    Adding wpa.supplicant.config file to boot partition
    Firmware installation
    • carcamerarigundefined
      carcamerarig
      Hi there,
      New user trying to setup duetPi by adding the wpa.supplicant.config file on the SD before I run it on the Pi but im not seeing the wood through the trees....
      Where exactly do I add the newly created file? It says boot partition in the dozuki but I only see one partition on my Mac, am I being crazy and just need to drop it in the sys folder? If not could someone point me off in the right direction in how to access the boot partition please.
      • alankilianundefined
        alankilian
        I've run a million Raspberry PIs, but I've never run in SBC mode, so this might be completely wrong.
        Did flashing your SD card with Etcher work?
        That looks like the filesystem from an normal "Insert into the Duet3"SD card to me.
        A Raspberry PI SD card boot partition should have stuff like this on it:
        kilian@DESKTOP-UP82TLJ /cygdrive/f
        $ ls -l
        total 54469
        -rw-r--r-- 1 kilian None    18693 Dec 10 20:43  COPYING.linux
        -rw-r--r-- 1 kilian None     1594 Dec 10 20:43  LICENCE.broadcom
        drwxr-xr-x 1 kilian None        0 Dec 10 13:33 'System Volume Information'
        -rw-r--r-- 1 kilian None    25426 Dec 10 20:43  bcm2708-rpi-b-plus.dtb
        -rw-r--r-- 1 kilian None    24774 Dec 10 20:43  bcm2708-rpi-b-rev1.dtb
        -rw-r--r-- 1 kilian None    25163 Dec 10 20:43  bcm2708-rpi-b.dtb
        carcamerarigundefined 1 Reply Last reply Reply Quote 1
          carcamerarig @alankilian
          @alankilian Thanks for replying, much appreciated. So its just the card that shipped with the mini 5+ in the dozuki it says tethered mode is considered as the normal mode to setup, have i inadvertantly assumed the card would be configured for duetpi and in fact as you say its set up for standalone mode?
          I just booted up windows in parallels to see if that can see the hidden files but all I see is an additional system information folder...
          If it is I can etcher the duetpi image straight on and get cracking lol, I only know a little information, dangerous I know haha
            alankilian
            Yes, it looks like you skipped STEP 1 in the procedure.
            Start there again and I think you'll see the boot partition as it should be.
            carcamerarigundefined 1 Reply Last reply Reply Quote 0
              @alankilian said in Adding wpa.supplicant.config file to boot partition:
              Ohh the joys haha
              im just not most of the time eh...
              Never having done or seen it before, a little note in the guide to see which version the card shipped with could help.
              Thanks again Alan.
                Phaedrux Moderator @carcamerarig
                @carcamerarig said in Adding wpa.supplicant.config file to boot partition:
                Where does it state that?
