104 S180 T0;
                                          G28 X ; home X
                                          G28 Y ; home Y
                                          G28 Z ; home Z
                                          G1 X40 Y372 ; Move to rear left corner
                                          M400
                                          G1 X340 Y372 ; Move to rear right corner
                                          M400
                                          G1 X340 Y52 ; Move to front right corner
                                          M400
                                          G1 X40 Y52 ; Move to front left corner
                                          M400
                                          ; Move Z
                                          M291 P"The entire bed has been mechanically leveled, now perform Mesh Bed Compensation" S2
                                            That macro worked well for me because I can easily visually see how close the nozzle is to the bed so a tiny adjustment to the screw is needed and it stays put for a long time. I have it do two passes of the 3 screws and it's enough for me. YMMV
