    First layer wont stick, need some help with my config
    • TiToMoskitoundefined
      TiToMoskito
      Hello my friends,
      i have a huge problem with my ender 5, the first layer wont stick anymore.
      To explain how it all happened. I printed something and when it was finished I wanted to take it off the heatbed and tore it too much, since nothing want stuck on the heatbed.
      I tried leveling and it really did at least 20 times, then I bought this and it didn't help either. I also exchanged the BLTouch without success.
      Then I updated the firmware and since then the belt is skipping some gears when homeing.
      I added a Z-axis to the Ender 5 and the automatic adjustment of G32 doesn't work, so I put the second Z-motor on Z2 and adjusted it manually.
      It would be nice if someone looks at my configuration, maybe I did something wrong. Would be really nice.
      My setup
      Printer: Ender 5
      Z-Probe: BLTouch
      Z-Axis : 2
      Hotend: Micro-Swiss All Metal Hotend
      Extruder: BMG Extruder
      Start G-Code
      G28 XY
      M561 ; Clear bed transforms
      G28 Z ; Home Z
      G29 S1 ; Load mesh leveling from SD card
      G92 E0 ; reset extrusion distance
      G1 Z0.2 F1000.0
      G1 X60.0 E9.0 F1000.0 ; priming
      G1 X125.0 E12.5 F1000.0 ; priming
      G1 Z0.5 F1000.0
      End G-Code
      G10 P0 R-273.15 S-273.15     ; Turn off Tool0
      G10 P1 R-273.15 S-273.15     ; Turn off Tool1
      M140 S-273.15                ; Turn off Bed
      M106 S0                      ; Object fan off
      G1 Z210                      ; Move Z to Z210
      G92 E0                       ; Zero Extruder
      G1 E-2 F300                  ; Retract 2mm
      G28 XY                       ; Home XY
      M84                          ; All motors Off
      Config Files
      retractprobe.g
      homez.g
      homey.g
      homex.g
      homeall.g
      heightmap.csv
      deployprobe.g
      config-override.g
      config.g
      bed.g
      • fcwiltundefined
        fcwilt @TiToMoskito
        @TiToMoskito
        Please post all of your configuration files using the </> tag like you did for you start and end code.
        Others everyone has to download each file.
          Are you trying to do automatic tilt correction with dual z axis?
          You would need to have each Z motor on it's own stepper driver and you would need to add a M671 command to config.g that defines the position each lead screw, and then in your bed.g you would need to define a point to probe close to each lead screw.
          That's all described here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          This is separate from mesh compensation which maps out the surface of the bed and adjusts the Z height for the entire bed area. That is done by configuring M557 and running G29.
          https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
          So let us know what you want to achieve.
          As you currently have it I think part of the problem might be a bad mesh. So remove the G29 S1 you have from your homing files. It only really needs to be loaded in your start gcode after all axis are homed, which it is.
          In order to get a good first layer the bed must be mechanically leveled by hand first while hot. Then your probe trigger height needs to be measured and set. Then you should create a mesh with G29.
          So maybe go through this calibration process for the bed and extruder first. Since that's the foundation of a good layer.
          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
          Then setup your probe offsets.
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          Then create a mesh and show us what the resulting map looks like.
          Setting up tilt correction is a good idea to keep your motors in sync. Otherwise they will drift out of alignment over time.
          The correct order of operations would be
          G28 to home all axis
          G32 to run bed.g and correct for tilt
          G28 Z again to set Z0 again to accoutn for any change in tilt
          G29 to run a mesh of the bed surface
            TiToMoskito
            Thank you @Phaedrux , i made every step you said, and now the first layer sticks on the bed.
            I swear i leveled the whole printer about 20 times...
            Nevermind, it works now and im really happy 🙂
            Thank you again 🙂
            Is my heightmap okay, or should i optimize it a bit more?
            I have currently one problem, the True Bed Leveling (G32) doesnt move on my leadscrew positions.
            When it should move to the first leadscrew (X70 Y10) it moves to (X23 Y26), why does this happen?
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 14:18:36 GMT+0100 (Mitteleuropäische Normalzeit)
            G90                                     ; send absolute coordinates...
            M83                                     ; ...but relative extruder moves
            M550 P"Ender 5"                         ; set printer name
            M552 S1                                 ; enable network
            M586 P0 S1                              ; enable HTTP
            M586 P1 S0                              ; disable FTP
            M586 P2 S0                              ; disable Telnet
            M569 P0 S1                              ; physical drive 0 goes backwards
            M569 P1 S1                              ; physical drive 1 goes backwards
            M569 P2 S0                              ; physical drive 2 goes forwards
            M569 P3 S1                              ; physical drive 3 goes backwards
            M569 P4 S0                              ; physical drive 3 goes backwards
            M584 X0 Y1 Z2:4 E3                     	; set drive mapping
            M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z400.00 E385.00       ; set steps per mm
            M566 X1200.00 Y1200.00 Z24.00 E300.00   ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z100.00 E6000.00   ; set accelerations (mm/s^2)
            M906 X850 Y800 Z800 E1000 I50           ; set motor currents (mA) and motor idle factor in per cent
            M671 X70:70 Y10:200 S0.5 				; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            M84 S30                                 ; Set idle timeout
            M208 X0 Y0 Z0 S1                        ; set axis minima
            M208 X220 Y220 Z300 S0                  ; set axis maxima
            M574 X1 S1 P"xstop"                     ; configure active-high endstop for high end on X via pin xstop
            M574 Y1 S1 P"ystop"                     ; configure active-high endstop for high end on Y via pin ystop
            M574 Z1 S2                              ; configure Z-probe endstop for low end on Z
            M950 S0 C"exp.heater3"                  ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T6000     ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X44 Y-17 Z1.85                 ; set Z probe trigger value, offset and trigger height
            M557 X15:195 Y15:195 S20                ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" B4092 R4700 	; configure sensor 0 as PT1000 on pin bedtemp
            M950 H0 C"bedheat" T0   						; create bed heater output on bedheat and map it to sensor 0
            M307 H0 R0.310 C384.6 D1.73 S1.00 V23.5			; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                 		; map heated bed to heater 0
            M143 H0 S120                            		; set temperature limit for heater 0 to 120C
            M308 S1 P"e0temp" Y"thermistor" B4092 R4700     ; configure sensor 1 as PT1000 on pin e0temp
            M950 H1 C"e0heat" T1                    		; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 R3.417 C47.1 D3.33 S1.00 V24.0    		; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S275                            		; set temperature limit for heater 1 to 275C
            M950 F0 C"fan0" Q500                    ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                          ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                    ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45                       ; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" Q500                    ; create fan 2 on pin fan2 and set its frequency
            M106 P2 S1 H1:0 T45                     ; set fan 2 value. Thermostatic control is turned on
            M563 P0 D0 H1 F0                        ; define tool 0
            G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
            G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
            ; BLTouch startup
            G4 S2									; Pause a couple seconds
            M280 P64 S160							; Clear any alarms
            M402									; retract pin just in case
            M912 P0 S-11							; CPU Temp Calib
              jay_s_uk @TiToMoskito
              @TiToMoskito its taking your probe offsets into account.
              So you ask for a nozzle position of X70 Y10 and it moves so the probe is over that position, which is X23 Y26
